MODIFIER Samba Member
Joined: December 09, 2006 Posts: 1560 Location: Summerville SC
Posted: Sat Jun 24, 2017 4:34 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Is this a rare one?
If I recall correctly it's from a type 4 one year only.it spent several years in my sons bug working flawlessly. _________________ Happyasshell
USC USMC DAD OORAH!
ASE MASTER TECH BODY/PAINT and MECHANICAL
62 Beetle
63 Vert
64 Beetle
https://www.facebook.com/SmartFarmServices |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Jun 24, 2017 8:49 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
While not rare that one is for several reasons an oddball and unique. It was installed on 1964 1500 S Type III's. Mid 1964 was a time when Bosch was going through some transitions. It was around that time that they left cast iron production behind and began aluminum bodied manufacturing. This distributor is an example of the last of the cast iron distributors to be installed at the VW factories. Around the same time Bosch changed their part numbering system. Your distributor is an oddball because while being cast iron older production it has the newer part numbering system on the badge. It is likely an aftermarket distributor. The mechanical advance side of the distributor would perform ok in a Beetle but the vacuum canister would only work as designed on the carburetor designed for the 1964 1500 S model. Due to the shape of the vacuum canister it is frequently mistaken as a 36 hp Beetle distributor. The typical badge for this distributor is ZV/JCU 4 R 3. Type IV production was too late for this distributor to have been a stock item. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Sat Aug 05, 2017 4:09 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Shall we venture into the type IV world? Here is a true oddball. It was manufactured in April 1971. Yet, it is a cast iron distributor. Bosch was manufacturing cast iron replacements at this time like the 01 0 and 019. Neither Andy (Glutamodo) nor I have any documentation for this distributor. It's a Bosch: 0 231 040 394 VW# 021 905 205 D. The 021 and 022 designate the distributor as type IV.
The badge is reminiscent of some of the very early Brazilian made cast iron distributors pre- Resolit. The bottom of the housing has very large prominent BOSCH and GERMANY stamps.
The condenser and points are similar to distributors of the 1970's era but look odd installed on a cast iron distributor. The points plate was used on the 050 aluminum distributor.
There are no ozone vents on this distributor. There are two small non threaded holes that must serve this purpose but why this approach in lieu of the usual vents?
Another interesting little mystery is with the rotor. There is no notch for mounting a rotor. Instead there is a hole near the top of the shaft for mounting ?
Was there ever a type IV industrial engine? _________________ Roads Scholar &
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Sat Aug 05, 2017 6:10 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Is for a NSU 1600TT with a inline 4 rear engine. VW owned NSU, it was never used in a VW engine.
I've rebuild 2 of them.
_________________ Glenn
Member #1009
#BlueSquare |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Aug 05, 2017 6:45 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
tasb wrote: |
Was there ever a type IV industrial engine? |
Yes, the type 127, but it appears to use a vacuum advance aluminum unit:
Maybe Wildthings (who's photo I robbed) can tell you what the number is on it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
mr. lang Samba Member
Posted: Mon Aug 07, 2017 3:57 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
tasb wrote: |
Shall we venture into the type IV world? Here is a true oddball. It was manufactured in April 1971. Yet, it is a cast iron distributor. Bosch was manufacturing cast iron replacements at this time like the 01 0 and 019. Neither Andy (Glutamodo) nor I have any documentation for this distributor. It's a Bosch: 0 231 040 394 VW# 021 905 205 D. The 021 and 022 designate the distributor as type IV. |
I couldn't find anything about the 0 231 040 394 and I couldn't find anything about the 0 231 040 ... series at all.
But I found the 021 905 205 D, which is listed as 0 231 129 029, so in the same series as the 010 and 019 distributor, which would explain the similarity.
A quick online search did show almost the same distributor you have posted, but with another label, where the VW number is missing.
My guess is that Bosch did relabel that distributor (like they did many times before) out of not jet known reasons.
The 0 231 129 029 is of type JFR 4 and got it's general approval for production in May 1967.
(side note: the 0 231 129 030, which was the second release of the 010, got it's general approval for production four month later in August 1967)
Part numbers from the Bosch list:
distributor 0 231 129 029 -> VW 021 905 205 D, NSU 68 17 02 524
points 1 237 013 044 -> VW 311 998 063 and NSU 9-8768-17-055 and many others (044 is a general replacement, so could be also one of the following: 1 237 010 044, 1 237 013 051, 1 237 013 074, 1 237 013 090, 1 237 013 096, 1 237 013 106 and 1 237 013 120)
condenser 1 237 330 124 -> no VW number, NSU 9-8768-17-050, Auto Union 987 68 17 050 000
rotor 1 234 332 086 -> no VW number, NSU 68-17-00-987, Auto Union 068 17 00 987 000
cap 1 235 522 033 -> no VW number, NSU 68-17-01-989, Auto Union 987 78 17 058 000 (can be replaced by 1 235 522 031)
(cap 1 235 522 031 -> VW 341 905 207 and NSU 68-17-00-989)
EDIT:
Tim, is this a leading zero in the part number 0 231 040 394 or another character? Looks like a S to me.
And is this a J in front of the FR 4? _________________ 1966 Bus | 1969 Bug | 1976 Passat LX two-door | 1984 Golf 2 C (daily driver)
There are three kinds of people: those who can count and those who can't
Und läuft ... |
Posted: Mon Aug 07, 2017 4:19 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Mr. Lang,
It looked like a Bosch logo but under magnification it is either a 0 or a home made "B".
Appears to be a JFR 4 but not 100% certain since the bottom of the J runs into the silver edge of the badge. _________________ Roads Scholar &
Posted: Mon Aug 07, 2017 4:25 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
The above distributor has a full 30 degrees of advance all in at 2800 rpm. _________________ Roads Scholar &
lightice Samba Member
Posted: Mon Aug 07, 2017 4:27 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
busdaddy wrote: |
tasb wrote: |
Maybe Wildthings (who's photo I robbed) can tell you what the number is on it. |
My friend bought a few NOS industrial type 4s.
He has since sold them off, I did see it 2 years back but cannot recall the distributor.
tasb wrote: |
Mr. Lang,
Appears to be a JFR 4 but not 100% certain since the bottom of the J runs into the silver edge of the badge. |
I think Glenn answered your question. |
Posted: Mon Aug 07, 2017 4:31 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
mr. lang wrote: |
tasb wrote: |
EDIT:
And is this a J in front of the FR 4? |
Interesting bit of information there. I've seen this distributor number as VW# 211 905 205 F which is incorrectly listed on Theoldvolkshome website as a late 40's early 50's distributor but the badge is very obviously from the late 1960's. There's a pic of one near the top of page one of this topic. _________________ Roads Scholar &
Posted: Mon Aug 07, 2017 4:37 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
lightice wrote: |
busdaddy wrote: |
tasb wrote: |
tasb wrote: |
Mr. Lang,
Glenn could very well be right but I have looked for documentation and have not found any evdence that it was used for NSU. _________________ Roads Scholar &
Posted: Tue Aug 08, 2017 3:07 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
could be B231040394 then
the search in the bosch archive for B231040394 did tell me, that this could be a racing part and did direct me to the bosch motorsports web side ( http://www.bosch-motorsport.com ), but my search there resulted in no results.
the search on google did show up a few ebay links and comments about Formula Super Vee and did show other B231040394 / 021905205D units.
I checked out wikipedia ( https://en.wikipedia.org/wiki/Formula_Super_Vee ) and found this:
Quote: |
Initially the series allowed 1600cc air-cooled engines of either type 3 (as used in the VW 1500 and 1600) or type 4 (as used in the VW 411, 412 and the VW-Porsche 914/4 sports car), however at a late stage VW had a change of heart and decided that the type 4 engines would be a better option. The type 4 engine is without doubt a better engine. However, this motor was never produced in a 1600cc version so VW decided to produce a "special" 1600cc version through their industrial engines division (the 127V unit), with smaller pistons and barrels, which reduced the capacity to 1600cc. |
So could be possible, that this distributor was used on a 1600 type 4 industrial engine 127V used for racing in the formula super vee series.
But I wasn't able to find any images or documents or the like to back up that information.
EDIT (2 hours later):
Well, I found the parts list for the VW type 127V engine
http://www.myf5000.com/files/svparts1974.pdf
See pdf page 17, part 22:
22* Distributor 021 905 205 D
I'm still positive, that the B 231 040 394 is a relabeled 0 231 129 029 (to give it a VW parts number) _________________ 1966 Bus | 1969 Bug | 1976 Passat LX two-door | 1984 Golf 2 C (daily driver)
Und läuft ... |
glutamodo The Android
Joined: July 13, 2004 Posts: 26320 Location: Douglas, WY
Posted: Tue Aug 08, 2017 4:46 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
a few various odd comments about this latest oddball:
Ugh, when tasb asked me about this, my first thought was, in fact, "Industrial" but didn't even consider racing/Vee - the irony is, I have a different version of that same parts list saved on my computer so I could have at least found that reference had I only thought to look there.
I found it kind of odd that this distributor suffix letter was skipped in the Type 4 parts book.
When Tim first asked me, he had yet to discover the locating hole for the rotor, and at that point he thought the rotor had no way to index, which seemed bizarre to me. But then the hole was discovered, but still seems to me an odd way of indexing. Then Glenn mentioned 1600 NSU, which were only listed as 1200s and smaller in my books, but the 1971 was shown using the aforementioned 0 231 129 029 distributor, and I did try to find an image of the rotor used on it. I have some Bosch parts books that include photos of various parts but this rotor is only shown from above in them, so no help there. I found some images online that showed it from the side and bottom, but whatever keys into the hole in the center shaft is not easily seen. https://www.oldtimer-yemodia.de/divers/9042-Rotor-Verteilerfinger-Bosch-Nr-1234332086.html _________________ Andy T.
Posted: Tue Aug 08, 2017 3:01 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
So looks like the possible applications for this distributor are type IV for racing purposes or stock for NSU 1200TT. Here is the curve data:
RPM degrees advance at crank
800 0
1000 5
1200 4 (problem here!)
1400 6
1600 9
1800 13
2000 16
2200 20
2400 24
2600 28
2800 30
3000 30
I need to disassemble due to the low rpm advance issue. I'll have a look at the weights and see how they compare to an 010, 019 (129) weights assembly. with a full 30 degrees of advance I'd expect the weights or springs to be different. _________________ Roads Scholar &
Posted: Tue Aug 08, 2017 6:46 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Well, the advance assembly does look familiar (129) The weights are a single layer and symmetrical similar to Porsche distributors. The 010 has one weight that is single and another that is two layers while the 019 has asymetrical weights. The weights number is 000. The points cam is # 550 and the springs are the same as those used with the 010. The points cam, shaft is the newer design (thankfully) that uses a screw instead of that pesky spring clip.
After disassembly I can confirm without any doubt that this distributor is NOS. After cleaning and relubrication, running on the Sun Machine the advance wobble at 1000rpm has been resolved. It now holds steady at 4 degrees of advance from 1000-1200 rpm and the total advance is now 26 degrees leaving some room for BTDC static timing. The condenser is date stamped 133 which is first quarter of 1971 for an April of 1971 distributor. Note how thin the original paint is. Those of us who restore these overdo it to keep y'all happy. _________________ Roads Scholar &
Posted: Tue Aug 08, 2017 9:34 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Thanks goes out to Wildthings, lightice , Glenn, Mr. Lang and Glutamodo for their experience and research, this was an interesting contribution.
I have another one coming soon. _________________ Roads Scholar &
Posted: Fri Aug 11, 2017 2:45 pm Post subject: Re: Rare Unique and Oddball stock ignition distributors |
This distributor model has been featured before in this topic but this particular one has something added to it that makes it unique. These used to be known as the "VW distributor" on account of the VW logo being found all over it. If you come across a low mileage unit even the tune up parts have VW logo's on them. They are commonly called out by an early bus distributor with the VW# 211 905 205 271 (A or B).
That's not the distributor number it's the number of the actual vacuum canister that the number appears on. It's also been called a 211 905 247 as that's what's on the drive dog but, again that's the number for the drive dog not the distributor.
The distributor is identified correctly by a sticker that the maker Garbe Lahmeyer GmBh applied to the housing. The sticker in most cases was either worn or fell off of the distributor. some common ones are 113 905 205 B,L,J and much rarer 211 905 205 B.
What sets this one off is the stamping on the bottom side of the housing. The early ones had a 3 digit date stamp on them but, these later vaccum advance GL's have never had a date stamp that I'd noticed after handling maybe 75 of these. This one has a stamping:
It's VU 405-20-0. V= verteiler = distributor U= unterdruck = vacuum. If its a date code next it would be 4th day of fifth month or 4 May since in Europe they use the system day/month/year as opposed to our month/day/year system. What then do the 20-0 represent? If we drop the day leaving month and year it would be April and the year 05 which means? It might not be a date stamp at all, the answer may be lost to time. It's been suggested that at least in the early stages of production that these were intended for German domestic vehicles only. In the 1960's lot's of them made it to the states. _________________ Roads Scholar &
klubbs Samba Member
Posted: Wed Oct 11, 2017 7:34 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
I have a nos 36hp industrial engine with a waterproof distributor and coil
Zv/Jam 4r9 Distributor
Is the curve on this one any Good for driving on the street?
Posted: Wed Oct 11, 2017 11:16 am Post subject: Re: Rare Unique and Oddball stock ignition distributors |
Somewhere in the topic I have one of those featured. I will have to pull it out and run it on the Sun Machine. Not sure what the curve is but it can't be any worse than the 0 231 178 009
Don't forget the coil has extra shielding too.
I seem to recall that there was some suggestions that these may have been run on military issued cars which suggests that they could have an acceptable curve for the street. _________________ Roads Scholar &
DONGKG The Araneta Boys
Joined: August 28, 2006 Posts: 5475 Location: Cainta, Rizal, Philippines, "A Certified Type 3 and Karmann Ghia Maniac"
Posted: Wed Oct 25, 2017 3:52 am Post subject: |
norcalmike wrote: |
i have 2 of these with the number ending in 030. i didnt know they were anything special. had 3 but sold one . is there any difference between this one and any other 010s? |
I have one like this that I installed on my KArmann Ghia 'vert.
This one:
At first I was confused whether it was a 010 or a 030. I made my research and found no Bosch distributor called "030." Reading this thread really gives me ocean of information on the unique distributors that were used by Volkswagen all those years.
Thanks,
DongKG _________________ '67 KG Cabrio (Mickey) ;
'66 Type 3 (Sharky 2)
'72 Type 2 Homey
'67 Splitty Bus
'65 beetle;'69 Country Buggy; '44 Kubelwagen (replica) TOOB MEMBER #20 |
