Fastmatt Samba Member
Posted: Wed Aug 27, 2003 8:31 pm Post subject: What is this thing in the case? |
Folks,
Just cracked the case tonight while rebuilding the 1600 on my 67 Fasty, and found a piece down in the primordial oil that I can't identify (and a trip the fountain of wisdom - Muir - doesn't seem to help either). It's a black rubber plug with a hole in it - 3/4 inch long, 5/8 inch diameter, hole is about 1/8 inch diameter...any ideas?
Fastmatt |
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Thu Aug 28, 2003 9:58 am Post subject: |
Yep...I have a feeling that there is a big German mechanic somewhere who is still chuckling about leave this thing in the case... |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Fri Aug 29, 2003 12:01 am Post subject: |
LOL@ Fastmatt. Yeah, I thinl you are right. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Sat Aug 30, 2003 6:26 pm Post subject: |
Check Your Dipstick. i did the same thing, pulled my motor out and forgot to remove the dipstick. the rubber piece came off and i found it when i split the case, except for i found globs of metal too. |
QWKDTSN Samba Member
Posted: Sun Aug 31, 2003 7:07 pm Post subject: |
I'd be willing to bet it's that dipstick rubber plug. What the heck is it for, anyway? |
nik Samba Member
Joined: February 13, 2003 Posts: 849 Location: 1 block away
Posted: Mon Sep 01, 2003 2:58 am Post subject: |
I have no idea but I had to zip tie mine on to the stick so that it wouldn't keep sliding down to the bottom of the stick and not allowing me to see the oil level.
nik |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 33875 Location: Conejo Valley, CA
Posted: Wed Aug 08, 2018 11:07 pm Post subject: Re: What is this thing in the case? |
Reviving a really old thread (one month shy of 15 years!), but I didn't see it mentioned elsewhere...
What I presume is a vibration damper on the dipstick slides down to the bottom on mine. It always has, but since it's going on 45 years old or so, maybe it's worn? Is it supposed to slide freely to near the bottom, or should it stay partway up; and if so, how far up?
I notice it now, because with an external full flow, I add more than the stock oil amount, and so after a long rest, and the oil drains back a bit, I typically have a higher than stock dipstick reading. That "thing" gets in the way of a proper reading now. |
nogoodwithusernames Samba Member
Joined: November 10, 2014 Posts: 598 Location: CA, USA
Posted: Thu Aug 09, 2018 8:39 am Post subject: Re: What is this thing in the case? |
KTPhil wrote: |
Mine stays put about half way up, never noticed it move at all. Super glue it? _________________ 71 Squareback, 1.7l T4 w/ crank trigger fuel and spark
(Conversion thread https://www.thesamba.com/vw/forum/viewtopic.php?t=732508&highlight= or https://shoptalkforums.com/viewtopic.php?f=1&t=151375&sid=f0542d44a322d290c29d6609fac7f215 )
74 914, 2.0L w/ D-Jet
-Derek |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22356 Location: Kimball, Mi
Posted: Thu Aug 09, 2018 1:38 pm Post subject: Re: What is this thing in the case? |
nogoodwithusernames wrote: |
KTPhil wrote: |
Mine stays put about half way up, never noticed it move at all. Super glue it? |
Agreed. Mine sit about half way up the stick. I suppose you could bugger a section of the tube to give the rubber bit something to bite into, and either super glue it in place, or use RTV to hold it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
