Seat Heaters
Classicvibe
Classicvibe is offline
PostPosted: Tue Oct 11, 2011 10:10 am    Post subject: Seat Heaters Reply with quote
I am ripping everything down this week, and I have been researching seat heaters. If anyone has experience with them, especially in a Vanagon, please share you experience. I am looking at:
http://www.rostra.com/products/comfortheat-automotive-seat-heater-by-rostra.html
http://www.heatedseatkits.com/heatedseatkits/index.html
http://www.checkcorp.com/seat-heater/seat-heaters.asp
I have not torn into my seats yet, so I would like to know that the seat heaters will actually operate and install properly. For what I can see, everything looks like a go, and a big win for an early ski season yo!
I am thinking I am going to get rid of the cloth as well, and perhaps find a cool perforated leather or the like.
On a mission, the destination is just an excuse.
Syncro Solstice 2022...see you there!
1986.5 Wolfsburg Syncro Westfalia Poptop Weekender Transporter
dubbified
dubbified is offline
PostPosted: Tue Oct 11, 2011 10:28 am    Post subject: Reply with quote
That first link looks real good.
Watching this post to see what you use!
Hope you take pics of your progress, install. Smile
r39o
Samba Polizei
r39o is offline
The factory had seat heaters too.
I noticed that all the parts for the VW system are sort of the same.
I noticed that most of the aftermarket stuff you showed looks a lot like the VW stuff.
Coincidence?
I located most of my heated seat stuff out of other VWs.
Just not the pads, yet. I have Recaro seats I want to put in and I can buy VW heated inserts from VW, but at a prcie. Factory pads for the factory seats may or may not still be available.
NOTE: Vanagons in Canada could have a heated driver seat. The control is hard and expensive to find. Plus it was for one seat only. You can make a later controller work just fine.
FYI: The heated VW heated seat parts are hard to find, but do integrate nicely, into the van.
EDIT: This is a LOW priority thing for me since we live in San Diego; who needs that, right? But, it is a nice thing to have, you just have to work at it for the once a year or so we actually might want it.
danfromsyr
danfromsyr is offline
PostPosted: Tue Oct 11, 2011 10:36 am    Post subject: Reply with quote
don't forget you can (should) install seat heaters in the back bench too.
not just for passanger comfort or while chilling in the mobile chalet..
but to preheat the beadding too Wink
Abscate wrote:
PDXWesty
PDXWesty is offline
PostPosted: Tue Oct 11, 2011 10:43 am    Post subject: Reply with quote
Here's two other posts with info.
http://www.thesamba.com/vw/forum/viewtopic.php?t=267239
http://www.thesamba.com/vw/forum/viewtopic.php?t=393280
89 Westy 2.1 Auto
big swifty
Location: Formally in Republic of VT; now in Hollywood, FL
big swifty is offline
PostPosted: Tue Oct 11, 2011 4:39 pm    Post subject: Reply with quote
I have the Check brand in my Jetta and in The van. Thumbs up!
Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. No mods. Yet.
[1991 Jetta coupe TD. Giles Superpump. Custom tall 5 speed. SOLD
2doorsdown
2doorsdown is offline
PostPosted: Tue Oct 11, 2011 6:15 pm    Post subject: Reply with quote
I don't see VW listed on the Check site. Do you remember what the kit ran you and did you get the DIY? Thanks again. Pre Heating the bed sounds like I'll make it on the wifes good side with this mod Wink
Syncroincity
Syncroincity is offline
PostPosted: Wed Oct 12, 2011 5:47 pm    Post subject: Reply with quote
I installed the heatedseatkits set in my Subaru under leather, worked great, install is a breeze, they provide very nice wiring harnesses, all modular with plugs, all you do is provide +12v and a ground, and find a place to mount the switches.
Take the opportunity to machine wash or dry-clean your upholstery while it's off. Smile
'86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight=
insyncro
Banned
insyncro is offline
PostPosted: Wed Oct 12, 2011 5:53 pm    Post subject: Reply with quote
I have installed carbon fiber heating elements to my stock Vanagon seats.
I wired them to the relay and control unit found in Canadian Syncros and Tristars.
Worked like a charm.
Really makes winter driving comfortable.
big swifty
PostPosted: Wed Oct 12, 2011 6:07 pm    Post subject: Reply with quote
Lux-51 DIY
Evan
a914622
a914622 is offline
PostPosted: Wed Oct 12, 2011 8:00 pm    Post subject: Reply with quote
I just scored the stock top plastic part that holds the seat/heater switch. (only a buck fifty) you got to love the wrecking yard!!
Post pics on the way you go! I have a set of eurovan seats waiting to go in after a good wash and heaters.
jcl
87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru
r39o
Samba Polizei
r39o is offline
PostPosted: Wed Oct 12, 2011 10:06 pm    Post subject: Reply with quote
So those heating elements have a thermistor that works with the "relays?"
Which brand and model of element did you use?
r39o
Samba Polizei
r39o is offline
PostPosted: Sun Oct 16, 2011 12:24 pm    Post subject: Reply with quote
I "discovered" our new Jetta V has heated seats. I never looked close before. The other day I drove it and it got cool in the evening. While playing with the controls (worse than a Vanagon!) I found the push button control in the middle of the hot / cold (left) and the vent control (right.) I noticed I only need two positions. Warm and Hot (and Off.)
I mention this as I may not really need to integrate the variable factory system which uses a thermistor to keep temperature at what you set via the (EXPENSIVE) controller.
In other words an after market setup may well be all I really need. (I won't use it a whole lot here in So Cal anyways.)
Any input?
insyncro
Banned
insyncro is offline
PostPosted: Sun Oct 16, 2011 1:38 pm    Post subject: Reply with quote
Yes and well above most budgets around here.
They are available on eBay.de
r39o
Samba Polizei
r39o is offline
PostPosted: Sun Oct 16, 2011 2:49 pm    Post subject: Reply with quote
The VW factory elements for my Recaros are about $90 each which is not too bad, I think compared to what the aftermarket ones cost. I can get the factory ones wholesale in the US last time I checked.
But, the control and "relays" are quite expensive to purchase new, but thankfully you can get them out of other model VWs used. Not like they are falling off trees, but you can get them.
Knowing myself I just put them on high or low. The variable feature of the stock VW is sort of lost on me.
BUT, I do have everything to do the job now and forgot to order the pads until this thread came up.
creative native Premium Member
creative native is offline
PostPosted: Sat Dec 03, 2011 2:11 pm    Post subject: Reply with quote
At this point, I believe I have all components to install the heated seat/seats in my 1986 Westfalia. I have the VW rheostat, raised upper column cover in brown, #59 heated seat relay. I believe all I need now are the heated pad elements and the wiring harness. Does anybody know where I can find these or the VW part numbers? I've been told that the heated seat wiring harness from an early 90's Jetta MK is the same...can anybody here verify that? If I should find the wiring harness, but not the heated pads, does anybody here know if aftermarket heated pads will work? I will appreciate any information and help!
Jaraqui
Jaraqui is offline
PostPosted: Sat Dec 22, 2012 5:27 pm    Post subject: r39o Reply with quote
Digging through the archives, I saw this conversation you had with 'insyncro' about seat heaters.
I'm about to re-assemble my driver's seat after a rebuild and cleaning, and have a complete OEM heated seat setup (rheostat, column shroud, harness, '59' controller. I bought aftermarket heating elements.
According to Bentley, there's a temp sensor in the OEM seat element that plugs into the 6-pin under seat connector. The aftermarket elements I have only have power and ground leads.
Did you figure out whether you needed thermistor-controlled heating elements to use the VW harness? I couldn't determine whether the temp sensor is needed from Insyncro's comments.
Thanks for any guidance, and Happy Holidays.
David K
Moglet
'90 Westy Syncro, EJ-22, other bell's & whistles
268K miles
Faithful companion since 1996
Next stop, Ushuaia?
plummerdesign
plummerdesign is offline
PostPosted: Sun Dec 30, 2012 10:15 pm    Post subject: Reply with quote
Seat heaters are on my list. On the Westy, both seats rotate. So what is the best way to keep from damaging the wiring leads when turning the seats?
Cheers,
Jeffery
(Westfalia travel/camping videos at YouTube link below)
It is old and green and it makes me grin.
1984 Westfalia 1.9
r39o
Samba Polizei
r39o is offline
PostPosted: Mon Dec 31, 2012 11:26 am    Post subject: Reply with quote
Cheers,
Jeffery
I have swivels, heaters and Recaro seats waiting to be installed.
I am thinking of putting a hole in the middle of the swivels to allow the cable to go through, if it is possible.
Otherwise you need a long enough service loop and the cable tied away so it does not get caught. In this case, I do not know what a good routing is.
This is a topic I sort of forgot about....
[email protected]
john@aircooled.net is offline
PostPosted: Mon Dec 31, 2012 11:28 am    Post subject: Reply with quote
I am doing this soon, and was going to drill a hole in the center of the swivel with a grommet on each piece of metal it goes through. Not sure how many pieces we have to go through yet or if the middle is an option at all.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
