Notablecarrot3 Samba Member
Joined: January 22, 2008 Posts: 461 Location: Sunny South Of France
Posted: Fri May 04, 2012 5:47 am Post subject: Shaking at speed |
Hi guys,
When I drive my bug I get a rough patch between roughly 2500 and 3500 revs (no rev counter sorry). It feels almost like the car's only on 3 cylinders and makes the car shake really badly at about 55mph in 4th.
If I accelerate through this it sits at high revs ok, low revs also are fine.
When I put the clutch down it stops immediately.
Since this problem I have changed both tranny and motor (stock 1200) for various reasons.
I had this shaking problem with my last motor. The only parts I have swapped over from the old one are distributor, coil, leads, carb (31pict), fuel pump and alternator.
I have tried a friend's HT leads and it made no difference.
Any ideas? _________________
EverettB wrote: |
Your Donkey has a large head. I like your donkey. |
EverettB wrote: |
Is it wrong to be jealous of their facial hair abilities? |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Fri May 04, 2012 6:50 am Post subject: |
Any chance you also reused the clutch?
Did you use a matched set of bolts to attach the pressure plate to the flywheel? Even a very small difference in those bolt weights can cause a lot of imbalance to the rotating assembly. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Fri May 04, 2012 7:00 am Post subject: |
I reused the clutch mechanism but changed the plate.
I've only had the problem for a few months and before that I had no problem at all so it is something the car has developed...
It feels almost electric to me, it really feels like the car isn't firing on all 4 cylinders at certain revs. _________________
EverettB wrote: |
EverettB wrote: |
JerryMCarter1 Samba Member
Joined: January 07, 2007 Posts: 6199 Location: N.W. Phoenix
Posted: Fri May 04, 2012 2:07 pm Post subject: |
any chance you can get the car on a scope ? _________________ Experience always triumphs over hearsay and You get to select which theory to believe |
