Bretsbus Samba Member
Posted: Sat Apr 28, 2012 5:05 am Post subject: My wipers do not work |
The wipers on my bus do not work. What should I check before I go poking around? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Apr 28, 2012 8:07 am Post subject: Re: My wipers do not work |
Bretsbus wrote: |
The forum posting do's and dont's sticky, I'm sure it says someting about including information about your bus like year and model in your posts _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Apr 28, 2012 10:59 am Post subject: |
It is a 1979 II |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Sat Apr 28, 2012 11:13 am Post subject: |
First, what do you mean by don't work? Does nothing happen when you move the switch or do the arms just don't move?
Figuring on it being on the first one, have you checked the fuses? Not only making sure they aren't blown but cleaning the contacts as well? Did they ever work for you? |
Posted: Sat Apr 28, 2012 11:26 am Post subject: |
Nothing happens when I move the switch. I have changed the fuses and that has not done anything to the wipers but it did fix a couple of other things. I can try cleaning the contacts, and no they have not worked for me. |
bugsy95 Samba Member
Joined: December 18, 2009 Posts: 275 Location: chicago
Posted: Sat Apr 28, 2012 12:48 pm Post subject: DDD |
Try and spray a little bit of pb blaster on the shaft part..dave 1973 bus |
Posted: Sat Apr 28, 2012 2:32 pm Post subject: |
Check the connections on the wiper motor (not fun to get at, I know), clean them up with some emery cloth. Get some new spade connectors and replace the ones on the wires. They do degrade over time and you are looking at a 30+ year old vehicle. Where you are having issues with several electrical items, I'm leaning towards corrosion on the fuse panel, old ends, a hacked wiring harness or all of the above. |
