coolerthanelvis Samba Member
Joined: June 30, 2003 Posts: 924 Location: San Diego, CA
Posted: Thu Mar 22, 2018 4:19 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
What about getting some early split bus rims? 15" with wide 5 bolt pattern. Readily available. _________________ Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Thu Mar 22, 2018 6:17 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
Won’t work because he has disc brakes from a 72 with the smaller bolt pattern. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Hikelite Samba Member
Joined: August 31, 2012 Posts: 557 Location: Colville, WA
Posted: Thu Mar 22, 2018 6:31 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
coolerthanelvis wrote: |
What about getting some early split bus rims? 15" with wide 5 bolt pattern. Readily available. |
Thanks. Did I forget to mention I already bought 5 new 14" RA18s?
A 15" wide 5 would work, but it wouldn't be 'original'. I went and tried to see what splitty wheels looked like. I can't tell, but it doesn't look like they have the 4 slots like mine. The hubcaps looks different.
If I switch to a 15" wheel, I think anything would work as long as it didn't start hitting the body or suspension.
He tried a T3 wheel too. It was better, but still was hitting the caliper.
This isn't anything that unusual. People widen bug wheels to get bigger tires on the rear. Others have changed offsets to accommodate different ride heights and wheel/tire combos.
I appreciate the feedback. I'll post an update once the wheels are done. _________________ ~Kevin
My 1968 Campmobile |
Zed999 Samba Member
Posted: Fri Mar 23, 2018 3:15 am Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
Great thread. I've done this servo addition to half a dozen buses including a 68 with stock drums. I have to say the 68 drum brakes with servo was "better" than the disc/servo ones. Very light pedal with drums as the non-servo drums were excellent to start with. I used the Brazilian servos, as I was also making the beam brackets the fixing holes being different wasn't a problem and the servos are an inch smaller which helps the handbrake cable situation. I also wired the cables together, it didn't take much to clear the servo.
Without a servo, disc brake buses have appalling brakes, it's a wonder that they were sold that way but cheapskate UK is stuffed with them as we have a lot of (originally) 1600 T1 powered buses here and the servo I think was only standard on T4 powered ones.
When I retro fitted both a T4 engine and servo to my 74, I out-witted myself by using an original balance/servo vacuum pipe and hooked it up to one manifold tube each side. Tidy install I thought as I patted myself on the back, but as my carbs are dual barrel drla this played havoc trying to balance them with a 4-way vacuum gauge and would also give a false reading on a snail type gauge. Now it's just plugged into one and the other is an untidy blocked up thing as is the spare end of the balance tube. Doh! |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Mar 23, 2018 6:55 am Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
You don't need to feed the servo vacuum from both sides of the engine. Once started and the vacuum drawn, there isn't much or any flow so the dual carbs aren't affected during driving. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Zed999 Samba Member
Posted: Fri Mar 23, 2018 12:24 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
aeromech wrote: |
You don't need to feed the servo vacuum from both sides of the engine. Once started and the vacuum drawn, there isn't much or any flow so the dual carbs aren't affected during driving. |
Yeah, I know, but the original pipe with the T off through the tin for the servo is so neat and tidy I couldn't resist. |
Posted: Fri Mar 23, 2018 12:59 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
Zed999 wrote: |
aeromech wrote: |
Maybe but I think you found out it doesn't work well, at least with your carbs. Kadrons have a balance tube. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tcash Samba Member
Posted: Mon Jun 18, 2018 6:18 pm Post subject: Adding vacuum nipple to intake manifold for power brakes. |
Adding vacuum Nile for brake booster
The best way is to weld on Bung.
Posted: Mon Jun 18, 2018 6:21 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
That wall is pretty thin. I hope it holds. I usually have a plug welded to the wall to add some girth for the fitting _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tcash Samba Member
Posted: Mon Jun 18, 2018 6:27 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
aeromech wrote: |
That wall is pretty thin. I hope it holds. I usually have a plug welded to the wall to add some girth for the fitting |
Just added a pic with a Bung as you where posting.
Great minds think alike, or mud minds, one or the other!
Tcash |
Posted: Mon Jun 18, 2018 6:41 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
Just so anyone looking at this wonders.... the plug welded on only needs to be about 3/8 thick _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tcash Samba Member
Posted: Mon Jun 18, 2018 7:42 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
aeromech wrote: |
Just so anyone looking at this wonders.... the plug welded on only needs to be about 3/8 thick |
9.5250 mm for a 12 mm hose. Please explain?
Thank you
Tcash |
Posted: Mon Jun 18, 2018 7:48 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
Okay, my welder uses a hole saw. Maybe 1 1/2 inches in diameter. He cuts a plug out of plate aluminum maybe 3/8 thick. Then welds it to the wall of the intake manifold. Now that wall is closer to 1/2 inch thick. Drill and tap for 3/8 NPT. Install fitting. Sizes are approximate. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tcash Samba Member
Posted: Mon Jun 18, 2018 9:00 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
Then you step up from 3/8" to what like 1/2" to except the 12mm hose?
Thank you
Tcash |
Posted: Mon Jun 18, 2018 11:06 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
The fitting I use is 3/8NPT on one end and -8 AN on the other. The hose is 15/32” ID so close to -8 that it works with the Parker Pushlok female hose end.
I can provide pics tomorrow if you want Tim. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Thu Jun 21, 2018 8:28 am Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
Some pictures
This is a fitting added to a stock intake manifold to supply vacuum for a booster
I put a booster in this 1968 DC and added a fitting to the left side manifold
Here's a pic showing the gates vacuum hose (27231) attached to the Parker -8 Push-Lok fitting
https://www.oreillyauto.com/detail/b/gates-3728/pe...31/4330548
This pic shows the bung welded to the thin wall of the Dellorto manifold being tapped for 3/8NPT
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Jade Samba Member
Joined: April 20, 2004 Posts: 63 Location: Houston, TX
Posted: Fri Dec 30, 2022 6:33 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
Reviving an older thread here. I did my conversion on my '66 bus about 22 years ago using Wolfgang adapters, '75 brakes, and a bracket we fabbed together. The M/C was leaking into the booster so it was time to refresh everything.
The booster I got has a slightly different bolt pattern. It worked out well because it's rectangular instead of square spacing between the studs so easier to get to when the nuts are tightened down. I powder coated as many of the components as I could.
One question I have, what the tube on the booster on the opposite side of where the M/C mounts? A vent? I just pointed it down so water can't collect in there.
_________________ '66 11 window |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Dec 30, 2022 6:40 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
Jade wrote: |
One question I have, what the tube on the booster on the opposite side of where the M/C mounts? A vent? I just pointed it down so water can't collect in there. |
Atmosphere vent, it really should have a hose on it that can suck clean air from somewhere, VW routed it into the fender cavity, but anywhere it can breathe clean air without road grit or splashes is fine.
Every time you brake it takes a gulp of air, there's a felt filter on the inlet under the boot (should be), but the less crap it eats the longer it'll last. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Jade Samba Member
Posted: Sun Jan 01, 2023 10:10 am Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
Excellent, thanks. Will put a filter on it. _________________ '66 11 window |
Posted: Sun Jan 01, 2023 2:44 pm Post subject: Re: How to: Install power brakes into 1968-1970 Bus (Pic heavy) |
I’ve used something like this before
https://www.knfilters.com/62-1600rd-l-vent-air-filter-multi-lingual _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
