Blaubus Samba Member
Posted: Thu Apr 12, 2012 10:56 am Post subject: where to buy compression tester for T4 |
i searched both Ratwell FAQs and compression topics but couldnt find a good source from which to purchase a tester that will work on a type 4 . i have one of those testers that does not screw in and it is also too short to reach thru the tin on cylinders 2 & 4.
also, Ratwell says to use a screw in tester. once i have one- how do I tighten it if there is a hose in the way? a special socket? |
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4207 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Thu Apr 12, 2012 11:03 am Post subject: |
I got mine cheap at Princess Auto; I think the equivalent for you would be Harbor Freight. Easy peasy; it just twists in a like a spark plug. Give it a little cinch, and away you go. Mine came with a couple of standard fittings, one of which fit the Type 4 no problem. _________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
ron3865 Samba Member
Posted: Thu Apr 12, 2012 11:28 am Post subject: |
The one I have works great. It has a 14" hose with a plug fitting on one end and a quick disconnect for the gauge on the other end. Any good auto parts house ought to have it. It only needs to be hand tightened and it's pretty easy to thread in through the tins. |
Posted: Thu Apr 12, 2012 11:51 am Post subject: Re: where to buy compression tester for T4 |
dansvans wrote: |
Your tester is probably made using 1/8 in pipe. Just get a suitably long nipple plus a coupling and go at it. |
AB westy nut Samba Member
Joined: June 01, 2010 Posts: 1124 Location: Calgary, Alberta
Posted: Thu Apr 12, 2012 12:17 pm Post subject: |
Any standard thread-in tester will work. They typically have a rubber o-ring at the base that provides a seal just with hand tightening. _________________ 1963 Ruby Red 356 Cabriolet
1976 Sage Green Westfalia Deluxe |
Chris_914 Samba Member
Joined: September 16, 2011 Posts: 344 Location: Las Vegas
chimneyfish Samba Member
Joined: July 28, 2009 Posts: 881 Location: United Kingdom
Posted: Thu Apr 12, 2012 2:31 pm Post subject: |
This is mine, easy to use and a good length on the brass screw in piece to easily reach into the deeper recessed spark plug holes, GB £20 when you shop around, which is about US $30 to $35:
http://www.gunson.co.uk/item.aspx?cat=666&item=1826 _________________ 1965 Type 1 Deluxe (1200cc)
1976 Type 2 T2b Microbus L (1800cc Type 4)
Previously...
1972 T2 Camper (Devon), 1988 Golf, 1972 Type 1, 1984 Polo, 1972 T2 Camper (Danbury) |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
Posted: Thu Apr 12, 2012 2:55 pm Post subject: |
I have the harbor Frieght unit works fine. _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3305 Location: Australia
Posted: Thu Apr 12, 2012 3:17 pm Post subject: |
Mine came with a size adaptor, a solid tube with the jam fit rubber thing, and a rubber hose with a brass screw fit and O ring. Paid about $50 which was is about the going rate here. Did a type 4 many times without issue. Well, mostly. The hose has a slight curve but that's easy enough to deal with. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Tcash Samba Member
Posted: Thu Apr 12, 2012 3:51 pm Post subject: |
Tighten them by hand. No special socket required. Good Luck |
Posted: Thu Apr 12, 2012 3:53 pm Post subject: |
Tcash wrote: |
That's it! Just screw it in with the hose. You don't need to really wrench on it because the thread and O ring work just fine for the purposes of compression testing. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Posted: Sun Apr 15, 2012 9:02 am Post subject: |
awesome, thanks. off to sears i go... they have an Actron tester for 30 bucks |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51119 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Apr 15, 2012 10:06 am Post subject: |
I have had issues with the screw in testers with the flexible hose, if the hose develops a curve from storage it's nearly impossible to get started in #2 and #4 on a type 4. A steel extension made from an old spark plug and a length of tube is one fix, or wrap the hose with aluminum tape tape to give it a stiffy I did have one that had the fitting get loose in the end of the hose, that was a challenge to unscrew from deep down in the tin You don't have to torque it up much, just enough to seal the O ring gasket but that one got stuck and made a 10 minute job much longer _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Apr 15, 2012 4:15 pm Post subject: |
busdaddy wrote: |
I have had issues with the screw in testers with the flexible hose, if the hose develops a curve from storage it's nearly impossible to get started in #2 and #4 on a type 4. A steel extension made from an old spark plug and a length of tube is one fix, or wrap the hose with aluminum tape tape to give it a stiffy I did have one that had the fitting get loose in the end of the hose, that was a challenge to unscrew from deep down in the tin You don't have to torque it up much, just enough to seal the O ring gasket but that one got stuck and made a 10 minute job much longer |
My tester's hose has always had a curve because of the way it was packaged. I get it in just fine. There's a knack to it but I can do it without issue. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
