bajorek Samba Member
Posted: Tue Aug 19, 2003 2:35 pm Post subject: What are the vents on the bottoms of front doors? |
What are the vents for on the driver's and passenger's doors. I'm talking about the ones down toward the bottom with the blue handle.
Are they fresh air vents? I don't have the rectangular, long, plastic vents going to my doors like I've seen on some. |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Tue Aug 19, 2003 3:27 pm Post subject: |
So because I don't have the "fresh air circulation" ducts in the doors (mine have no opening, or ducting for air to flow), I don't get fresh air coming out of those vents? |
NeverHadaBeetle Samba Member
Joined: October 08, 2002 Posts: 442 Location: Missouri
Posted: Tue Aug 19, 2003 7:40 pm Post subject: |
"Circulation" is an optimistic assessment of these vents' performance. There is not ducting inside the door for the ones you have. The air simply passes through the door cavity where it is channeled via the plastic sheeting behind the door panel and out through the vent. Whenever I replace door panels I replace the plastic and simply seal these vents up. They don't provide enough air in the summer and they leak too much air in the winter. _________________ "Well, we shot the line and we went for broke
With a thousand screamin' trucks
An' eleven long-haired friends a' Jesus
In a chartreuse micra-bus." |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Tue Aug 19, 2003 8:21 pm Post subject: |
The air for those vents comes in thru the front edge of the door. Look between the hinges when you have the door open. |
A.J. Adams Samba Member
Joined: August 20, 2003 Posts: 115 Location: Stroud, United Kingdom
Posted: Thu Aug 21, 2003 5:12 pm Post subject: |
Any idea where I can get a set of those vents for my bus? |
Karl Samba Member
Posted: Thu Aug 21, 2003 6:33 pm Post subject: |
What year is your bus? I believe 68 and 69 did not come with them and they do not have the vent holes in the front edge of the door.
68 doors are one year only: they have pushbutton handles like a 67 [lever action came in 69] and the lock knob is on the top of the doorsill. 69 to about 74 had the lock knob by the inner handle. Then the knob moved back to the sill, but they have air slots in the front edge. Mid 75 or mid 76 the hinges were complete opposites. Early doors used an allen bolt that went thru the door hinge and threaded into the bracket welded to the A pillar. Late doors had a 13mm headed bolt that went thru the bracket and threaded into the hinge. |
Posted: Thu Aug 21, 2003 6:49 pm Post subject: |
Mine is a 78 Westy. I want to add them in, it didn't have them originaly. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Fri Aug 22, 2003 7:09 pm Post subject: |
A.J. Adams wrote: |
From what I have read so far, people here have not figured out these vents. They were introduced in 1973 and are air extraction vents to allow flow-through ventilation. There is negative air pressure at the leading edge of both front doors. The slotted holes on the inner door skin at the front edge of the doors pull a nice vacuum that removes the air from the interior of the car.
The engineers missed something though. Water can come dumping in during hard rain. There is a gutter (?) along the edge of the wheel well that is optimistically supposed to channel water down to the step. The inner panel vapor barrier has an opening for this air extraction, and it allows water in.
Your defroster and fresh air performance are enhanced by keeping the blue slide levers in the forward position.
The Westfalias do not have the door ventilation channels that allow the 7-9 passenger Buses to cool off the passengers with the partition panel vents, and they do not have the door extractors because less airflow occurs through the ventilation system, and I suppose the louvred side glass leaks air anyhow.
Colin |
Posted: Sat Aug 23, 2003 6:27 am Post subject: |
OK, that's settled, you open the vent, and air moves thru it. Now where can I find a set for sale? |
Bravhefen Samba Member
Joined: August 09, 2003 Posts: 135 Location: Las Vegas
Posted: Sun Aug 24, 2003 9:22 pm Post subject: Found One |
Hey I found one vent grill. If your interested It's yours. It's in very good shape. I figure at minimum you could cut the hole for the grill, clip it in place and paint behind it black.
Let me know. I looked and looked for the other one. but I could only find the one.
Rob _________________ I learn so much in here, sometimes it makes my head hurt.
Proude SBS Member #12
78' Transporter
69' Westy |
