sbclayton Samba Member
Joined: October 14, 2003 Posts: 483 Location: A place where owning a VW and enjoying life are synonymous
Posted: Thu Apr 12, 2012 8:14 pm Post subject: |
Beautiful! Great score, that! Does the Seller have more of these? Oh - also, can these be stacked, end-to-end? I'm thinking engine oil here...
PS - Fluid temp figure is from turbodieselregister.com, back when I was hauling powerboats with my 95 Dodge diesel pickup. Recommendation was to keep the fluid as close to 150° as possible. Don't know what is the ideal temp for Vanagons. _________________ Steve - Tampa Bay Area
Original Owner (12/1990) of
NavDog, a 91 Carat
Enlightenment came when I realized that any time in my life I was having fun, it was somehow connected with owning a Volkswagen. |
James 93SLC Samba Member
Joined: January 21, 2009 Posts: 937 Location: NE Ohio
Posted: Fri Apr 13, 2012 5:40 am Post subject: |
sbclayton wrote: |
Beautiful! Great score, that! Does the Seller have more of these? Oh - also, can these be stacked, end-to-end? I'm thinking engine oil here... |
Here is the place I bought mine from. This is a 12" model, but they say in the ad that they have 24" available.
http://www.ebay.com/itm/12-ALUMINUM-TRANSMISSION-COOLER-DUAL-LINE-TRANS-FINNED-/330506327852
I think you could stack the single line models (inlet on one end - outlet on the other). _________________ -------------------------
91 Vanagon Carat
93 Corrado SLC
Photos: http://picasaweb.google.com/slc.corrado
tencentlife "Sometimes a pooka is a problem and sometimes it's just a pooka" |
Mmartinphd Samba Member
Joined: March 17, 2012 Posts: 42 Location: Newnan, GA
Posted: Sat Apr 14, 2012 6:50 pm Post subject: |
Thanks all! Going with either GoWesty or Smallcar I guess. Definitely going to replace. _________________ ------------------------------
1987 Westy |
madspaniard Samba Member
Posted: Mon Aug 06, 2012 1:16 pm Post subject: |
does anybody have a picture of the Small Car auto tranny cooler installed in their van? I have two stock propane tanks under the van so I want to know if I have enough room for this cooler.
Any reason why I shouldn't buy the Small Car cooler? It is about $170 compared to the $300 cooler options from VanCafe and GoWesty. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
denwood Samba Member
Joined: July 29, 2012 Posts: 1047 Location: Thunder Bay, Ontario, Canada
Posted: Mon Aug 06, 2012 5:04 pm Post subject: |
Just ordered the van-cafe version. My thoughts are that this solution removes two coolant lines, and adds none (oil lines that is). Therefore the KISS rule prevails. I don't winter drive the van. _________________ Cheers,
Dennis Wood
The Grape |
Posted: Mon Aug 06, 2012 7:55 pm Post subject: |
Finished installing my copy of the Go Westy setup.
91 Vanagon Carat
93 Corrado SLC
Posted: Mon Aug 06, 2012 8:26 pm Post subject: |
Super sweet sano install! _________________ Steve - Tampa Bay Area
NavDog, a 91 Carat
Posted: Tue Aug 07, 2012 9:11 am Post subject: |
Ok, decided. Going with VanCafe cooler. It is the only option that retains the stock location, no additional hoses needed and space under the van is becoming precious with all the new mods and extras that are and will be available. I don't need a thermostat in California and the Small Car option seems to stick down a bit based on comments here. _________________ 1991 Westy auto w/ Peloquin TBD
Posted: Tue Sep 11, 2012 6:53 pm Post subject: |
Just finished installed the Van Cafe auto transmission cooler. It's a very well machined piece, eliminating the coolant hoses, and not adding any oil hoses. Therefore this part is a smart addition in one's efforts to create a very reliable traveler IMHO. My conversion has 50% more HP than stock, therefore the transmission gets loaded up pretty good with a full load, trailer out back, kayaks on top, and cruising at 110km/hr.
Next, the engine oil cooler is being replaced with a Mocal 25 row unit with the same objective...lower oil temps (higher oil pressure) and no chance of a cooler failure allowing oil/coolant mixing.
A few points as the cooler does not ship with instructions:
1. You need to support the engine/trans, remove the rear engine/trans mount entirely, and lower the back end about 3 inches to access the two cooler banjo bolts. I raised the entire van up on truck stands to allow easy access. Doing a pile of work at the same time..
2. Clean up the tranny/mount electrical ground while you're in there!! If it's missing...then make sure you replace it. This is a thick braided copper cable grounding the transmission to the body. I'd say this cable is pretty important for efficient starter grounding.
3. The kit has four o-rings. Two go between cooler and transmission in the machined grooves for them. The banjo bolts holding the cooler on have two more o-rings hiding in the bolt heads...they are easy to miss. Replace them with new ones in the kit.
4. The cooler must be mounted so that the "ears" (wider section) are at the top of the cooler, not towards the ground. If you put it on backwards, you'll find your mistake when you try to put the rear engine mount back on! When you remove the stock cooler and coolant hoses, you'll lose a small amount of ATF, and 2-3 liters of coolant. Leave the expansion coolant tank cap on to minimize coolant loss by siphoning.
5. The kit (depending on your variation) may include a coolant hose coupler. I don't suggest using it, but rather blocking off the hoses, or replacing them. Using the hose union just "short circuits" coolant flow between return and supply with no resistance...so will decrease cooling efficiency.
6. Obviously you'll need to add ATF, as well as engine coolant. Then bleed/burp away
Cheers,
Dennis. _________________ Cheers,
Dennis Wood
The Grape |
dubbified Samba Member
Joined: March 03, 2010 Posts: 1406 Location: Redmond, WA
Posted: Tue Sep 11, 2012 7:06 pm Post subject: |
ursaworks wrote: |
gw at cooler here, does NOT use coolant, liked the thermostat and the narrow profile under the van. really easy to install. |
X2, love it.. although I'd like to be able to monitor my oil temps in the tranny, so I am going to be adding a guage.. |
indytriple Samba Member
Joined: April 27, 2009 Posts: 710 Location: Brownsburg, Indiana
Posted: Tue Jan 08, 2013 8:38 am Post subject: |
denwood wrote: |
Just ordered the van-cafe version. My thoughts are that this solution removes two coolant lines, and adds none (oil lines that is). Therefore the KISS rule prevails. I don't winter drive the van. |
X2
I currently have the GW version, and I have been happy with it. However, I'm going to go with the "Van Cafe" heat-sink version after my engine install/tranny rebuild in the interest of simplicity. Also, it is interesting to note that German Transaxle offers this as an option and seems to prefer it FWIW. Their price is also $299 (installed or separate). _________________ "See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com |
Joined: January 03, 2010 Posts: 297 Location: Amesbury, MA
Posted: Fri May 17, 2013 9:12 am Post subject: Poor Go Westy Parts, and Customer service |
I will be going with the Van Cafe kit..
I had installed the go westy cooler, which took very long to arrive, only to have the thermostat assy fail, part was RMA'd a new part was shipped supposedly never to show up.. appears the part is back - ordered.. 3 weeks..
It's all going back.. crappy parts, poor customer service.. nice install though.. not a part or company I can trust, or rely on.. _________________ 2001 eurovn weekender 207k fresh batteries |
Posted: Fri May 17, 2013 3:00 pm Post subject: |
I've heard a few cases of GoWesty cooler kits losing oil thru the hose connections. I'm sure others with these kits have nad no problems.
My VanCafe cooler has given me no problem so far. _________________ 1991 Westy auto w/ Peloquin TBD
Posted: Fri May 17, 2013 5:52 pm Post subject: |
My leak seems to be at the thermostat on the side, the O ring was broken.. that should be remedied tomorrow, but I am not thrilled to do it.. _________________ 2001 eurovn weekender 207k fresh batteries |
Posted: Sat May 18, 2013 10:34 am Post subject: |
O ring replaced... very happy with install.. settled up with Go Westy..
All good, they could save themselves grief with a bit more quality control.. _________________ 2001 eurovn weekender 207k fresh batteries |
rym Samba Member
Joined: August 03, 2013 Posts: 119 Location: vancouver bc
Posted: Sat Aug 17, 2013 10:16 pm Post subject: |
O-rings with the gowesty kit? We're they included or did you go get them after it leaked? Do I need these? My kit certainly did not ship with o-rings and there aren't any in the new hose fittings they provided. It's all just metal on metal.
I am installing it this weekend but got stuck when I realized maybe I should pinch off the coolant hoses but I can't quite reach them with my vice grip+old bike tube pinching contraption. At the same time I wonder how effective the union of the two coolant hoses will be after I (likely) butcher them while trying to pry them off the old cooler. Some have said this is an easy job.. Guess I wasn't properly prepared! |
Posted: Sun Aug 18, 2013 1:38 am Post subject: |
it is a pretty easy job..
the O ring was in my leaky thermostat the cooler uses. if your cooler does not leak, you don't need any O rings.. _________________ 2001 eurovn weekender 207k fresh batteries |
rym Samba Member
Posted: Mon Aug 19, 2013 12:15 pm Post subject: |
Well it finally did go on pretty easily.
The 'tough' part was all me, paranoid of the jack dropping the tranny a little too much and breaking something. took a while dropping the transmission 1/2" at a time and re-checking all its connections to make sure I wasn't breaking anything. But it sure did drop about 6" without straining the accelerator cable.
Only spilled a few oz. of ATF from the banjo bolts, and maybe an oz. of coolant. pretty clean job. Was easier to access the coolant lines for clamping/removal from the cooler by removing the banjo bolts FIRST, and being able to move the cooler around a bit.
Time will tell if there are any leaks, but none so far after a run around the block.. |
SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Fri Nov 11, 2016 10:56 am Post subject: Re: GoWesty vs. Van Cafe AT Cooler (vs. leave it) |
Reviving this thread as I may be about to replace my transaxle.
How cold is cold enough to start worrying about the lack of ATF warming when using the VC cooler vs the GW thermostat controlled unit? What would be the result of driving the van when the ATF is "too cold"?
I typically park the van for winter so it rarely gets driven in temps below 25F.
Thanks _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Fri Nov 11, 2016 2:00 pm Post subject: Re: GoWesty vs. Van Cafe AT Cooler (vs. leave it) |
To a point, cooler ATF fluid generally doesn't hurt anything but parasitic drag. If you start getting to sub-zero temps..let everything (engine, transmission and you) warm a little up first prior to driving off down the road.
Right now I'm using Valvoline Maxlife atf full synthetic..which has excellent cold flow properties and our Vanagon/VW transmissions seem to do very well with it. Readily available anywhere and not too expensive.
Warning though..the Maxfife ATF stinks big time..a very strong odor..don't know why. Don't spill any in your attached garage or you smell it for a few days. |
