Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Mon Feb 25, 2019 5:45 am Post subject: Re: Kick Azz 1975 LaGrande Super Rebuild |
I've never messed with a Mega squirt system before, so I may be a bit off base here, but I had an idea. The FI system has an IAT sensor correct? Is it possible to write a line of code into the system that when the IAT is above a certain ambient temp, when the key is shut off it will continue to flow fuel through the system for a set amount of time? If you could trigger off the IAT that would prevent unnecessary fuel circulation in conditions where the vapor lock issue would normally occur. |
baxsie Samba Member
Joined: August 09, 2005 Posts: 606 Location: Eastern Washington State
Posted: Mon Feb 25, 2019 10:07 am Post subject: Re: Kick Azz 1975 LaGrande Super Rebuild |
Bashr52 wrote: |
Yes, what you propose would be a reasonable approach. A lot may have changed in the meantime. Maybe the MegaSquirt team has added some option like this.
At the time, I looked into it and found that the 3-second prime pulse was hard coded. No way to change it in the normal configuration. I would have had to download the tools and code and recompiled it on my own to make the change.
Later, it occurred to me that there is really no reason to shut the pump down. If you are driving all day, it is running all day anyway. So what we might do is just wire the pump to come on with the ignition and stay on. There is not normally any reason to be in that state of having the ignition on and the engine off--the pump running can just be a reminder to switch the key back to the accessory position or finish starting the car. _________________ 1975 LaGrande Super Beetle Build Log / Farm boy hinge pin puller / Farm Boy Chassis Rotisserie
"I'm not getting older, I'm getting bitter." |
TK-CS Samba Member
Joined: April 15, 2019 Posts: 279 Location: D - Deutschland
Posted: Mon May 06, 2019 6:26 am Post subject: Re: Kick Azz 1975 LaGrande Super Rebuild |
baxsie wrote: |
Later, it occurred to me that there is really no reason to shut the pump down. |
It is a safety feature that the fuel pump is switched off after a few seconds when the engine stalls. This is to prevent spilling fuel over hot engine parts if the fuel lines were ripped off by an accident and the driver is not able to switch off the ignition any more.
There were some wc VWs (i. e. Passat B3, Corrado) that featured an fuel pump after run to minimized hot start problems. The after run relais monitored temperature in engine compartment and fuel pressure (to make sure the fuel system is not punctured).
In the water cooled application additionally the radiator fan is switched on to remove hot air from the engine compartment.
Of course there also is a timeout to prevent discharging the battery.
Perhaps this relais would help with your hot engine issue. |
baxsie Samba Member
Posted: Sun Nov 10, 2019 9:10 pm Post subject: KIck-AZZ Images are (mostly) back. |
We had a little complication with the baxsie image server. A "simple" upgrade of the OS then a reboot and . . . it would not come back up
It looks like a combination of odd hardware ("fake RAID" or "software RAID"), combined with a non-standard OS installation and then errors trying to do the upgrade doomed. it.
Now we have a new server in place. Dual Xeons, 128GB memory, 256GB OS SSD, 4TB of SSD for the images, and a 5TB backup drive with scripts to backup the OS and image drive.
So in theory . . . all should be good for a long time. If you notice any issues, please PM me and I'll try to sort it out. _________________ 1975 LaGrande Super Beetle Build Log / Farm boy hinge pin puller / Farm Boy Chassis Rotisserie
tzepesh Samba Member
Posted: Tue Nov 12, 2019 12:16 am Post subject: Re: Kick Azz 1975 LaGrande Super Rebuild |
I am glad the pics are back! I followed this topic closely, because the detailed pictures are really useful in my rebuild. Especially on metal work. Congratulations on your work, you got a very solid and beautiful car in the en. _________________ '74 1303S, L98B Viperngrun (extra glitter), German Look
'64 1200, Sea Blue, under restoration |
amaskedman Samba Member
Posted: Tue Sep 08, 2020 3:35 pm Post subject: |
perhaps those nubs on the fender nut are supposed to be drilled out so you can tack weld it, or is it spot weld?? I have to replace a few of mine and that is what I was thinking. |
baxsie Samba Member
fabricator john Samba Member
Joined: October 09, 2009 Posts: 510 Location: manassas va. now Venice Fl.
Posted: Wed Oct 07, 2020 5:16 pm Post subject: Re: Kick Azz 1975 LaGrande Super Rebuild |
use indian head shellac on tank gaskets allways seals ive allways used it . been building hot rods and doing restorations well close to 30yrs ,, that stuff works on all of em filler tube o rings too , by the way i absolutely love your a/c compressor bracket,,, fabricator john |
pharos Samba Member
Posted: Mon Feb 01, 2021 2:42 am Post subject: Re: Powered rear window pop-out actuators |
baxsie wrote: |
Way back when, we talked about putting powered rear window pop-out actuators in. Today is that day.
The actuator is one of several I gathered up from various minivans at the local Pull-And-Save. I think it was from a Nissan mini van.
Inital placement and cutting for the actuator:
Here is the start of the hole. It extends into the back side of the fresh air vent:
More careful & minimal cutting, clearance for the actuator motor. Also more of the cursed foam of death:
Another test fit:
We wanted to make a box or "bucket" (think headlight bucket) to keep the inside inside and the outside outside, and preserve the mechanical integrity. Start with a paper prototype:
Move that to some OG metal:
Sanity check before foldiong the box up:
Fold up the metal box, trim cut file, etc:
Then we went back to the car to fiddle the hole until it accepts the box, tryiong to keep the gaps to a minimum:
Here is what it looks like from the outside, with the inner metal of the car clearanced around the box:
Once the box is sitting at the correct depth, mark it for folding:
By now, the paper prototype is a distant memory, and the metal prototype has several fiddly errors. Plus we need right and left copies of the box. So we flattened the metal prototype box, traced and cut two copies, fixing the errors as we went:
Fold up the two new boxes:
Now we can fold out the mounting flanges trim them and another test fit:
A couple more views from outside:
The passenger side went much faster . . . not problem free, but knowing the dimenstions and positions helps:
Here are the finished boxes. We welded studs in to mount the actuators. We welded up the corners, ground the welds down a bit, smoothed things out and glass beaded them:
Here is a shot of the test installation. We used screws to hold it until the body folks can fix the rust in these areas. Later the plan is to weld the box into the car to assure mechanical/structural integrity.
So . . . does it work? Brilliantly! Here is a video of operation:
The plan is to have the upholstery folks pad and cover the actuator, ideally there would be a lined hole where the shaft exits, the rest would be covered by the upholstery. If needed we can build a top cover out of metal and screw that fast. |
Hi,
Please share the link to buy the same electric motor
Dose it come for right and left?
Is there is another model that can open the popup window wider? _________________ http://www.facebook.com/groups/vwbug/ |
baxsie Samba Member
baxsie Samba Member
Posted: Tue Oct 26, 2021 9:51 am Post subject: Question about mounting the Wolfsburg Crest on the Hood |
I got this question via a PM, thought I would share it here for all.
> Hey there, was wondering if you could tell me how you modded a late hood to
> mount the crest? I can’t seem to find more info on this, not even how the craft
> normally mounts (two tabs thru the hood, or a single stud). If a stud where did
> you get one that would clear the emblem? Thanks!
There is the crest itself, which includes mounting tabs (pic from a random eBay auction)ref:
These go through a mounting plate, and into slots in the hood. I cut the slots using a Dremel with a small carbide bit. The mounting plate covers them, so they can have a little slop. Here is a pic of what the factory mounting holes look like:
After the tabs of the crest pass through the mounting plate and through the hood, they are supposed to pass through these little rubber pads:
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113853611
I did not know that then so I did not use any.
Properly, the trim should meet with the crest like this:
I needed to shorten the hood trim (because of the badge added at the top) so I went with a simple straight cut of the wider stainless trim:
If you search "crest" at Wolfsburg West, there are two options.
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113853621AGR
https://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113853621BGR
And many more after that:
Many crest photos are mixed in this (long) post: https://www.thesamba.com/vw/forum/viewtopic.php?p=8501645#8501645
Here is another thread that has more information on adding a crest to a newer bug:
https://www.thesamba.com/vw/forum/viewtopic.php?p=9417185 _________________ 1975 LaGrande Super Beetle Build Log / Farm boy hinge pin puller / Farm Boy Chassis Rotisserie
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1294 Location: Modesto, CA
Posted: Tue Oct 26, 2021 2:23 pm Post subject: Re: Kick Azz 1975 LaGrande Super Rebuild |
Braxie
Such an impressive build! I can't believe it's already been 2 years since you completed it. How's the car holding up? Engine?
Two things I thought were brilliant (among MANY) were the powered pop outs and the cruise control (i.e. I like how the cruise control lever is very much like cruise control on a Subaru)
H2OSB _________________ (o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. |
baxsie Samba Member
Posted: Tue Oct 26, 2021 5:12 pm Post subject: Re: Kick Azz 1975 LaGrande Super Rebuild |
H2OSB wrote: |
. . . How's the car holding up? Engine? . . . . |
Thanks for the kind words.
My son finished college, moved out.
We went to change the oil so he could take it to his new home and found that one intake manifold was loose. We think that the stud was too short and pulled the threads in the head out Those massive manifolds, ITB, and air cleaners put a lot of stress on those studs.
So we need to drop the engine, fix the threads in the head or maybe just use a bottoming tap and a longer stud then put the engine back in.
Other than that it has been pretty reliable.
There is an issue with vapor lock if you shut it off when it is very hot -- we know how to get around that now. Just have to keep toggling the key to run the fuel pump until the lines cool. _________________ 1975 LaGrande Super Beetle Build Log / Farm boy hinge pin puller / Farm Boy Chassis Rotisserie
