Mr. Okrasa Original Old Speed
Joined: May 20, 2000 Posts: 726 Location: Eastside, Costa Mesa. So. Califas...Loco's ;-)
Posted: Fri May 18, 2012 2:31 pm Post subject: New "SOLEX" 32mm Carburetor Woes / Rough Idle!! |
Has anybody else experienced rough idling/stubbling, carbs wont synch, etc, etc with the new immitation "SOLEX" 32mm carbs that are coming out of China/India? Part of problem is because of the loose/sloppy throttleshafts. When they bore the carb for the throttleshaft, the bore is too large and allows air to bypass through the throttleshaft bore. This causes uneven idling, stubbling, "hunting", etc, etc. I solved this problem by installing silicone impregnated bronze bushings and removing the white plastic "O" rings that I think are there to make up for the sloppy bore! Once the bores are sleeved and reamed to the throttleshaft dimentions, you elimate the possibility of air "seeping" bypass this area hence much more imporoved engine performance! See this link below that shows detailed photos. Enjoy! Mr. Okrasa
http://ImageEvent.com/mrokrasa/carburetorssolexzenithweber/newsolex32mmrebush _________________
See my Instagram: https://www.instagram.com/okrasa/
1959 VW Karmann Ghia Coupe / Bamboo-Green / Denzel 1300cc / OG. owner, paint
Denzel engine running. See this link: https://youtu.be/DgUlsQDTXTE
VW www.Okrasa.com
356 www.PreA356.com |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Fri May 18, 2012 2:45 pm Post subject: |
Hello-
You mentioned that part of the idling problem is related to the way the throttle shafts are mounted. Are there any other common problems we should know about?
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Fri May 18, 2012 2:53 pm Post subject: |
Joe, what are you doing to keep the throttle shafts center IE butterfly. I have found on the sets I've done that you can not really tighten the linkage pieces or it will pull the shaft/butterfly one way or the other and cause them to bind.
I made some brass spacers to prevent this. Luckily I haven't had any with loose shafts except maybe one on my Bonneville engine has started to seep a little from the shaft now! But still starts and idles smoothy. _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Flavio Samba Member
Joined: May 14, 2008 Posts: 414 Location: Madeira Island, Portugal
Posted: Sat May 19, 2012 3:57 am Post subject: |
The same problems with mine...
After a friend machinist installed new brass bushings, (using some old VW valve guides) they became much better in respect to idling and also transition.
About the In and Out shaft play, that I think Splitpile is refering to, I've done nothing about it because with mine carburetors the described in/out play only "happens" when the throttle is almost fully open and also when fully open. I've considered that this is not a too bad thing... am I right about this ?
BTW, another thing: comparing the original jeting 32 Solex with this Indian copies, I've noticed that the small Idle Air Bleed is a 160 jet but the original has a 100 jet (1 mm). I've tried to put a 100 jet there...no way...too rich.
Also, I've found that the carbs work better with a 24 mm. venturi and a 120 or 117 Main jet.
Testing yet to find if a 45 idle jet is better than the stock 50.
Note: my engine has stock 36 Hp crank and cam. |
Posted: Sat May 19, 2012 8:43 am Post subject: |
gimmesomeshelter wrote: |
Hello-
Cheers,
Paul |
Paul
My first impression of the carb was pretty good until I wiggled the throttleshaft and noticed that their was excessive play. Also, a steel throttleshaft would have been better than the brass since the early original SOLEX carbs also used a brass shafts that wore out prematurely. This was remedied with the steel later on. Installing bronze bushings would cure the loose shafts and also aid in wear resistance on the "soft" brass throttleshaft. I have not ran these carbs yet but hope to do so when Steve G's 36hp engine is completed. Cheers, Mr. Okrasa _________________
VW www.Okrasa.com
Rwoodshvac Samba Member
Posted: Wed May 23, 2012 11:33 am Post subject: Solex 32 and 34 PBIC |
I have a set of the WW Solex Repro 32 carbs and i have a set or Repro Solex 34 PBICs from SCAT.
Both sets had way to much slop in the throttle shafts.
Since i have decided to use the 34 PBICs i sent them out to Joe Mr Okrasa to see if he could help them.
I must say i am Super Impressed with how they turned out. Before they were sloppy and rough feeling
Now after Joe's magic they are butter smooth almost like bearings were installed. NO SLOP what so ever.
This is one job that was undersold and over delivered
Thanks Joe
_________________ 57 Ragtop Semaphore Sedan
48 Aluminum Case drilled tapped, Full Flow Filter
Porsche 356 B Crankshaft 74mm
Porsche 356 B Rods
Shasta Cylinders with JE Pistons 80mm
WW Okrasa Heads worked by Ron Chuck
Speedwell Ratio Rockers 1.25
Dual Valve Springs w/Lash Caps
Blackline Racing Lifter Inserts, Manton Push Rods
34 Pbic Carbs rebushed by Mr Okrasa
Custom Okrasa Intakes enlarged to 34mm
Gene Burg Sump
Fram bypass Filter with Okrasa Oil Cooler |
Vedderism Samba Member
Joined: October 02, 2020 Posts: 28 Location: Paramount
Posted: Thu Feb 09, 2023 4:08 pm Post subject: Re: New "SOLEX" 32mm Carburetor Woes / Rough Idle!! |
Has anyone successfully installed and ran the WW 32’s with the jets they come with? |
Bub Samba Member
Joined: June 10, 2004 Posts: 1151 Location: Central Washington
Posted: Mon Feb 13, 2023 7:03 pm Post subject: Re: New "SOLEX" 32mm Carburetor Woes / Rough Idle!! |
Vedderism wrote: |
Yes, I did on a 64x 83mm 36hp engine with the WW street cam. From very first cold start on a fresh rebuild they ran GREAT, I have zero complaints.
I did eventually do a size down on the jets, I do think it helped a little, but not anything terribly noticable.
It's run great from day 1 and I put 2200 miles on it this year.
Swapping the 019 to a BR25/ 010 made a bigger difference than swapping the jets.
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Posted: Sun Oct 15, 2023 8:38 pm Post subject: Re: New "SOLEX" 32mm Carburetor Woes / Rough Idle!! |
Bub wrote: |
Vedderism wrote: |
Great looking engine!
Can you tell me your jet sizing? |
