Manfred58sc Samba Member
Posted: Tue Sep 04, 2012 9:38 pm Post subject: |
Floor is ah, well, totally shot, brake and clutch pedal move fine and the frame is a-O.K. even the cross supports are fine and all dedicated tabs ( MC/accelerator) are also good. _________________ Fat chick owner/operator |
Posted: Tue Sep 04, 2012 9:44 pm Post subject: |
Donor nose section will provide many sections that are rusted, its a 64 so there will be some creative modifying on the dog legs, harvesting the sections will be time consuming..now getting that steering wheel off>>>> ? _________________ Fat chick owner/operator |
Posted: Wed Sep 05, 2012 9:07 pm Post subject: |
The 58's parcel tray (thin lip) had some nasty rust outs (mostly in the center), I had a 64 fat lip donor with bad rust along the lip. So I clipped out the rusty fat lip and overlaid the remaining section onto the 58 thin lip, gave it a few rivets and a good coat of rustoleum. Presentable. _________________ Fat chick owner/operator |
Posted: Wed Sep 05, 2012 9:08 pm Post subject: |
still a bit tacky.. _________________ Fat chick owner/operator |
Stocknazi Samba Member
Posted: Fri Sep 07, 2012 7:39 am Post subject: |
good to see some progress made on that 58 manfred.
it will be cool to see it being used instead of sitting in a scrap metal pile somewhere _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Fri Sep 07, 2012 9:19 am Post subject: |
Damn Manfred, you were not kidding about the trip and all of the work entailed! You are a better man then me! Now I know why you are so tired when I call you.
Keep up the good work, and I will see you soon, hopefully before Winter hits....I need a road trip! _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
Posted: Fri Sep 07, 2012 7:15 pm Post subject: |
Gave it a few more hours today and I now have a good idea of what needs replaced,what I have, and how to do it...I think. This is a first time adventure for me, Colorado does not have this level of rust. I will tackle drilling out stitch welds on the donor bus first, if I can get the floor out then I should have good access to the lower nose. I do not have the welding skills to reattach so I will bring in a pro. It has kind of a cool look...maybe waxoil treatment, except for the roof, it really needs something to protect it.. _________________ Fat chick owner/operator
Posted: Fri Sep 07, 2012 7:17 pm Post subject: |
Whatta nose!!!
Posted: Fri Sep 07, 2012 7:18 pm Post subject: |
Posted: Fri Sep 07, 2012 7:20 pm Post subject: |
That's a bit intimating, what view!!
Posted: Fri Sep 07, 2012 7:22 pm Post subject: |
!!!yellow cargo doors!!!!Yee-haw
Posted: Fri Sep 07, 2012 7:25 pm Post subject: |
There is a little more to work with on this side...
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Fri Sep 07, 2012 10:07 pm Post subject: |
Manfred58sc wrote: |
Yes there is a bit of a Sam Elliot resemblance now that you mention it. I had never met a professional tractor mower, an amazing career, he drives town to town field to field at 18mph, stays in many motels and is rarely home. He had been doing it for 24 years! He was super curious about AC and often compared them to Chevy 350's he worked on. We get an early start in the am, nice and cool with a breeze. The "keys" have had it so time for a jumper set up. 2 shots of starting fluid and 2 cranks...Starts right up! Wait, it is in gear and I am driving already (without brakes). Foot on the clutch and still moving forward, shifter feels strange...to loose. Power off and a check underneath, coupler is broken and has been for a long time, this is not good. I put heavy vise grips on the trans shift rod and try like hell to get it into another gear. No go..it is demonically locked in first. Clutch cable is good and properly adjusted but still locked in first. I had hoped the engine died long ago and the trans was good, however it appears that the trans locked into first, the PO tried to force it out of gear, sheered the coupler and then probably cooked the engine trying to get it home. This driveout is canceled. Now we need a close storage area as we can only tow at 10mph so we don't hurt the 40h.p. We have become idle news in Osceola so the locals are drifting by to check out the "hippy Bus's".. |
I had a similar symtom once and it turned out the splines were too rusty and would not allow the clutch disc to slide away from the flywheel with the clutch depressed. I pulled the engine, cleaned the splines up with a chainsaw file, test fit the clutch disc to make sure is slid on easily, and reinstalled the engine. It worked perfectly. |
Posted: Sat Sep 08, 2012 7:23 pm Post subject: |
The rust issue on the spline is a good analysis, I spent a good deal of time cleaning, but maybe I missed some burrs/etc. I was most bothered by not being able to get the trans to shift, I had heavy vise grips on the shaft right by the nose cone and gave it lots of force and it would not move in or out. The SC is going to a new home and I will pass the observation along to them. In the future if the splines are rusty, I will wire wheel them and then put the disc on it to make sure it moves "clean". Thanks _________________ Fat chick owner/operator |
Posted: Mon Sep 10, 2012 8:04 pm Post subject: |
Got the donor floor removed from the nose and frame..quite a job. the donor has its own issues with rust but it is savable. Time for some heavy gauge aluminum sheeting,rivets, and Alex paint-able outdoor siliconized caulk. This is a low budget repair but it will hold fine in the dry Colorado conditions. We are shooting for getting this on the road by then end of the year, still lots to do.some pics,, _________________ Fat chick owner/operator |
Posted: Mon Sep 10, 2012 8:06 pm Post subject: |
swiss cheese has fewer holes
Posted: Mon Sep 10, 2012 8:11 pm Post subject: |
tomorrow it gets heavy coat of rustoleum paint, should be presentable from the mat side any way..
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Tue Sep 11, 2012 2:50 pm Post subject: |
Gave it a few more hours today and I now have a good idea of what needs replaced,what I have, and how to do it...I think. This is a first time adventure for me, Colorado does not have this level of rust. I will tackle drilling out stitch welds on the donor bus first, if I can get the floor out then I should have good access to the lower nose. I do not have the welding skills to reattach so I will bring in a pro. It has kind of a cool look...maybe waxoil treatment, except for the roof, it really needs something to protect it.. |
Hey Manfred,
If you need some advice on the nose/floor, give me a ring. I'm fresh off doing a floor and nose on a 67. I used a WW floor on this one and can't imagine there being a better replacement. Just modified a couple of small things to get it a bit more accurate, but it fit like a glove. If you're doing a nose and floor, I'd recommend removing the nose and drilling out the floor from the backside. This allows you to rosette weld from the front of the Bus which is far more comfortable than laying on the cab floor. An added bonus is that the welds won't have to be finished at the front of the floor since you welded it from the back.
Good luck, Buddy! _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs
Posted: Tue Sep 11, 2012 7:06 pm Post subject: |
Thanks Mike, I totally see what you are saying. It was a bear getting the floor off the donor section. I decided not to remove the nose of the 58, amazingly it was unwrecked and only rusted below the belt line. I will get John ( our fab guy) to replace the lower nose. I will slip the replacement floor onto the frame of the 58 and do the dreaded under the car welding. You are the VW "Godfather"!! _________________ Fat chick owner/operator |
Posted: Wed Sep 12, 2012 6:32 pm Post subject: |
Here is the final result, good solid finish with the heavy coating of rustoleum. I also got a rebuild on the master cylinder from the 64 nose, I had a NOS rebuild kit in stock..after chipping out the rusty guts and giving the cylinder a hone ( who has that tool anymore??). I also "gooped up" and painted the "street" side as well, pics of that tomorrow...
