I need suggestions on mounting window insulation while camping
pinetreeporsche
pinetreeporsche is offline
PostPosted: Fri Apr 01, 2016 1:51 pm    Post subject: I need suggestions on mounting window insulation while camping Reply with quote
(I did a bit of a search but couldn't find this topic, although I'm sure it's already somewhere on the site.) SO: I want winter insulation, plus the ability to put panels up in the windows facing the sun while in camp to limit summer sunshine. Questions come up: I've fixed on the 1/4 in. thick silver-surfaced Prodex that comes in rolls. First Q: is it too 'floppy'- do I need something more rigid? Either way, do I cut the insulation to exactly fit the window glass itself, or an extra rim all the way around for the attachment (and how wide, if so)? This leads to the big Q, on the actual attachment mechanism. I think I've seen a reference to magnets, but about half the windows set in to 'upholstered' metal openings-- that is, framing openings covered with a layer of plasticized cloth. PLUS, I think it's most important that the whole lower edge of the insulation sheets be really close to the frame, so a current of cold air can't slide down, bringing in cold from the window surfaces. Do I glue strips of flexible magnetized plastic to the lower (or to all) the edges? Are super-magnets required where the window frame is covered with the upholstery? -Thanks for offerings of your experiences- both successful results and things to avoid. -C H
kourt
kourt is offline
PostPosted: Fri Apr 01, 2016 2:02 pm    Post subject: Re: I need suggestions on mounting window insulation while camping Reply with quote
Howdy,
Before I bought the Just Kampers Thermomat kit, I used Reflectix panels cut to fit my window openings, with rare earth magnets to hold them at the metal window frames. If you have curtains in your van those curtains can also help hold the panels in place.
These radiant barrier products do have a profound effect on keeping heat out or heat in the van, depending on how you use them.
It is important to seal up that bottom edge where the mat meets the window frame so that cold air does not just fall down the glass face and into your cabin.
The Just Kampers mats work well most of the time--but I have to admit the suction cups don't perform well in the winter. That's when having nice tight curtains can help hold things to the glass.
kourt
Tom Powell
Tom Powell is offline
PostPosted: Fri Apr 01, 2016 3:19 pm    Post subject: Re: I need suggestions on mounting window insulation while camping Reply with quote
My daughter repairs computers. I use the surplus magnets from them. Otherwise neodymium magnets from an online source. They are not cheap. They are brittle and the thin ones break easily. Caveat: handle carefully, they will pinch fingers.
Aloha
tp
0to60in6min
0to60in6min is offline
PostPosted: Fri Apr 01, 2016 3:47 pm    Post subject: Re: I need suggestions on mounting window insulation while camping Reply with quote
I use suction cups like this one
http://www.homedepot.com/p/OOK-1-lb-1-1-8-in-Clear.../100212757
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Fri Apr 01, 2016 3:58 pm    Post subject: Re: I need suggestions on mounting window insulation while camping Reply with quote
I had a go at what you are asking about. It works pretty well, if I had to change anything I would make the blankets taller by an inch or so.
I'm proud of one idea I had with the magnets. I arranged them so that the poles were oriented such that when the blanket is folded the magnets attract each other and hold everything in place. In fact it almost feels like it folds itself.
Oh and that magnet orientation trick also helps hold the blanket in a half open config on the window.
Apologies for large image size
Blog post
https://shufti.wordpress.com/2013/03/10/vanagon-insulated-window-blanket-prototype/
Alistair
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com
pinetreeporsche
PostPosted: Fri Apr 01, 2016 5:23 pm    Post subject: Re: I need suggestions on mounting window insulation while camping Reply with quote
ragnarhairybreeks wrote:
I had a go at what you are asking about. It works pretty well, if I had to change anything I would make the blankets taller by an inch or so. ....
Alistair-- I love the way they look- the fabric is most luxurious. Two Qs: You say you'd make them an inch larger, vertically-- but don't say how large they are, either dimension, or, as the windows differ, how tall would they be Big Q is how are the magnets installed (?like sewn in maybe-- but can the foil take stitching without tearing? And how close, one to the next, are the magnets spaced to keep them tight to the glass?
pinetreeporsche
PostPosted: Fri Apr 01, 2016 5:43 pm    Post subject: Re: I need suggestions on mounting window insulation while camping Reply with quote
kourt wrote:
Howdy,
... I bought the Just Kampers Thermomat kit,
The Just Kampers mats work well most of the time--but I have to admit the suction cups don't perform well in the winter. That's when having nice tight curtains can help hold things to the glass. -kourt
Couple of Qs here, too: Do the suction cups do the job of sealing the bottom edge-- say, when it's warm enough that the cups work- or is there always some leakage? How many cups, how big and how close together do they come on the pre-made Kampers? Would extra closure at the bottom of the Kampers be achieved by adding magnets, or are they too short (vertically)?
ragnarhairybreeks
PostPosted: Fri Apr 01, 2016 6:15 pm    Post subject: Re: I need suggestions on mounting window insulation while camping Reply with quote
Yes the fabric is swanky isn't it? Was a microsuede in the remnants pile. Cost very little. The foil stuff, and I think I have the name of that stuff on my blog link, did sew ok. My wife did the sewing, used tape, binding tape, on the edges.
The size... Well they really do need to be sized so that the magnets lie on the less curved portion of the window. I cut a little tight, and there was no need for that. Some excess lenght is ok.
I used a total of eight magnets for that one. One on each corner and in the middle of the horizontal edges. And you need one in the middle of the vertical edges. Yup, magnets just in stitched pockets.
Alistair
kamzcab86
kamzcab86 is offline
PostPosted: Fri Apr 01, 2016 6:24 pm    Post subject: Re: I need suggestions on mounting window insulation while camping Reply with quote
I hate those suction cups. I sewed tabs around mine with a Rare Earth magnet in each and covered the grommets with Reflectix tape:
~Kamz Anxious
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein
