wcfvw69 Samba Purist
Posted: Tue Mar 08, 2016 7:34 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
BarryL wrote: |
EverettB wrote: |
I did notice it said 0 TDC as you mentioned for post-67 stuff. |
I was hoping tasb would officially weigh in as post '67 had smog stuff. If the spring rate and vacuum can is the same and it's a dealer replacement then it "should" be 7.5 BTDC but I want to be sure for El Maestro Himself. Thanks glutamundo and EverettB. |
The vacuum can pull length is what is the difference between the 7.5 BTDC can and the 0 can. I have both the 67' 205K distributor and the 69' 205T distributor. Glutamoto pointed that out in the vacuum can thread so I went and measured both cans. He also noted that most of the 66 and 67 original vacuum cans had the "star" pattern on the back on the vacuum cans which my 67 205K does.
My 69' engine came with the Solex 30PICT-2 carb with the altitude corrector (smog device) on it.
I've often wondered how many people are running the wrong timing on their distributors because of a vacuum can being changed. _________________ Contact me at [email protected]
The Samba member since 2004.
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Tue Mar 08, 2016 9:36 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
An educated guess would be about 1 in 10 are mismatched, so fairly common. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Tue Mar 08, 2016 9:41 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
That Service Department replacement distributor should have a vacuum canister that delivers approximately 32 degrees of advance and static timed starting at 0 degrees. _________________ Roads Scholar &
Posted: Fri Apr 01, 2016 3:45 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Many of us have been using Progressive Refinements as a near gospel when it comes to dates for various changes to the early Beetle and Bus. I am discovering that at best it is selective in what the author chose to include and that it is not an exhaustive accounting.
In two cases the listing is either incomplete or erronious when it refers to distributors. PR states that the date coding of distributors began in March 1951 (Electrical sec.). This is without a doubt inaccurate as Bosch has been date stamping distributors at least as far back as 1937 and likely further.
PR also states that advance spring revisions are identified by a red paint mark (engine sec. April 1954). The fact is that there were several colors used and each probably referenced a specific revision that has probably been lost to time. Here is an example of an early take off distributor. It is date stamped 12 K or December 1954. The condenser is date stamped 11 K for November of the same year. This distributor has the same condenser installed by the Bosch factory worker 62 years ago and it is still functioning normally by the way. The rotor and points are very likely just as original. The cap is definitely an older version, correct for the distributor vintage, with no logos on the outside. _________________ Roads Scholar &
Posted: Fri Apr 01, 2016 3:48 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
I have seen distributors from 1954 with red, yellow and blue marking's.
While it still functions it remains original/un-restored. _________________ Roads Scholar &
Posted: Sun May 15, 2016 7:23 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
In 1967 Porsche produced 2,178 of the 911 S' models, 360 of those were Targa's. One of the unique parts on those 911 S models from 1967 was the distributor. While the "regular" 911's had distributor # 0 231 159 001 the S models received the 0 231 159 002. A unique feature of the 002's was the badge background being yellow instead of the typical black. Here is one of only 2,178 yellow badged distributors. It does have a kind of golden sheen to it.
Porsche distributors are taller and have a drive gear at the end of the shaft. I'm not quite finished with this one since the pin is peened onto the gear face. These distributors also have an oil port that can be seen on the left side.
The 002 uses the same condenser/bracket as the BR 25, 010 models. They also share the same points. Amazing that even Porsche was still using points as late as 1967 on their top line model.
Looks just like the mechanical advance distributors on VW's except that there are 6 peaks on the cam.
Besides the drive pin I still need to source a distributor cap and find the rev limiting 7300 rpm rotors that I stashed somewhere in the shop.
This exceptional piece stumbled my way in a parts lot with no mention of a cast iron distributor at the bottom of the box. I had to sit down and catch my breath when I found it and turned it over to reveal the yellow badge. _________________ Roads Scholar &
spanky324 Samba Member
Joined: September 28, 2006 Posts: 1070 Location: Greeley Pa
Posted: Mon May 16, 2016 3:48 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Nice piece!! |
Posted: Wed Jul 06, 2016 8:35 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
This piece of machinery fits into all three categories: rare, unique, oddball:
The assembly has three parts a top middle and bottom.
It mounts in the distributor location perfectly but is too short for the stock distributor drive gear. The identifying marks are as follows.
Top: Cog VW 120.17.01.1 The bearing has "Made in Sweden" stamped into it in English!
Middle: Cog VW logo - 5 - 120 -17 - 02 . 1
Bottom: Cog VW logo 120-17-03 .7 - 5
I've searched pretty thuroughly for a date stamp but have not found anything yet.
From this angle you can see that there is a part missing from the assembly. There is no cap or wires present so likely that is what is missing. Note the driven gear facing the left side of the engine.
From this view you can see that there is an adjustment arm. It appears to attach to something.
This appears to be a magneto and/or speed governor from the World War II time period. _________________ Roads Scholar &
Oldfart Samba Member
Joined: March 09, 2008 Posts: 187 Location: Strayliya
Posted: Thu Jul 07, 2016 2:28 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Looks like a governor that aircraft have for constant speed propeller. Any chance it's from a diesel that this thing governs the fuel injector pump? |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Thu Jul 07, 2016 10:06 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
My guess is governor with the adjustment on top. The take-off drives a distributor. Navy? |
Posted: Thu Jul 07, 2016 3:33 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
That drive looks like a magneto coupling |
Posted: Thu Jul 07, 2016 7:09 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Oldfart wrote: |
Absolutely a chance. Any one who recognizes an application is making a good guess. Interesting proposition that a VW engine would have run on diesel during the war. _________________ Roads Scholar &
Posted: Thu Jul 07, 2016 7:29 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Oldfart wrote: |
I would agree,esp since this came with it.
I'm pretty sure that this magneto does not go with the one above. There are no VW stampings and the Bosch logo looks more modern than World War II era. Again, I have yet to find any date stamping. _________________ Roads Scholar &
Posted: Fri Jul 08, 2016 12:12 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Are you sure it's that old? VW engines have been used as aircraft powerplants for a while, the earliest I've seen was a modification to a 25HP.
To me it looks like an aircraft application but normally you don't have constant speed prop/governor on lower power engines such as VW conversions. |
Posted: Fri Jul 08, 2016 6:20 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Oldfart wrote: |
In the first picture above note the VW cog wheel logo? _________________ Roads Scholar &
Posted: Sat Aug 27, 2016 3:59 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Here are a couple of pics of the assembly together.
The distributors in the background are not part of the assembly. _________________ Roads Scholar &
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Sat Aug 27, 2016 9:06 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
The bracket that attaches to the magneto - also is supported by the fuel pump studs?
Would it use a modified pump or at the least a longer rod?
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Mon Aug 29, 2016 1:08 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Hey notchboy, did you notice that we joined TheSamba on the same day/year?
You are member 2066 and I am member 2067. There were only three people who joined on that date. The first member last visited in 2002. _________________ Roads Scholar &
BarryL Samba Member
Posted: Mon Aug 29, 2016 9:02 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
"Seattle", "Running", "Lincoln". and "Kennedy" have the same amount of letters. |
Posted: Mon Aug 29, 2016 9:13 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
tasb wrote: |
You are member 2066 and I am member 2067. There were only three people who joined on that date. The first member last visited in 2002. |
Ha, too funny.
What about?
Would it use a modified pump or at the least a longer rod? |
t3kg wrote: |
1964 1500 S
