Adding a second battery..how to...with photos FAQ
Vince Waldon
Vince Waldon is offline
PostPosted: Mon Jul 15, 2013 10:49 am    Post subject: Reply with quote
My suggestion: make a list of what you want your house battery to be for... and then wire accordingly.
IE: What things do you want to run when parked for the night? Stereo? Dome light? tach? oil pressure gauge?
Whatever the list is... those are the things that are wired to your house battery (thru a fuse panel, of course) and will be able to draw power when the ignition is off and the engine is not running... by design. Smile
When the engine is running both batteries are essentially in parallel with all of the loads. It's when you turn the key off that the magic happens...hence the importance of the list.
DougB
DougB is offline
PostPosted: Mon Jul 15, 2013 11:42 am    Post subject: Reply with quote
I'd love to do the same, but my aux battery wiring kit has been on order from German Supply for 2 months. I need to call them and find out what's up...I'd love to get that and the other pieces I ordered sooner rather than later. At this point it's almost difficult to even remember what I ordered.
locky
locky is offline
PostPosted: Mon Jul 15, 2013 12:23 pm    Post subject: Reply with quote
Thanks for the replies guys. I am clear on all of it now. If I were to install one of these http://www.bluesea.com/products/category/Manual_Battery_Switches/m-Series
In line with the ACR
http://www.bluesea.com/products/7610/SI-ACR_Automatic_Charging_Relay_-_12_24V_DC_120A,
could I switch off power to my second battery when I didn't need it. ie: when I had it parked in shop not driving for days? This way all power to accessories is off until I need it.
This is the fuse block I bought
http://www.bluesea.com/products/5026/ST_Blade_Fuse_Block_-_12_Circuits_with_Negative_Bus_and_Cover
Westy Steve
Westy Steve is offline
PostPosted: Mon Jul 15, 2013 1:02 pm    Post subject: Reply with quote
Interesting stuff. Assuming I get my bus running pretty soon, I'm going to be working on my interior. I was just going to put a marine battery in the back and wire the two batteries together, but then wire up a disconnect switch like they use for boats so that I could isolate the marine battery manually by turning a key. Then I was going to run a bunch of cigarette lighters through my "walls" that connect to the marine battery only. I was also thinking of mounting a plug in trickle charger into my Westy's wiring that would route a trickle charge from the Westy's shore power to the battery. So when I'm on shore power, it would keep the marine battery topped off. Lastly, I was thinking that I'd have a solar cell that would power a trickle charger to the marine battery. I don't think any of these would conflict with each other, but I don't know if it's bad for a marine battery to apply a constant trickle charge to it...will it get a memory?
I'm guessing the auxillary fuse near the ignition switch would do the same thing, but I was hoping to minimize wire length by essentially keeping the key turn/isolator in the back of the bus where the power is.
Steve
I. can. drive. '55!
'55 Oval Survivor
Tristan79
Tristan79 is offline
PostPosted: Wed Jul 17, 2013 11:16 pm    Post subject: Reply with quote
grandpa pete wrote:
AEROMECH; I put the fuse block next to the battery for the tutorial ,it isn't even hooked up. I didn't wan't to confuse the issue by showing how i ran 3/4 inch flexible conduit through the rear tire wheelwell to a custom made box inside with the inverter and the fuse pannel. The inverter is hard wired direct to a double outlet box in the wall with the faceplate painted orange so you know it is inverter voltage and not shore power like the unpainted one next to it. The pump for the sink works now too
How did you wire the wall outlet? Could you also just explain what the two different ones are for, thanks
Brian
Brian is offline
PostPosted: Thu Sep 19, 2013 11:33 am    Post subject: Reply with quote
Wouldn't having two batteries on one alternator just be terrible for a 55amp alternator's lifespan?
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
telford dorr
telford dorr is offline
PostPosted: Thu Sep 19, 2013 3:41 pm    Post subject: Reply with quote
Theoretically, no.
An alternator is inherently current-limited by nature (that's why there's no current detection in the regulator, unlike with a generator). Assuming it has sufficient cooling air, it should be OK.
But, like they say, "In theory, theory works in practice; in practice, it doesn't." I suspect that if you ran an alternator continually at full rated current, its lifespan would be substantially shorter than under a normal automotive load. That said, I suspect that a typical dual battery setup is no harder on an alternator than a single battery - if you don't continually (like everyday) run the second battery low or dead.
'71 panel, now with FI
To steal ideas from one person is plagiarism; to steal from many is research - Steven Wright
All models are wrong; some are useful - George Box
More VW electrical at http://flowcon.us/td/ (available 9am to 9pm PST)
grandpa pete
grandpa pete is offline
PostPosted: Thu Sep 19, 2013 5:34 pm    Post subject: Reply with quote
How did you wire the wall outlet? Could you also just explain what the two different ones are for, thanks[/quote]
The all white outlet is wired directly to the external "shore power "...The outlet with the orange paint on it is hooked to the inverter and provides limited 110 volts off the camping battery
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
JQ1492
JQ1492 is offline
PostPosted: Tue Jul 01, 2014 7:38 am    Post subject: Reply with quote
Interesting post. I have a 77 camper, but the wiring for the 2nd battery is messed up. I think I can fix that based on this post, but have a couple questions:
1) I have an Edgestar 630 high efficiency fridge. Can I run it off the 2nd battery indefinitely while I am driving, since the batteries are being recharged as I drive?
2) I have a Goal Zero solar panel with inverter and wonder if there is a way to use that to help recharge the 2nd battery while parked.
3) The manual says that while the primary battery will not be drawn down by tapping the second, when you start the bus, it will split the ignition draw between the two batteries and may not have sufficient power to start the engine. Will this issue be fixed by rewiring as directed above? I'm assuming it will be, (why else go to the trouble), but wanted to make sure.
Thanks for helping a newbie!
aeromech
aeromech is offline
PostPosted: Tue Jul 01, 2014 11:20 am    Post subject: Reply with quote
I think so. The way it SHOULD work is that when parked, the batteries are separated. You can wire the fridge to run off the house battery. When you start the engine and voltage increases about 13 volts, that should cause the ACR to close and connect both batteries to the bus charging system (alternator). In transit, the aux battery feeds the fridge but is also being charged at the same time by your engine.
Of course. Here's a picture of a charging panel sold by GoWesty. One of my customers has this and it's pretty cool. Not sure if you need to buy the whole package that includes the solar panels to get this or not.
http://www.gowesty.com/ec_view_details.php?id=23897&category_id=&category_parent_id=
The systems I install using the Blue Sea ACR keep the batteries separated for roughly the first minute when the engine starts. All the power for the ignition and starter comes from the start battery. Most of the systems include the battery switch which allows you to easily COMBINE both batteries for engine start if the start battery gets low.
I really can't imagine why anyone would want to install a dual battery system any other way. The Blue Sea "add a battery" kit is available for less than $150. Most guys would spend way more than that on their stereo.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
chachi
chachi is offline
PostPosted: Wed Jul 02, 2014 6:31 am    Post subject: Reply with quote
Desertbusman wrote:
6) A low drain evaporative cooler
i am looking for something like that. do you have a little more information on the one pictured?
'74 transporter panel
'91 vanagon carat NAHT
grandpa pete
PostPosted: Fri Sep 05, 2014 9:18 am    Post subject: Reply with quote
Hey DBM !! are you gonna answer this guys question ?? Razz Very Happy
63 two fold rag
aeromech
aeromech is offline
PostPosted: Fri Sep 05, 2014 9:28 am    Post subject: Reply with quote
Pete,
Mikes been MIA for a bit
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
grandpa pete
PostPosted: Fri Sep 05, 2014 5:02 pm    Post subject: Reply with quote
Chachi ; Just talked to DBM.. that unit is no longer produced anywhere
Aeromech : Hi! thks for jumping in....I called Mike ; The old faht is doing fine ; just taking a break from Samba.....quitting cigaretts after 74 years is making him grouchy Very Happy Very Happy
63 two fold rag
aeromech
aeromech is offline
PostPosted: Fri Sep 05, 2014 5:30 pm    Post subject: Reply with quote
Fixed it for ya
quitting cigaretts after 74 years is making him grouchyer
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
babysnakes
babysnakes is offline
PostPosted: Fri Sep 05, 2014 5:37 pm    Post subject: Reply with quote
Hey! Don't diss DBM, I had a great lunch and a good time with him a few weeks back. He's not grumpy, he's..................DBM. Very Happy
Brian
Brian is offline
aeromech wrote:
Fixed it for ya
Laughing good for him though.
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
aeromech
aeromech is offline
PostPosted: Fri Sep 05, 2014 5:38 pm    Post subject: Reply with quote
It's no diss. Just stating fact. I'll be there soon myself since I'm 57.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
babysnakes
PostPosted: Fri Sep 05, 2014 5:41 pm    Post subject: Reply with quote
I'm six years behind ya, so watch out!
aeromech
aeromech is offline
PostPosted: Fri Sep 05, 2014 6:04 pm    Post subject: Reply with quote
You're making me grumpy
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Page 4 of 10
