baxsie Samba Member
Joined: August 09, 2005 Posts: 606 Location: Eastern Washington State
Posted: Sat May 26, 2012 9:57 pm Post subject: |
So my son and I decided to see if we could get the rusty red bug running. Here are some quick videos of the fun:
We cleaned the plugs, distributor cap, rotor, and replaced two leaking sections of fuel line, the air filter, the points and condenser.
I think the coil was the only thing really wrong. It actually started and ran for about 30 seconds on the old coil, then would not start again. The spark looked really weak:
The old coil is a "Lucas" "Made in England", with a VW emblem on the end. Something had worn through the can, and what appeared to be oil was leaking out.
We swapped another coil and then it starts OK. Runs rough as heck, but I just wanted to see if it would run at all, and I do not want to put the effort of tuning it up.
Other topic: We have been trying to figure out some nice solution for mirrors. We went to the local "Pull And Save" junkyard. For $7 each, I picked up 4 power mirrors (two matching pairs) from two Honda Accords:
It would take some very special custom work to modify the mirror and the door to work together seamlessly. The black one is smaller and a bit more square, the red one larger but rounder. I think in any case we would paint the mirror to match the body. We shall see.
baxsie Samba Member
Posted: Sun May 27, 2012 10:21 am Post subject: Could this engine be the original for this chassis? |
Is there a way to tell if the number of the engine is the original for this chassis? Does that mean anything to have a matching set?
The engine number is : K058276
The VIN is: 1332416312
Here are pics of the number plates.
baxsie Samba Member
Posted: Mon May 28, 2012 6:46 pm Post subject: |
OK, it turns out I missed the first number of the engine. And I forgot the door sticker. Here they are:
baxsie Samba Member
Posted: Mon May 28, 2012 7:48 pm Post subject: |
Back on the mirror investigation. We disassembled the mirror from the base:
It looks like we could machine a bracket that mates with the mirror (as highlighted here), and bolts to the original VW mounting hole. A hollow bolt would let the wires pass into the door:
baxsie Samba Member
Posted: Wed May 30, 2012 8:57 pm Post subject: 1974 Super Beetle Foam Rust Doom |
Not much progress on the car. The "remodel the barn into a shop" is progressing well.
Back story: For another job we had a fairly beefy DeWalt 4200PSI, 4GPM pressure washer hooked up and dangerously near the car. Boys will be boys, and soon the pressure washer and car met.
I knew that on the yellow chassis, there was some trouble on the right rear vent. We could see some cracks and poor bondo.
Today I got to see how bad the trouble is.
The pressure washer with its turbo tip made short work of the cruddy body work:
The water gets under the patch and lifts it right off. Frankly I think this says more about the patch than the pressure washer. All that was removed in the above photo was done by the pressure washer.
A little prying with the screwdriver brought the patch off. Here is the back side:
The pain is obvious. The hole goes down into the fender well and you can see right into the interior. Ugggh:
Well. I guess that is why you take them apart |
baxsie Samba Member
Posted: Tue Jul 03, 2012 2:41 pm Post subject: Maybe now it is a 1975 Super Beetle project? |
We are still working on making a shop in the barn, so not so much actual VW work happening.
We went ahead and picked up the white 1975:
We now have a red 1973, yellow 1974 and this white 1975. Sigh.
What intrigued me about the 1975:
* sunroof
* rack-and-pinion steering
* 4 (apparently good) bumper struts
* clean metal in back (do not know about the foam rust of death)
* had factory fuel injection, so there are already two lines from the tank to the engine
* probably was a green LaGrande Bug
* interior in bad shape, but not the worst, and lots of parts there.
So now we most probably have one of everything, and 3 of many things.
Lots of progress made on the barn/shop project, and lots more to go. But when it is done it should be a nice place to work.
In the meantime, I think we will use the sand blaster to take the finish off the foam areas of the white 75 and red 73 to see if either of those is usable without major metal work. |
TjdTaylor Samba Member
Joined: July 04, 2011 Posts: 1727 Location: Niagara Falls, Ontario
Posted: Tue Jul 03, 2012 3:10 pm Post subject: |
That bondo is THICK _________________ 1974 SuperBeetle Build
Beetle Bums VW Club Member
Jamies74sb wrote: |
I can't see myself cutting up my super beetle . Maybe a oval or 61 or so with the small windows |
EXJAY Samba Member
Joined: October 04, 2009 Posts: 1109 Location: Myrtle Beach, SC
Posted: Tue Jul 03, 2012 4:51 pm Post subject: |
no fender beading? _________________ EXJAY
'74 Superbeetle (Family owned since new)
'73 181 Thing (sold) |
dubllyou Samba Member
Joined: May 24, 2012 Posts: 1251 Location: Jack & Cee Motors
Posted: Tue Jul 03, 2012 5:03 pm Post subject: |
The engine numbers don't match the VIN numbers. The VIN numbers on the dash plaque, plaque behind the spare, sticker on door frame and stamped on the tunnel under the back seat should all match and should match the title (of course). You would have to apply for your car's "birth certificate" to see if the engine is original to the car. The engines size and year can be deciphered here: http://www.thesamba.com/vw/archives/info/engine_letters.php _________________ Two wrongs don't make a right...
three lefts do.
Wade
vwo60 wrote: |
You cannot polish a turd, but you can roll it in glitter. |
baxsie Samba Member
Posted: Tue Jul 03, 2012 5:57 pm Post subject: |
EXJAY wrote: |
no fender beading? |
There is fender beading on the white one. Just painted over. On the yeller one it had beading on 3 fenders but not the 4th.
Stay tuned, should have some good videos in a bit |
baxsie Samba Member
Posted: Tue Jul 03, 2012 6:48 pm Post subject: |
I wanted to find out right away what was in store for the "foam of death" rust areas.
Here is step one, removing the cruddy white paint by using a pressure washer:
Then the sand blaster, video in three parts:
The rust is certainly not as bad as the yeller one. But there is some perforation:
A-Step-Towards Samba Member
Joined: October 03, 2010 Posts: 145 Location: Albany,Oregon
Posted: Wed Jul 04, 2012 12:23 am Post subject: |
The white one has the sport rims, if there in good shape there worth some money maybe 150-200$ for a set.
If you were close to me id be trying to buy some parts off you. _________________ 1961 Vw Bug @61beetle IG |
Posted: Wed Jul 04, 2012 5:35 am Post subject: |
wow screw a sander for next time, ima just bust out the pressure washer. It looks like the pressure washer does a better job than the blaster Was that og paint or just a cruddy paint job from the past? _________________ 1974 SuperBeetle Build
Jamies74sb wrote: |
baxsie Samba Member
Posted: Wed Jul 04, 2012 7:41 am Post subject: |
TjdTaylor wrote: |
wow screw a sander for next time . . . Was that og paint or just a cruddy paint job from the past? |
Where the OG paint is still in good shape, the pressure washer cannot touch it. The pressure washer does do a great job of finding any paint or body work that is not in great shape, getting under it and blasting it away. Make no mistake, this is a serious pressure washer, and the rotary tip really concentrates the power. That tip will blast right through wood at close range.
The white paint is something seriously low quality. I almost wonder if it is house paint. It looks pretty smooth, but is spider cracked all over, and you have seen in the video how well it adheres.
A bit of a mystery is that the body work under the white paint, the de-chrome job, the small damage repair we have seen so far, do not seem to be that bad of quality. Seems a shame that a person would do good work on that stuff then shoot some goofy bad paint on it. Maybe it was a bad batch, or mixed wrong or something. |
baxsie Samba Member
Posted: Wed Jul 04, 2012 7:49 am Post subject: |
A-Step-Towards wrote: |
The white one has the sport rims, if there in good shape there worth some money maybe 150-200$ for a set. . . |
Out of the three cars and now 12 wheels I think I have:
3 4.5x15" sport rims
2 5.5x15" sport rims (raised rim on square holes)
3 chrome "standard" rims
4 painted "standard" rims
I was really hoping to have enough of the chromes or sport rims to make a set of winter wheels.
. . . If you were close to me id be trying to buy some parts off you. |
I get down to Portland OR and Seaside OR on a regular basis (leaving for a trip in ~1.5 weeks) What do you need, maybe we can work something out. |
baxsie Samba Member
Posted: Wed Jul 04, 2012 9:15 pm Post subject: |
We decided to look at the rest of the the likely rust spots on the white 1975 super beetle. Of course there is under-body stuff to explore too, but that will wait.
The right side front quarter is perfect
The left side front quarter had some pretty substantial bondo, with rust forming under it. We removed all the bondo to make sure the rust is just surface and not all the way through:
The repair job included some nice brazing work on the body seam. Oddly the fix did not continue upward, where the seam is also damaged:
Is there factory brazing on the seam here?
baxsie Samba Member
Posted: Wed Jul 04, 2012 9:33 pm Post subject: |
For completeness, we also removed the paint on these same areas on the rusted red 1973 super beetle donor car. This car has serious lower rust -- both heater channels are completely open, and every fender bolt area is rusty. OK, that is pretty normal for a bug, right? Here are the weird things. The battery area appears to be original and completely solid. And the rear foam of death areas appears to have no rust, at least on the side.
The right side front quarter. Rust is bad, centered around fender holes:
Close up of perforations:
The left side front quarter. Rust is bad, centered around fender holes:
The right side foam of death area. The "foam" area is clean (or at least not all the way through). The rust that is there appears to be growing from the fender holes:
The left side foam of death area. The "foam" area is clean (or at least not all the way through). The rust that is there appears to be growing from the fender holes:
There is nasty perforated rust to the left of the rear window, about 3/4 of the way down. Is this from the foam?:
baxsie Samba Member
Posted: Thu Jul 12, 2012 7:38 pm Post subject: |
We finally got the barn/shop job far enough that we could pull the yeller bug into the main bay and start disassembly:
This is the first time for serious mechanic work for my son. Just trying to let him figure it out as much as possible, and help only when he is stuck or frustrated. |
beetlenut Samba Member
Posted: Fri Jul 13, 2012 6:03 am Post subject: Re: Maybe now it is a 1975 Super Beetle project? |
baxsie wrote: |
We went ahead and picked up the white 1975:...
Can you do me a favor and look at that FI tank and tell me where the two lines come out of that tank? I have a 74 super with a carb tank, and I'm converting to FI, so I need another fuel line inlet/outlet in my tank. Just wondering where to put it? I also might just look for an FI tank.
Thanks, _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
baxsie Samba Member
Posted: Fri Jul 13, 2012 7:00 am Post subject: |
beetlenut Yes, I'd be happy to look, post pics, etc. Right now it is at the radiator shop getting cleaned and coated. When it gets back, I'll post some pictures of the differences between it and the non-FI one. |
