reay Samba Member
Posted: Sat Jul 03, 2021 7:38 am Post subject: Re: Restoration:1966 1200A Model 115 Sedan with Sunroof (Ragtop) |
For the 66's 55th birthday I picked up the sweet painted mirror! _________________ Tom Reay
Da weiss man, was man hat!
68 Karmann Ghia Sunroof / auto T345
66 Standard Microbus T221
66 1200a Standard 115 with factory ragtop |
reay Samba Member
Posted: Fri Jul 03, 2020 8:55 am Post subject: Re: Restoration:1966 1200A Model 115 Sedan with Sunroof (Ragtop) |
Thanks so much -
That does help. Of course the three options I'm looking at now - 2 complete rebuilt motors or rebuild a motor I have using a correct case - none of them have the pre-heat hose in that location!
Would I be forgiven if I didn't get that detailed on the engine?
TR _________________ Tom Reay
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Sat Jun 13, 2020 8:32 am Post subject: Re: Restoration:1966 1200A Model 115 Sedan with Sunroof (Ragtop) |
Tom,
Given your late 66 chassis number you would want to run the air cleaner pre-heat hose to the left heater box same as the late 1300's.
Here is my fuzzy pic of how a late 66 should look:
This is how the front tin looks, and you can just make out the fitting on the left heater box:
Rear tin is unique too, no hole for pre-heat tube. Not exact but something like this:
Of course to be 100% correct the engine should have a D stamped serial number, your friends probably doesn't have that but only the detail nuts will notice that.
Internally late 40's got cam bearings and most other progressive engine refinements but those are hidden from view inside the case. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
reay Samba Member
Posted: Tue Jun 09, 2020 9:46 pm Post subject: Re: Restoration:1966 1200A Model 115 Sedan with Sunroof (Ragtop) |
I have a question -
A guy I know has a complete 40hp plug and play motor for sale. He's a retired VW mechanic. What should I look for so it would look correct in my 1200A? Or, was it basically the same motor for it's run, or were later ones different than earlier motors?
I have a H block and another complete engine with the correct tin and parts. But I think I'd rather just get a good solid motor like the one that is for sale.
Thanks, Tom _________________ Tom Reay
mukluk Samba Member
Posted: Tue Jun 02, 2020 9:57 pm Post subject: Re: Restoration:1966 1200A Model 115 Sedan with Sunroof (Ragtop) |
The workshop manual calls for the split boot seam to be installed horizontally and toward the rear, though common practice usually dictates putting the seam at 10 or 2 o'clock to help prevent leaks while keeping the seam as close as possible to horizontal. The reason you don't want the seam straight up is so that the boot can flex as much as possible during suspension cycling without putting undue strain on the boot -- having the thick seam straight up stresses the boot and leads to tearing.
_________________ 1960 Ragtop w/Semaphores "Inga" |
reay Samba Member
Posted: Tue Jun 02, 2020 8:52 pm Post subject: |
finster wrote: |
don't the axle gaiters need re-orientating? the join is where it will get most stress. |
I think that is correct the way it is. (But I'm not sure) That how it was on the car originally. _________________ Tom Reay
finster Samba Member
Joined: May 26, 2012 Posts: 7951 Location: north o' the border
Posted: Fri May 29, 2020 5:42 am Post subject: |
don't the axle gaiters need re-orientating? the join is where it will get most stress. _________________ "we're here on Earth to fart around" kurt vonnegut
nothing lasts, nothing is finished, and nothing is perfect... |
reay Samba Member
Posted: Thu May 14, 2020 10:01 pm Post subject: Re: Restoration:1966 1200A Model 115 Sedan with Sunroof (Ragtop) |
I have a painter lined up, but need to figure out when that can happen. _________________ Tom Reay
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Thu May 14, 2020 7:47 pm Post subject: Re: Restoration:1966 1200A Model 115 Sedan with Sunroof (Ragtop) |
jays58s wrote: |
Any updates? |
What about now? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
reay Samba Member
Posted: Wed Oct 16, 2019 9:55 pm Post subject: Re: Restoration:1966 1200A Model 115 Sedan with Sunroof (Ragtop) |
Lets see -
I've picked up a NOS painted hubcap just to get the correct silver.
Later I found 4 NOS un-chromed hubcaps. So now I have almost everything that needs to be painted.
But, this project is a bit on hold. I picked up a Porsche for my daily driver and have been spending plenty of money there. Also, I have decided to make my other two vintage VWs 100 % finished. I need to take care a few items, nothing big. _________________ Tom Reay
jays58s Samba Member
Joined: August 23, 2004 Posts: 2133 Location: Nor-Cal
Posted: Tue Oct 15, 2019 11:09 pm Post subject: Re: Restoration:1966 1200A Model 115 Sedan with Sunroof (Ragtop) |
Any updates? |
Oliwer Lorenc Samba Member
Posted: Mon Nov 05, 2018 4:54 am Post subject: Re: Restoration:1966 1200A Model 115 Sedan with Sunroof (Ragtop) |
Can you show me your right rear wheel arch? _________________ 1966 1300 Deluxe Beetle from Croatia |
reay Samba Member
Posted: Sat Sep 15, 2018 4:10 pm Post subject: Re: Restoration:1966 1200A Model 115 Sedan with Sunroof (Ragtop) |
Hello, I'm Tom - and I've taken over this project from Brian!
We have been friends for about 18 years now and this just looked like too cool of a project to pass up. I'm going to just pick away at it and hopefully have it back on the road in two years or so. My main passion is Karmann Ghia type 34s and this my first beetle of the many vintage VWs I have owned. I now own the most expensive VW you could buy - a 68 Type 34 with electric sliding roof and automatic transmission and the other end of the spectrum - the least expensive VW, a 1200a which costs 1/2 as much. (of course this model was $50 or so more with the ragtop option).
Another cool thing that has happened is when I finally received the birth certificate for my T34, it turns both cars where made on he same date! (two years apart).
I post, and keep this thread going.
LHG wrote: |
First a little background.
I first heard about this car on January 6, 2009. It was up for sale and the owner wanted it to go to someone who could appreciate what it was and keep it stock. After doing a bit of research and checking out the car I made the 700 mile round trip and bought it on January 10, 2009. What followed was an exhaustive research on the car and what would have been correct for this model.
A classic example of "Rare does not mean Valuable".
It's a rare car, a post 1963 factory ragtop is one of those cars you hear about but rarely see. There are only a handful in the US and maybe less than 20 or so world wide. I can't afford some of the more common expensive cars people seek, so I just call this my Hebmueller
I received the Birth Certificate from VW and it confirms that it is a Model 115 which is a 2 door Sedan; Standard Model LHD with sliding roof. One thing I like about this car it doesn't require any explanation about how it was built for this or that special market, or how it happened to come with some odd level of trim. This is just a straight forward, delivered to Germany, stock with no options, 1966 Model 115.
Here is a topic I started to find out more about this model.
1966 European Standard, what was OG
http://www.thesamba.com/vw/forum/viewtopic.php?t=336263
Why a complete restoration?
In a word, Rust. For a car that spent a lot of time in California, it's pretty rusty. Most of its life was in San Francisco and then moved to near the river bottom in Chico. Rusty heater channels, cancer bubbles here and there and the drivers side pan was toast. It was also repainted on the outside and needed some body work from getting tapped both front and rear.
Fortunately, it still has most of the Standard parts and hasn't been hacked up. I usually wouldn't take on a car with this much body repair but I'm doing it as a labor of love, or just because I'm foolish!
Restoration Guidlines
Here is the cars Birth Certificate.
Here is a list I made a while back about some of the differences between a 66 Deluxe and Standard.
The car has been completely disassembled and most of the correct parts have been obtained... So now let the fun begin! |
60CDNSTD Samba Member
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
LHG Samba Moderator
Joined: April 13, 2000 Posts: 1855 Location: LostHillsGuy, CA
ento Samba Member
Joined: December 31, 2008 Posts: 180 Location: el paso tx
Posted: Sat May 17, 2014 10:34 am Post subject: |
Hope you have a had chance to make some progress. Can't wait to see the car finished. I would kill for one like that _________________ 66 European bug, 66 euro sunroof
76 baja
76 sun bug sunroof
64,66,67,68 bug
69,70 bay
61 Ragtop bug, 61 sedan(looking for the vert)
61 RHD Ragtop Semaphore bug fakeAF
64,64 KG
74 thing
55 oval
70 ratrod
73 fastback pignose |
Project_dog Samba Member
Joined: June 26, 2003 Posts: 65 Location: Spokane, Wa
Posted: Sun Apr 07, 2013 12:20 am Post subject: |
Great looking project you got there. |
LHG Samba Moderator
Posted: Sun Mar 31, 2013 6:59 pm Post subject: |
I've been working on the old house for 5 months and we are moving this month. Because of that, I needed to get this project to rolling status so today I installed a rebuilt tranny I got from Joe Crockett. He had it as a left over from a previous project.
_________________ Brian O'Kelly
Central Coast Chapter, CA - Vintage Volkswagen Club of America
www.centralcoastvwclub.com
www.facebook.com/groups/vintagevwclub/ |
LHG Samba Moderator
