crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9939 Location: Orbiting San Diego
Posted: Fri Nov 22, 2019 3:18 pm Post subject: Re: Can you HEAR your low speed radiator fan? |
Sorry, you have it all wrong. Does your manual have page 97.200?
Mark |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Fri Nov 22, 2019 3:21 pm Post subject: Re: Can you HEAR your low speed radiator fan? |
#3 gets the load. #5 goes to radiator fan. #1 and #2 Are power and ground to energize the relay. If you are power at the fan switch, that goes to one pin and the other pin is ground. If you wired the fan switch to complete a ground it’s the opposite. Ground comes from switch and power is bat +. M
When adding relays I wire them to work off of switched grounds. Makes wiring much easier. I would also suggest you tube. Your questions reflect a lack of understanding how relays, switches, and consumers operate. Give a man a fish feed him for the night. Teach a man to fish and he will feed himself for life. _________________ ☮️ |
Zephyr_shreds Samba Member
Joined: July 15, 2019 Posts: 185 Location: Bakersfield
Posted: Fri Nov 22, 2019 6:52 pm Post subject: Re: Can you HEAR your low speed radiator fan? |
Like this? One day hopefully I’ll be a good fisher:) thanks to you guys.
beach_creature Samba Member
Posted: Fri Nov 22, 2019 7:22 pm Post subject: Re: Can you HEAR your low speed radiator fan? |
They should have their own grounds and don’t connect in a loop. It’s ok if they share the same ground location. But the ground location for the rad fan should be clean with good connection to the van body.
The diagram looks good other words.
_________________ 84 Westy
1.9TD AAZ
5spd manual with Locking Peloquin TBD |
