tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Sun May 27, 2012 5:47 pm Post subject: Stranded on the highway right now and need help - solved |
I was just heading down the highway with engine turning at 3500 rpm. As I approached a hill I pressed the pedal down and started to lose power. I pulled over and shut it off and tried to restart it. It will run for a few seconds and die. I thought I was out of gas so my wife brought me some. I filled it up and it still will just start for a few seconds and die. Could it be vapor lock or am I looking at a tow home. Its a 2 liter with 79 federal fi. All vacuum hoses and wires are in place. Help please! _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's)
Last edited by tootype2crazy on Sun May 27, 2012 10:20 pm; edited 1 time in total |
addison5429 Samba Member
Posted: Sun May 27, 2012 5:53 pm Post subject: |
Ive got a 70 and mine does this if you floor it up hill. I believe it is a vapor lock. When it happened to me I took the fuel line off the carb let the gas in the line out into a container put the hose back on and it started right back up. _________________ [url=http://www.vw-mplate.com/mplate2-9652.png]Click to view image[/URL] |
Posted: Sun May 27, 2012 6:06 pm Post subject: |
Fuel injected engines do not get vapor lock as a rule, the pump can cavitate if the filter or tank outlet is clogged though. Try shorting to ground the wire running from the ECU to the TSII sensor. If your engine starts running fine, your TSII sensor is bad. |
Posted: Sun May 27, 2012 7:05 pm Post subject: |
I tried grounding the ts2 but no change. I also took off the fuel pressure test hose and when I turn the engine over fuel comes out, but not when the key is in the 'on' position. I tried unplugging the vacuum from the pressure regulator and plugging it, no change. I tried jumping terminal 86b to 88a on the duel relay, no change. I just put a used coil on yesterday, would it behave this way if the coil were bad? _________________ air-cooled or nothing for me
2001 GTI VR6 (wife's) |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun May 27, 2012 7:27 pm Post subject: |
tootype2crazy wrote: |
I just put a used coil on yesterday, would it behave this way if the coil were bad? |
Possibly, but I'd be suspect of the wires you reconnected, are they all on firmly in the right places?, any chance they broke internally when you disturbed them? Is your bus a California model with the odd coil?
A broken or disconnected black wire to the fuse holder laying along the LH side of the engine and the DR would cause the symptom you describe (BTW fuel should never flow when the key is on unless the engine is turning). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun May 27, 2012 8:38 pm Post subject: |
Remove and reinstall the wiring plug on the AFM |
Posted: Sun May 27, 2012 9:04 pm Post subject: |
I got it towed home. The guy didn't hook it up right and it almost fell off the flat bed. Got a new dent and a ripped off bumper. This just isn't my night. I tried removing the afm plug and reinstalling, still just runs for a second and dies. I will really dig into it tomorrow. I suspect something is up with the fuel pump or the pressure regulator. Fuel pressure tests will tell more. _________________ air-cooled or nothing for me
Posted: Sun May 27, 2012 9:11 pm Post subject: |
With the AFM top off and the key on, when you push the wiper on the AFM and it releases that ground on that copper prong, the fuel pump should run, right? Mine doesn't. I think I recalled testing it this way when I installed the system. Would this mean the double relay is at fault? _________________ air-cooled or nothing for me
Last edited by tootype2crazy on Sun May 27, 2012 9:28 pm; edited 1 time in total |
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1399 Location: Cambridge, MA
Posted: Sun May 27, 2012 9:19 pm Post subject: |
Yes, the pump should run when you move the wiper. This is almost certainly your problem. Could be the double relay, or the wiring harness perhaps, or maybe a ground. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Posted: Sun May 27, 2012 9:30 pm Post subject: |
You should have 12V on one of the contacts in the AFM (the movable one I think?) when you have the key on. Once you open the flap in the AFM you should have power on both contacts.
On the double relay, you should have power on both terminals 88a and 86b when the flap in the AFM is held open. |
Posted: Sun May 27, 2012 9:53 pm Post subject: |
busdaddy wrote: |
A broken or disconnected black wire to the fuse holder laying along the LH side of the engine and the DR would cause the symptom you describe. |
Слава Україні! |
Posted: Sun May 27, 2012 10:19 pm Post subject: |
Well I fixed it, $75 and a new dent later. The little prong that contacts with its ground inside the AFM wasn't working. I only figured it out by sticking my test light probe inside the AFM on a few spots. I noticed when I stuck the probe in between the prong and its ground the fuel pump would run (with the key on). So I was like dang, there's the problem! I cleaned up the contact and put some dielectric grease on it and bam, it started right up. I wish I could have figured out that simple 1 minute fix on the highway. _________________ air-cooled or nothing for me
greenbus pilot Samba Member
Joined: March 14, 2008 Posts: 1285 Location: Wisconsin: Rustbelt, USA baby!!
Posted: Mon May 28, 2012 12:27 am Post subject: |
Well I fixed it, $75 and a new dent later. The little prong that contacts with its ground inside the AFM wasn't working. I only figured it out by sticking my test light probe inside the AFM on a few spots. I noticed when I stuck the probe in between the prong and its ground the fuel pump would run (with the key on). So I was like dang, there's the problem! I cleaned up the contact and put some dielectric grease on it and bam, it started right up. I wish I could have figured out that simple 1 minute fix on the highway. |
......Yeah, but it feels good, don't it? You learned something and are now smarter than before. _________________ Sent from a white van down the street. |
busmania Samba Member
Posted: Mon May 28, 2012 7:34 am Post subject: |
If driving a bus daily, you really should consider AAA or other club. I get 4 tows per year. Use it one and it pays for itself. I just used it the other day when my single cab left me stranded. I'll bet AAA would make them pay for that new dent too. Nice job fixing it. |
Jockomo Samba Member
Joined: October 11, 2006 Posts: 163 Location: Lafayette, LA
Posted: Mon May 28, 2012 7:55 am Post subject: |
Seriously, make that idiot pay for your dent.
The one time I had my bus towed, the guy screwed up my bumper. _________________ '75 Westy with '78 2.0L engine. |
Posted: Mon May 28, 2012 7:15 pm Post subject: |
Well the idiot is definitely going to pay. I drove the old bus today and I could hear a distinct exhaust leak getting louder and louder. By the end of the day it sounded like a freaking straight pipe. I get home today and look under the engine and, much to my horror, depression, anger and desire to kill someone, the main body of my passenger side heat exchanger is completely broken away at the pipes going into the head! I can't even describe in words how incredibly livid I am right now. I feel like throwing my laptop across the room. I JUST TOTALLY RESTORED MY HEAT EXCHANGERS LAST NOVEMBER. (See my thread on it) Now the passenger side one is a useless piece of trash. At least I think it is:
What do you think? There are some really skilled welders around the corner from my house. Should I try to have it repaired? Or should I get another one and restore it as I did this one? _________________ air-cooled or nothing for me
Posted: Mon May 28, 2012 8:17 pm Post subject: |
Sadly I think you're right, the heat exchanger is trash. I don't think welding is a viable option, for one thing I'm pretty sure those pipes aren't regular mild steel. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
