ballbag Samba Member
Joined: January 01, 2006 Posts: 204 Location: Cheshire, UK
Posted: Sat Apr 21, 2012 2:43 pm Post subject: Hard/heavy steering |
Right then I have fitted all new balljoints, but my steering is really heavy, could anyone shed any light on this? _________________ I never learned that much at school, but i've taught ladies plenty!!
Bobnotch Samba Member
Posted: Sat Apr 21, 2012 4:51 pm Post subject: |
You probably need to add some caster back into it (those big rubber bushes that wrap around the beam). This is one of the things about lowering a T-3 using the stock beam, you take away caster. Caster helps the car track in a straight line, and it also makes it easier to turn. It's also possible that you need to adjust the camber. That can be done at the ball joints. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vlad01 Samba Member
Joined: October 27, 2010 Posts: 3069 Location: Australia
Posted: Sat Apr 21, 2012 5:46 pm Post subject: |
actually more caster makes it heavier but better stability and handling.
less caster makes it light but all twitchy and unstable.
I suggest raising it is its too low, check the tierod ends, tire pressure, steering box adjustments, check ball joints.
Also you mention narrowed arms? that could be exactly it!
congratulation! you have ruined your steering geometry |
