72 westy rear brake drums***HELP
juvewoo
juvewoo is offline
PostPosted: Mon Apr 30, 2012 6:32 am    Post subject: 72 westy rear brake drums***HELP Reply with quote
Looking for the correct exploded/install diagram for a 72 Westy rear bake drum assembly. They do not move when pedal is pushed or e-cable pulled. I wonder if they are assembled wrong. I only find the wrong pics. All internal parts have been replaced. Additionally, the 'bad' light is lit. Yet, the new e-cables should still move the shoes.
'72 Westy...1776 upright...my sweet DIXIE !!!
muffler bearing
muffler bearing is offline
PostPosted: Mon Apr 30, 2012 7:39 am    Post subject: Reply with quote
I will see what I can find. I went thru the dreaded 72 brakes recently. front and rear.
" A poor ride is better than a proud walk"
56 Beetle
72 Westfalia (Driving project)
75 Riviera
Yes, I do have a Bentley.
mikewire
mikewire is offline
PostPosted: Mon Apr 30, 2012 7:49 am    Post subject: Reply with quote
This isn't probably going to help one bit, because I only had the drum and wheel off, but I have one picture of the rear drums on my '72
Fluid? New brake lines? How are the solid lines?
-Mike
@countdowngarage
@bigskyeuro
1972 VW Kombi 9 Passenger Deluxe w/ 2.0L F.I. VWAC swap
1965 VW Beetle Deluxe Bahama Blue
View user's profile Send private message Send e-mail Visit poster's website Twitter Instagram Classifieds Feedback
SGKent Premium Member
SGKent is offline
PostPosted: Mon Apr 30, 2012 8:01 am    Post subject: Reply with quote
from 1972 to 1979 the setup is essentially the same. What manuals do you have?
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
juvewoo
juvewoo is offline
PostPosted: Mon Apr 30, 2012 8:25 am    Post subject: 72 Type 2 brakes Reply with quote
Ok. the pic does resemble my brakes and , from what little I can see they are assembled the same. No, I have not replaced any lines, nor the mc or booster. New resevoir and line to mc. I will replace the rubber lines and mc, next. I still do not understand why the e-cable and arm moves nothing.
juvewoo
juvewoo is offline
PostPosted: Mon Apr 30, 2012 8:29 am    Post subject: Reply with quote
I only have the Bentley Official Service manual for type 2 68-79. And routinely does not include pics for 'my' bus. I am aware that 72 was a split year. changes were made mid year. Pretty sure mine is the pre-changes model-no engine bay access door from inside. gas filler is on passenger side.
mikewire
mikewire is offline
PostPosted: Mon Apr 30, 2012 8:38 am    Post subject: Reply with quote
You do have two systems on the rear, the e-brake is the cable, the pedal is hydraulic. So if the e-brake arm/lever isn't moving then you ether have rusted cables or a part in the linkage that is not moving, probably rusted solid, or broken, and is a common issue.
The brake pedal is hydro, so if you are having problems there, that could be related to fluid level, MC, bad/old lines etc.
If neither work, then yeah you probably have it assembled incorrectly, and I would triple check that. Brakes are not something to mess around with.
The Bentley has everything you should need to do a full R&R on front and rear brakes - parts are readily available.
Actually '71 was the first year of disk/drum, so '72 is the same, and on up the line until '79 the brakes are the same, possibly with small changes. Almost all drum brakes I have worked on function the same - the linkages may designed a little different, but on a Bus, they should be all the same or really close.
Trust me, I know the nuances of a '72 Very Happy I'm not sure what I'm missing here, but if you can take some pictures of what you have, we can compare and try to e-diagnose.
-Mike
@countdowngarage
@bigskyeuro
dabble
dabble is offline
PostPosted: Mon Apr 30, 2012 9:03 am    Post subject: Reply with quote
Have you turned the adjustment screws to see if they move that way?
1973 Westy with a 78 FI 2000cc
[url=http://www.vw-mplate.com/mplate2-9157.png]Click to view image[/URL]
muffler bearing
PostPosted: Mon Apr 30, 2012 10:04 am    Post subject: Reply with quote
Finding the spreader bar was the hardest part for me. it a 72 only thing
56 Beetle
75 Riviera
BumbleBus
BumbleBus is offline
PostPosted: Mon Apr 30, 2012 11:36 am    Post subject: Reply with quote
For what it's worth here's a shot without the hub on:
Good luck! Took me months of spare time in the evenings to do mine, but I learned a TON and when I test stomped on the brakes and came to a screeching halt it was all worth the effort. Cool
(and no, I hadn't routed my ebrake cable yet so ignore that hehe)
'72 L11H Campmobile in various stages of disrepair. Just bumbling along...
busdaddy
busdaddy is offline
PostPosted: Mon Apr 30, 2012 12:18 pm    Post subject: Reply with quote
Слава Україні!
mikewire
mikewire is offline
PostPosted: Mon Apr 30, 2012 12:22 pm    Post subject: Reply with quote
^ all above pictures and diagrams are awesome Dancing
-Mike
@countdowngarage
@bigskyeuro
atmellovw
atmellovw is offline
PostPosted: Mon Apr 30, 2012 2:16 pm    Post subject: Reply with quote
Note that the 72 spreader bar is different and that the fastener on the rear most shoe is a pin with a special clip (not shown in the diagrams?). You can see this clip in the pic above and there is a pic in my gallery.
1972 Westy ("Bubbles") - Pastel White - 1700(1974 MT) - Dual Solex
juvewoo
juvewoo is offline
PostPosted: Mon Apr 30, 2012 3:17 pm    Post subject: 72 brakes Reply with quote
Thanks everyone
prodaddy
prodaddy is offline
PostPosted: Thu Jan 24, 2013 2:08 am    Post subject: Reply with quote
Hey, does anyone happen to have a spare 72 brake spreader bar, I found out I'm missing one in my right rear drum . I could not get my emergency brake cable to adjust properly and found out this part was missing when I pulled the drum. Any help with locating this part would be greatly appreciated. Surprised
1957 23 window samba,1963 23 window deluxe(work in progress),1967 westy,1967 21 window deluxe,1963 vw bug ragtop,1962 vw bug.
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Thu Jan 24, 2013 11:59 am    Post subject: Reply with quote
chris at busted bus, or ken at the bus company will have it. they both ship.
Stuart Zickefoose
206-841-7324
[email protected]
Amskeptic
Amskeptic is offline
PostPosted: Thu Jan 24, 2013 12:25 pm    Post subject: Reply with quote
NOTE:
The '72 and early '73 ebrakes had a peculiar issue with brake shoes that are not at full *thickness*. I have happened across cheap new shoes that scrimp on lining thickness, and you must also be aware of this problem as your linings wear.
The lever that is pulled by the cable will hit the wheel bearing housing as the shoes wear. A shoe adjustment will not fix it. Tightening the ebrake cables will not fix it. As a matter of fact, I have visited buses with a tight ebrake handle that doesn't even bother slowing the car down. You need to grind the inner edge of the lever in a nice smooth crescent around the wheel bearing housing to maintain ebrake function as your shoes wear.
Colin
www.itinerant-air-cooled.com
kreemoweet
kreemoweet is offline
PostPosted: Thu Jan 24, 2013 12:49 pm    Post subject: Reply with quote
I hereby nominate Colin's post above for immediate stickification.
'67 bug: seized by the authorities
Amskeptic
PostPosted: Thu Jan 24, 2013 12:58 pm    Post subject: Reply with quote
I nominate a further discussion . . . I am looking at Bumblebus' immaculate rear brake assembly, and I see no chance of the lever ever reaching the wheel bearing housing, but I sure as heck have seen levers only a scant inch away.
Other observations or experiences?
Colin
prodaddy
prodaddy is offline
PostPosted: Thu Jan 24, 2013 4:31 pm    Post subject: Reply with quote
Thanks for the info.I'll give them a try. I too also live on a hill with no e-brake. Hopefully I can get rid of my Cinder Block soon. Laughing
