Typhon2222 Samba Member
Joined: October 24, 2009 Posts: 363 Location: Berkeley, CA --> Berlin, Germany
Posted: Mon May 21, 2012 7:53 am Post subject: How to keep wing-window open? |
Hi folks,
The driver's wing-window on our '88 swings shut at speeds over 40 MPH.
And I hear there's no way to tighten the pivots themselves.
So.... I'm wondering what creative solutions have been developed for keeping these things propped open at highway speeds when they're no longer capable of doing it themselves. Bungee cords? Custom-made latches? Other nifty things? _________________ Basil — '88 Dove Blue Westy. |
molybdanum Samba Member
Joined: December 27, 2010 Posts: 57 Location: Berkeley, CA
Posted: Mon May 21, 2012 8:25 am Post subject: |
The friction to hold the window open comes from the lower pivot. I think you can adjust the tension on that pivot, but may have to remove the wing window frame to get to the screw.
-Dan _________________ 85 Vanagon Westfalia EJ22
00 Passat GLS Wagon |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9799 Location: Mt Lemmon, AZ
msinabottle Samba Member
Posted: Mon May 21, 2012 3:06 pm Post subject: Better HERE |
This thread's a bit more directly responsive:
http://www.thesamba.com/vw/forum/viewtopic.php?t=122598
I still have the mental scars!
tpinthepack Samba Member
Joined: July 11, 2004 Posts: 816 Location: clearwater,florida
Posted: Mon May 21, 2012 4:31 pm Post subject: |
My Vent windows don't stay open too well either. I also notice they don't really open far enough to blow on me either. Is there a stop or limit to the travel of the vent? Can it be opened further? Mine is sloppy also.
Thanks _________________ TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne |
Posted: Mon May 21, 2012 4:44 pm Post subject: |
tpinthepack wrote: |
My Vent windows don't stay open too well either. I also notice they don't really open far enough to blow on me either...
Mine open about 150 degrees (pointing back at me) so you might investigate what is keeping yours from doing that. |
SloFloSyncro Samba Member
Joined: June 16, 2010 Posts: 80 Location: Oceanside, CA
Posted: Mon May 21, 2012 9:52 pm Post subject: |
Maybe not the most elegant solution, but certainly works at any speed:
Posted: Tue May 22, 2012 7:30 pm Post subject: |
Wow, thanks for all the helpful replies folks. Especially since there were older threads on the same topic -- dunno why I didn't remember to use the search function first.
At any rate, thanks for the tips! I'm definitely going to explore those options. _________________ Basil — '88 Dove Blue Westy. |
Posted: Wed May 23, 2012 6:12 am Post subject: |
SloFloSyncro wrote: |
Maybe not the most elegant solution... |
Maybe??? |
Luckymonkeylss Samba Member
Posted: Sat Aug 29, 2020 12:50 pm Post subject: Re: How to keep wing-window open? |
Has anyone tried these? |
puchfinnland Samba Member
Joined: December 26, 2005 Posts: 279 Location: Deale Maryland
Posted: Sat Aug 29, 2020 1:12 pm Post subject: Re: How to keep wing-window open? |
Stop whining, open the door,disassemble and when you get to that bloody screw remove it and install a bolt, in the future you can reach a wrench up and adjust it. _________________ ABYC marine master technician , EX European auto technician, new business- EASTCOASTWEST , custom work on campers, only systems, no mechanical |
Franklinstower Samba Member
Posted: Tue Sep 01, 2020 8:38 am Post subject: Re: How to keep wing-window open? |
here are photos for you.
tighten the screw, since you have the wing window out, A bolt will be easier to tighten and loosen when the window is back in.
It pinches on the lower pivot:
and if you want full range on the later models, tap out the limiting pin here - then you can open the wing fully like in a bay bus:
_________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
Last edited by Franklinstower on Tue Sep 01, 2020 9:46 am; edited 1 time in total |
BrownEye02 Samba Member
Posted: Tue Sep 01, 2020 9:02 am Post subject: Re: How to keep wing-window open? |
Franklinstower wrote: |
YES!!!! I've seen threads cover the tighten up part but this is the first I've seen to get a later model window to open further. Wind and bugs at my face, here I come! |
Rorke Samba Member
Joined: August 04, 2016 Posts: 255 Location: Traverse City, MI
Posted: Tue Sep 01, 2020 10:41 am Post subject: Re: How to keep wing-window open? |
Luckymonkeylss wrote: |
Yes. The Sea Cow has a set.
A couple of days ago, I was on the highway doing 65 mph when a semi passed causing turbulence. The driver's side extension arm shot off like a bullet ricocheting around.
It needs a bigger lip on the outer side. Maybe?
Anyway, it works great for 98% of the time. For the other 2%, protective eyewear and an athletic cup are recommended! |
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1141 Location: Northern Nevada
Posted: Tue Sep 01, 2020 11:09 am Post subject: Re: How to keep wing-window open? |
Anyone tried this?
_________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote: |
I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Tue Sep 01, 2020 11:19 am Post subject: Re: How to keep wing-window open? |
kourt Samba Member
Joined: August 13, 2013 Posts: 1942 Location: Austin, TX
Posted: Mon Jun 21, 2021 1:12 pm Post subject: Re: How to keep wing-window open? |
I found this at Home Depot on Sunday. It's plastic so it doesn't mar the painted finishes, and it's cheap--I think it was $5. They are just under $4 on Amazon.
kourt
will5023 Samba Member
Joined: March 25, 2019 Posts: 28 Location: Washington, DC
Posted: Tue Jun 22, 2021 5:28 am Post subject: Re: How to keep wing-window open? |
Here'a a picture of how I was able to tighten mine. The screw had not fallen out but was disengaged from the threads. I wedged a screwdriver against the head of the screw and used a set of locking pliers to hold the assembly together. I then was able to use a set of needle-nose locking pliers (not shown) to grip the screw head and turn the screw to thread it in and tighten it. This did not require removing the window.
_________________ Will
'85 Westy w/ '99 Subaru EJ25D
Orig. manual now automatic |
space Samba Member
Posted: Tue Jun 22, 2021 9:31 am Post subject: Re: How to keep wing-window open? |
I used Drop ceiling wire _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
NSPeters92 Samba Member
Joined: May 11, 2018 Posts: 9 Location: Grants Pass, Oregon
Posted: Tue Jun 22, 2021 6:57 pm Post subject: Re: How to keep wing-window open? |
I got a pair of these plastic printed wing window holders on Etsy, and they work fantastic! They clip in and then when i’m not using em they just sit on the dash or in the glovebox during the winter… it amazes me what people can do with those printer things
https://www.etsy.com/listing/814378150/pair-of-vanagon-westfalia-wing-window |
