chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Tue May 01, 2012 5:23 pm Post subject: Insulation |
OK, I know I am asking for it, but what is the current best practice for insulating the walls of the van. Not sound deadener, but a replacement for the fiberglass that I have systematically removed from within the wall cavities?
I have searched and found various ideas that were repeatedly shot down by members, so do we have a 'agreed' practice that works without negative side effects?
As I have just removed my drivers rocker panel and have seen the damage a fiberglass batting can inflict on an unsuspecting vanagon panel, I am curious to gain some insight from the membership.
Thanks in advance for any input.
LP _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
rubbachicken Samba Member
Posted: Tue May 01, 2012 5:42 pm Post subject: |
probably wrongly, i'd look for a water repellant spray foam insulation
what are you doing about the insides of your seams now that you have repaired them ? _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
outwesty Samba Member
Joined: June 06, 2006 Posts: 1074 Location: Tahoe City
Posted: Tue May 01, 2012 5:48 pm Post subject: |
rubbachicken wrote: |
what are you doing about the insides of your seams now that you have repaired them ? |
Sikaflex 227. Was recommended by my friend the body man.
http://us01.webdms.sika.com/fileshow.do?documentID=978 _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
Posted: Tue May 01, 2012 6:04 pm Post subject: |
chojinchef wrote: |
Sikaflex 227. Was recommended by my friend the body man. http://us01.webdms.sika.com/fileshow.do?documentID=978 |
is that for the seams you see, or the insides where you don't, i was wondering about the possibility of sweating in lead based solder from the inside, sealing the seam from the inside, being sure that water could not rot the seams out from the inside
the capillary action should suck solder almost right though, sealing the seam from the inside
an it would need to be done before painting _________________ lucy our westy
meet 'burni'
Posted: Tue May 01, 2012 6:10 pm Post subject: |
chojinchef wrote: |
Never thought about solder. Figure with the idiot drivers here in Northeast, I will probably need repair ability.
I will be using the Sikaflex wherever I can apply it around seams - inside and out. Trying to blast as much of seam, then prime to best prep for sealer.
an it would need to be done before painting |
insyncro Banned
Posted: Tue May 01, 2012 6:18 pm Post subject: |
Sika products are amazing.
I use many of them in home construction.
Most come in tubes and can be spread like a brushable seam sealer on the inside.
Wurth has two part foams available.
I have the pneumatic applicator.
Pricey stuff |
Posted: Tue May 01, 2012 6:21 pm Post subject: |
insyncro wrote: |
Pricey stuff |
Have used some Wurth products before. Are you referring to something specific that I can look into? _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
insyncro Banned
Posted: Tue May 01, 2012 6:31 pm Post subject: |
I don't remember the name or product number offhand.
I can check tomorrow.
Not sure if you can access the product info without an account.....
wurthusa.com |
Posted: Tue May 01, 2012 6:34 pm Post subject: |
Thanks for any information you can get.
J Charlton Samba Member
Joined: August 24, 2007 Posts: 1544 Location: The True North Strong and Free
Posted: Tue May 01, 2012 6:54 pm Post subject: insulation |
I really like the Prodex insulation referenced (linked) above. Light, easy to apply - its great for lining the inside of a hightop. Its IR reflective properties means that the van stays warm in the cold months and cool in the summer.
Would I use it to insulate the sides, doors, etc of a van - NO. The reason is that whereas when lining the top one can seal the surface completely by using the reflective tape, thereby preventing any air infiltration
it would be impossible to do so in the cavities of the van.
I'd use this stuff - at first glance it seems expensive, but I figure that there's enough to probably do 3+ vans - so if a few people got together .... http://www.foaminsulation.net/spray-foam-insulatio...-foam-kit/
Used in the side cavities it has all of the qualities I'd like: closed cell, good acoustically, good R value and it would get into all of the nooks and crannies.
I wouldn't use spray foam to insulate a hightop however - I've talked to quite a few professional foam folks - there is no way to ensure that the thickness of the foam when applied and expanded will be uniform. If a spray foam insulation was of varying thickness it would be next to impossible to finish the interior of the top neatly. _________________ NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 3 available), Small Car Performance Fife Wa. (7 tot 5 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2023 |
Westified Samba Member
Posted: Tue May 01, 2012 7:09 pm Post subject: Insulation |
I too removed my Dometic fridge to change the fan and check valve. I looked at the floor behind it and as many members have said there was rust. I have now pulled the entire kitchen, removed the fiberglass insulation behind the kitchen and under the water tank. Did POR-15 for the rust. I am trying to figure out what is the best insulation to replace the fiberglass. My big concern is how hot does it get behind the fridge when running on propane. Does anyone know. The reason is that various insulation's have temperature limits. ie Reflectix 185 degrees, dynaliner 225 degrees, fiberglass 350 degrees etc. I don't want the insulation to melt or offgass. I also don't want to put something back that holds moisture. Any help would be appreciated. |
Posted: Tue May 01, 2012 7:27 pm Post subject: Re: Insulation |
Westified wrote: |
You'll have to read the specs on a variety of products. That's a pretty flat surface, you might consider a spray foam with a reflective barrier between it and the fridge. Check Summitt Racing or Racer Part Wholesale for reflective heat shielding. _________________ NAHT hightop availability May 18 2023 -
