Ratt Samba Member
Joined: April 15, 2003 Posts: 753 Location: Puyallup, Wa
Posted: Mon May 14, 2012 8:51 pm Post subject: clucth issues with motor swap |
I have searched the forums and cant find mch. Ive got a 66 bus that I'm using the motor from my Thing. So ive got the early transmission (no removable cone). Ive got the clutch and pressure plate from the Thing. Can I use that plate with this transmission? If so what throw out bearing do I use? Or do I need to get an early pressure plate with the ring on the finger springs to use with an early throw out bearing?
Thanks for any help. This is really the last thing keeping my bus off the road(with the exception of my safari windows...)
Andy |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon May 14, 2012 8:56 pm Post subject: |
Kind of depends on the transaxle in the bus. If original you need the latter. If someone installed a later transaxle the former will work if all the parts are there. _________________ In Stereo, Where Available! |
Ratt Samba Member
Posted: Mon May 14, 2012 9:02 pm Post subject: |
Its still the early transaxle. Early ones don't have the removable cone around the output shaft, right? |
Posted: Mon May 14, 2012 9:16 pm Post subject: |
Correct! _________________ In Stereo, Where Available! |
Ratt Samba Member
Posted: Mon May 14, 2012 9:24 pm Post subject: |
Ok last Newb question. Ive got a 200mm flywheel. Will the 200mm plate from a 67 bus with the collar work, or do I need to source a new flywheels? |
Posted: Mon May 14, 2012 9:38 pm Post subject: |
200 mm is 200 mm and will work just fine. Just do not mix 180 mm equipment with 200 mm stuff or visa versa.
Some of the new clutch discs rub on the inside of the PP ring, and have to be ground a tad on the disc center that the input shaft passes through. _________________ In Stereo, Where Available! |
tyzel Samba Member
Ratt Samba Member
Posted: Mon May 14, 2012 9:47 pm Post subject: |
Thanks for the help! That link is a big help too. |
