greenbus pilot Samba Member
Joined: March 14, 2008 Posts: 1285 Location: Wisconsin: Rustbelt, USA baby!!
Posted: Mon May 28, 2012 10:20 pm Post subject: |
I would certainly try welding, or brazing if they are some kind of cast steel.
What do you have to lose by trying? I would do it right in situ, making sure it stays straight, then remove and finish welding off the Bus. Its a lot of work, but you have nothing to lose by trying, and of course someone will pay you for your time and labor, right? _________________ Sent from a white van down the street. |
Posted: Tue May 29, 2012 4:28 am Post subject: |
Get them to buy you a new heat exchanger and forget the welding. That is why they are licensed, bonded, and insured. |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Tue May 29, 2012 8:02 am Post subject: |
Is the heat exchanger damage due to the towing guy? If so, they must buy you a new heat exchanger. What did he do, wrap a chain around it? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Tue May 29, 2012 8:59 am Post subject: |
Well the tow truck people are coming by to look at it now. Hopefully they will be nice about it and work with me. I do just want to get a different exchanger, not a new one though. Those Dansk jobs are totally inferior to the VW original. I bought these exchangers from vw76westy aka raul. I wonder if he still has some.
As far as I can tell this is what happened. The truck was a flat bed. He hooked the chain up to the front tow ring , which is big and strong, and he hooked up a chain to the teeny weeny tow ring on the rear bumper, whereas he should of attached the chain to the torsion tubes or something like that. As we were going around an on-ramp, we could feel a big shift in the truck. We looked back and the bus was rolling toward the front of the truck. What happened was the rear bumper spot was too weak and it pulled the bumper off on the drivers side. The bus stopped short of running into the truck because the bumper was clinging on to the passenger side. When the bumper pulled away from the bus, the passenger side curved around and put a big dent in the battery tray area behind the rear wheel. Then the bus started rolling back, and as it was rolling back, the bumper must have gotten caught up on the exhaust and the weight of the vehicle must have been pressing down on the exhaust and it broke.
The tow company's mechanic just came by and looked at it and they are not willing to admit fault on account of my bus being rusty where he hooked up the bumper. They say they were just hooking it up on the tow hook and couldn't anticipate the problem. I say the guy should have been more thorough since he was dealing with an older vehicle. The mechanic is a welder and he was willing to try welding it for me. Why must life suck so very, very much? _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's)
Last edited by tootype2crazy on Tue May 29, 2012 9:31 am; edited 1 time in total |
Posted: Tue May 29, 2012 9:15 am Post subject: |
tootype2crazy wrote: |
Well the tow truck people are coming by to look at it now. Hopefully they will be nice about it and work with me. I do just want to get a different exchanger, not a new one though. Those Dansk jobs are totally inferior to the VW original. I bought these exchangers from vw76westy aka raul. I wonder if he still has some. |
Some southwestern bone yard will certainly have one in good condition. |
Daverham Samba Member
Posted: Tue May 29, 2012 9:32 am Post subject: |
I just brazed a cracked F-pipe (late T4 exhaust manifold). That was a couple weeks ago on a daily driver. So far so good.
I don't believe it's steel, unless it's some REALLY high nickle stainless or something as Busdaddy has suggested. Magnet won't stick. Brazing has worked perfectly so far. I have no idea how long it will hold up. Maybe forever. Maybe another month. Either way, you'll have to remove the heat exchanger because you have to grind the seam perfectly clean for the brass to stick.
Scroll to bottom:
http://www.thesamba.com/vw/forum/viewtopic.php?t=381102&start=0 |
Posted: Tue May 29, 2012 9:49 am Post subject: |
If i remove it i am extremely concerned it will get out of alignment. Not sure what to do here. Clearly the tow guys will not pay for another. |
Your state probably has some commission just waiting to hear a complaint from you about these guys if they refuse to make your van whole again. |
Posted: Tue May 29, 2012 10:08 am Post subject: |
If alignment is your concern, then clean and braze the bottom half - which is accessible as it sits - enough to hold it together and properly aligned. Then remove it and finish the rest of the repair on your bench. |
Desertbusman Samba Member
Posted: Tue May 29, 2012 10:12 am Post subject: |
The tow company's mechanic just came by and looked at it and they are not willing to admit fault on account of my bus being rusty where he hooked up the bumper. |
So was it rusty and rotted out where the bumper ripped off?
No one knows and cares for my vehicles the way I do. And no one is going to touch them or do anything to them without my supervision and approval. I've learned from experience over the years that trusting anyone else is apt to be disasterous. Tire stores have been the biggest problem but I've never had a vehicle towed or hauled.
The owners manual talks about the tow hooks for towing but did VW have any guide lines for tieing a bus down and securing it? Do tow companies have any vehicle specific instructions? All of our buses came across on ships and I doubt the tow hooks were the only way they were held secure. _________________ 71 Superbug
71 Westy |
Posted: Tue May 29, 2012 10:13 am Post subject: |
I think brazing would work. The heat exchanger part is still hanging in there and really firm at that. This shows that those pipes going in to the head don't really have too much to do with holding up the heat exchanger when it is installed correctly with the proper brackets and such. _________________ air-cooled or nothing for me
2001 GTI VR6 (wife's) |
Posted: Tue May 29, 2012 10:29 am Post subject: |
Desertbusman wrote: |
So was it rusty and rotted out where the bumper ripped off? |
The metal in there was firm enough to tow the bus by. It was not firm enough to tension it down hydraulically and then for it to withstand the shear forces of going around an on ramp curve at 40 mph. _________________ air-cooled or nothing for me
Posted: Tue May 29, 2012 7:56 pm Post subject: |
Well I fixed them by brazing:
I went ahead and took off the other one too and now they are off to the powder coater's. The VHT paint did not hold up at all over the 7 months. I will post pics of that when they are done. Thanks everyone for your help and moral support. A lot of really bad things have been happening to me lately and this one just made made me crack. No pun intended. _________________ air-cooled or nothing for me
Jockomo Samba Member
Joined: October 11, 2006 Posts: 163 Location: Lafayette, LA
Posted: Tue May 29, 2012 7:59 pm Post subject: |
Well I see you've already fixed it, good job.
Now get their insurance company on the line and send them the bill.
Don't let them get away with that.
As Wildthings said, that's why they are insured, licensed and bonded. Perhaps they shouldn't be. _________________ '75 Westy with '78 2.0L engine. |
