Manfreds78bay Samba Member
Posted: Fri Apr 27, 2012 10:55 am Post subject: Windshield Advice Remove or Not to Remove |
I have a 78 westy with a cracked windshield. It came that way. I've been holding off replacing the windshield after researching all the rust issues. The windshield does leak. There are visible rust holes just below the seal. I have purchased a new seal and the entire lower windshield tray from Klassic fab.
My plan was to save enough money to take it to a body shop and have the guys install the new windshield and give them the lower windshield tray incase they need it.
But lately I've been thinking about just taking the windshield out myself and see how bad the damage is. My problem is that I don't want to remove it and then be stuck with an down bus if the damage is so bad I won't be able to re install the windshield.
Has anyone seen a windshield tray that was so rusted there was no way to install a windshield back in? I think it would be wise to take a look myself, but I don't want to take the chance that she will be down until I get the cash together for the repairs. I'm crossing my fingers that it won't be as bad as I think. |
Yondermtn Samba Member
Joined: November 21, 2007 Posts: 609 Location: Illinois
Posted: Fri Apr 27, 2012 11:15 am Post subject: |
It might be easier to get a look from under the dash. Maybe even feel with your fingertips if that area is going to crumble.
Post some pics. |
FreedomBuild Samba Member
Joined: September 21, 2010 Posts: 385 Location: Calgary, Alberta
drober23 Samba Member
Joined: April 01, 2009 Posts: 787 Location: Detroit, MI
Posted: Fri Apr 27, 2012 11:50 am Post subject: |
I see the dilemma. If you don't pull the windshield, you can muddle along with your leak, while the rust slowly gets worse. But at least you are driving.
If you pull the windshield, you MUST deal with whatever is there before you can drive again. It's easy for an observer to say "do it now, cause it's just going to get worse."
However, this summer could be a significant portion of the time you have to enjoy the bus (especially if you let it rust to death).
Hmmm....
I would be tempted to roll it this summer, then tackle it in the fall. But I'm a hack, so your mileage may vary. _________________ DJ
'75 Westfalia, '79 Deluxe, and some others...
(more busses than sense)
In a time of chimpanzees I was a monkey |
ned Samba Member
Joined: June 28, 2004 Posts: 1574 Location: Arroyo Grande Ca.
Posted: Fri Apr 27, 2012 4:54 pm Post subject: |
Or you can wait till you get a ticket for a cracked windsheild. Maybe then you will do it. |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Fri Apr 27, 2012 5:08 pm Post subject: |
If a glass shop is nearby, drive there and remove the windshield on a Friday. Repair and paint on the weekend. Install the new glass and moulding at the shop on Monday. Or, do it yourself on the same schedule.
Aloha
tp |
Joined: January 01, 2007 Posts: 16886 Location: sticksville, ct.
Posted: Fri Apr 27, 2012 6:40 pm Post subject: |
do it......i dare you
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
SGKent Samba Member
Posted: Fri Apr 27, 2012 6:54 pm Post subject: |
skills@eurocarsplus wrote: |
amazing what people use to fill rust holes these days... _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Apr 27, 2012 7:06 pm Post subject: |
SGKent wrote: |
amazing what people use to fill rust holes these days... |
thanks. i really didn't need the captain & coke to make a trip thru my nasal cavity before hitting the keyboard
lesson learned here boys and girls, all it takes is buckets of 20's make make rust go away _________________
Jake Raby wrote: |
Brian wrote: |
crushie Samba Member
Joined: September 23, 2011 Posts: 878 Location: alberta
Posted: Fri Apr 27, 2012 7:52 pm Post subject: |
With the value of a greenback going down that's probably the best use of a 20 I've seen in a while. |
grandpa pete Samba Member
Posted: Fri Apr 27, 2012 8:12 pm Post subject: |
..IMHO...Get some syllacone sealer and squish it in the cracks in the old rubber seal and all the places where the old seal has shrunk and clean off the excess and enjoy your bus. Don't jump into this major project without the time knowledge and money to fix it properly...the "temporary" fix will slow down any more rusting by cutting off the moisture supply...I did this on mine over a year ago . Now I have the knowledge (thanks samba ) and the money; but have gotten busy and won,t have the time untill august when bisness slows down for vacations...TO those who disagree ; you are intitled to your opinion ...IT,S NOT YOUR BUS _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3305 Location: Australia
Posted: Fri Apr 27, 2012 8:28 pm Post subject: |
grandpa pete wrote: |
..IMHO...Get some syllacone sealer and squish it in the cracks in the old rubber seal and all the places where the old seal has shrunk and clean off the excess and enjoy your bus. Don't jump into this major project without the time knowledge and money to fix it properly...the "temporary" fix will slow down any more rusting by cutting off the moisture supply...I did this on mine over a year ago . Now I have the knowledge (thanks samba ) and the money; but have gotten busy and won,t have the time untill august when bisness slows down for vacations...TO those who disagree ; you are intitled to your opinion ...IT,S NOT YOUR BUS |
But at the same time that's like leaving an unopened envelope of medical test results on your fridge. Doesn't affect most of your life, but sometimes you will glance at it in passing wondering what is hidden within.
That's why I have a windscreen rubber fund. The glass is in passable shape thankfully, as long as I can get it out intact. It's OE VW glass so it'll probably be a bit touchy. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Posted: Fri Apr 27, 2012 9:44 pm Post subject: |
the "temporary" fix will slow down any more rusting by cutting off the moisture supply...I did this on mine over a year ago |
that is the worst advise i have seen in a while....for so many reasons
your right. not my bus. and i wouldn't dream of doing it that way either.
here is what silicone and newspaper lead to
and after 2K and my ice coffee bill
do it right the first time, or don't bother until you can do it right _________________
Jake Raby wrote: |
Brian wrote: |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Fri Apr 27, 2012 9:45 pm Post subject: |
Except that smearing a bunch of silicone in there will not stop the water coming in -- it will only make it rust faster by not letting the water that sneaks in behind the silicone out. Bad idea. It should not take a body shop more than a couple of days to fix it -- go ahead. You'll be glad you did.
And Ned, are you serious that you can get a ticket for a cracked windshield? You'd be lucky to drive in New Mexico for a year without getting a cracked windshield! _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
DirtyCossack Samba Member
Joined: January 29, 2012 Posts: 209 Location: Ft Sill, OK
Posted: Fri Apr 27, 2012 10:03 pm Post subject: |
jtauxe wrote: |
And Ned, are you serious that you can get a ticket for a cracked windshield? |
Go a week on an Army base and you win Hide and Seek Champion of the Year. _________________ 1970 Type II, Betty
1973 914 |
VWDruid Samba Member
Joined: June 14, 2008 Posts: 1192 Location: Boca de Ratones FL
Posted: Sat Apr 28, 2012 8:47 am Post subject: |
I did the silicon on the seals but first I picked out all the rust and used ospho, Ospho puts navel jelly to shame.
http://www.ospho.com/
look for it i hardware stores the paint section. _________________ 70 Westy, 2027cc "dual DRLA 40 m140 i55 wjdoc a165 p33 v30 "w100 straight cut 040 polished heads 1.25 rockers 1.5 A1sidewinder supertrapp muffler trans 091 coil SUM-850500 CDI universal svda Pertronix
http://www.storyofstuff.com/
It's not the straight cut gears It's the T.A.R.D.I.S. engine.
wanted Chameleon Circuit |
Posted: Thu May 03, 2012 7:19 pm Post subject: |
Hey guys sorry this is so late. I finally got some pics. Not as bad as I thought. I think I might just pull it.
_________________ 1978 2.0L FI Campmobile
1982 AMC Eagle SX4 4.2L FI |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Thu May 03, 2012 7:33 pm Post subject: |
get some POR15 if nothing else... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Fri May 04, 2012 7:47 am Post subject: |
I've got some....going to try and pull it this weekend! will update. _________________ 1978 2.0L FI Campmobile
Posted: Fri May 04, 2012 9:59 am Post subject: |
i think the easiest way to get it out is to pick a corner (pass top is nice) and push GENTLY and it should slide right out of the groove and then just follow it along where it comes out and it should be out in a minute or two. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
