bjrogers86auto Samba Member
Joined: March 26, 2009 Posts: 1375 Location: Halifax, N.S.
Posted: Fri Apr 27, 2012 10:44 am Post subject: Brake shoe query |
Hey folks,
86 Vanagon. Just wondering if the lever on the shoes for the self adjuster is reusable. I have a set of shoes that doesn't have it. Perhaps they are the wrong shoes. Entirely possible.
I won't get a chance to pull the wheels off until next week and want to make sure I have the proper ones.
Thanks,
Brian. _________________ 86 Vanagon GL Westfalia 2.1
18 Nissan Frontier Pro 4X
19 Honda Civic Hatchback
A little rudeness and disrespect can elevate a meaningless interaction to a battle of wills and add drama to an otherwise dull day. Calvin and Hobbes. |
syncromike Samba Member
Joined: November 14, 2011 Posts: 660 Location: Boise, ID
Posted: Fri Apr 27, 2012 11:08 am Post subject: Re: Brake shoe query |
bjrogers86auto wrote: |
Hey folks,
Thanks,
Brian. |
I just replaced my rear brakes and the lever is not removable, it's attached like a loose fitting rivet. The old ones were pretty worn anyhow.
I bought shoes from CarQuest first and with their shop-brand shoes the lever was not bent at the right spot so the lever did not align with the teeth on the adjuster. I bought German-made shoes from Van-Cafe that were a much better fit.
If your shoes don't have a lever, I would assume they're the wrong shoes and I'd get the proper version with the lever. _________________ _____________________
'91 Syncro w/ Country Homes PopTop |
SGS Samba Member
Joined: May 30, 2011 Posts: 99 Location: High Level AB
Posted: Fri Apr 27, 2012 11:51 am Post subject: |
I got mine from autopartsway.ca Same shoes and brand as Van Cafe has listed for my 1985. Normally free shipping for orders in Canada over $75. Sales (%5) by email promo code every couple months.
They have ok prices, the right brands (usually), and shipping is quick. I usually get stuff in 2-5 days. _________________ SERENITY 1985 Vanagon GL Westfalia 1.9L wbx (Cdn. model) |
Posted: Fri Apr 27, 2012 12:40 pm Post subject: shoes |
Thanks for the info. I was pretty sure they were the wrong shoes but unsure about that lever.
Thanks for the parts info. I have a few local sources that get me parts pretty quick.This particular guy is usually right on, just happened to get sent the wrong ones. I will reorder on Monday.
chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Fri Apr 27, 2012 2:54 pm Post subject: |
Need the lever.
My brand new shoes from leading supplier had the levers break off within 2500 miles and jam into the crevices of the braking system causing unholy noises.
LP _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
danfromsyr Samba Member
Posted: Fri Apr 27, 2012 4:08 pm Post subject: |
the non-adjuster lever ones are most likely for Bay Buses, they are manualy adjusted.
one thing I've had trouble with in econo kits is 2 left E-brake shoes
which is quite the puzzle when you're not expecting it and have to either use one old one, or grind off the rivit from the correct old shoe and resecure it to the new shoe... just to be prepared. _________________
Abscate wrote: |
Posted: Fri Apr 27, 2012 4:14 pm Post subject: shoes |
Thanks Dan,I"ll keep that in mind.
How's the trip planning going? Still heading up Quebec way this summer?
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Fri Apr 27, 2012 9:10 pm Post subject: |
chojinchef wrote: |
Need the lever.
LP |
I also had some "white box" rear brake shoes from one of our favorite vendors snap the adjuster lever..the thin one that works the adjuster.
Left side broke and I made a good repair..by replacing the leading brake shoe assembly from RockAuto.
Right side broke about a year later. Used the right side leading brake shoe from the same box.
The broken part attaches to the spring. Right and left broke in the same place.
Beware of the brake parts that come in a simple white box with no clear vendor..bad news. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Apr 27, 2012 9:26 pm Post subject: |
chojinchef wrote: |
...brand new shoes from leading supplier had the levers break off within 2500 miles... |
Me: same thing ... AS I WAS INSTALLING THEM. <Meyle brand>
Yep - sounds like you got the wrong parts... _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
