scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
c21darrel Samba Member
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Tue Jul 31, 2018 4:09 pm Post subject: Re: 1971 ghia build |
Well, now; so how does this clean bear run?
My guess as to the rear floor mats is that the left one was for a '68 or earlier Ghia that had the seat rails spaced farther apart than '69 and on. Right one is '69 or later so that the indent is for the closer-spaced rail.
oldtimercraiova Samba Member
Posted: Thu Oct 11, 2018 3:03 pm Post subject: Re: 1971 ghia build |
Nice project! |
Disc Samba Member
Joined: September 24, 2009 Posts: 558 Location: Europe
Posted: Fri Aug 27, 2021 3:04 am Post subject: Re: 1971 ghia build |
scotty timmerman wrote: |
went to a dyno day today. $40 for 3 pulls. the ghia made 115 hp @5800rpm and 119 ftlbs of torque @4200rpm
Would you post the spec of the engine please? _________________ The glory never gets old, just need new paint.
Nick |
Posted: Fri Aug 27, 2021 7:12 am Post subject: Re: 1971 ghia build |
Disc wrote: |
Would you post the spec of the engine please? |
This was a 2109cc. 76mm welded crank, 94mm mahle pistons/cylinders, stock 311b rods, lightened flywheel, as41 case full flowed/welded behind #3, 30mm oil pump, berg deep sump, external oil cooler, w130 cam, light weight lifters, chromoly push rods, 1.1:1 stock rockers, berg elephant foot adjusters, berg bolt together rocker shafts, 42mmx37.5mm welded and ported vw heads, dual springs/chromoly retainers/hardened keepers, dual 40mm DCNF carbs with 36mm vents, 009 distributor with pertronics. Compression IIRC was around 8.5:1. _________________ 71 ghia coupe: Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=511738&highlight=
71 type 3 fastback auto
71 type 3 fastback manual
73 super beetle
57 oval: build thread: https://www.thesamba.com/vw/forum/viewtopic.php?p=8616563#8616563
63 beetle reassembly: http://www.thesamba.com/vw/forum/viewtopic.php?p=7458619#7458619
2332cc engine build: https://www.thesamba.com/vw/forum/viewtopic.php?p=8608429&highlight=#8608429
84 vanagon westfalia wolfsburg edition |
Disc Samba Member
Posted: Fri Aug 27, 2021 10:48 pm Post subject: Re: 1971 ghia build |
Sounds impressive! Just wanted to know what it takes to make such power out of Type 1 engine, cause Type 4 have the volume as default, needs just some of the ingredients to reach similar or higher power figures. _________________ The glory never gets old, just need new paint.
Nick |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3818 Location: Georgia
Posted: Tue Sep 27, 2022 2:50 pm Post subject: Re: 1971 ghia build |
I guess you can say I restored mine too.
My DMV said I couldn’t paint it but I asked a cop that lives in the neighborhood and he said that as long as it’s still reflective at night it shouldn’t grab anyones attention. So I masked off the characters and painted it to match the car.
I’m still waiting for a ticket. _________________ Volkswagen!
(Compression 8.7:1) |
