cmiller95 Samba Member
Joined: August 04, 2010 Posts: 1226 Location: Illinois
the2ndcashboy Samba Member
Posted: Tue May 29, 2012 11:26 am Post subject: |
I tend to think you get what you pay for. That seems a little too easy. An LSD for 350$ would be freaking awesome though  _________________
SRP1 wrote: |
You see....... He talks in code and translation requires a priest, geologist, astronomer, biophysicist, and Indiana Jones. |
modok wrote: |
If anything comes out perfect it just means your measuring tools are substandard. |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 6146 Location: Videbaek Denmark
Posted: Tue May 29, 2012 11:35 am Post subject: |
I´m a complete transmission imbessile.
I cant "see it" How should they be installed ?
T |
sullydog93 Samba Member
Posted: Tue May 29, 2012 11:36 am Post subject: |
I see the same price on their website.
Give it a try and report back. |
tncsparky Samba Member
Joined: November 29, 2008 Posts: 703 Location: santa rosa
Posted: Tue May 29, 2012 11:59 am Post subject: |
Maybe Bruce will give his two cents on this. _________________ "My Daddy told me, son if your stupid today you will be stupid tomorrow"
scotth17
I think you are just waiting around for a high-five from a unicorn so you can feel better about yourself |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3410 Location: Charleston, SC
Posted: Tue May 29, 2012 12:28 pm Post subject: |
All it appears to do is place pressure on the side-gears, limiting differentiation. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
Posted: Tue May 29, 2012 1:10 pm Post subject: |
I did a little research (google is your friend) and apparently they kinda sorta work but they wear out the spider gears and pins very quickly if used on the street. There is some debate about whether they even work at all. _________________
SRP1 wrote: |
modok wrote: |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23551 Location: SHALIMAR ,FLORIDA
Posted: Tue May 29, 2012 2:41 pm Post subject: |
should not affect the spider gears but may be hard on the dif case at the axle gears from the pressure.if the case was machined for some clutches it would probably be better, but I see nothing rong with nthe kit other than the price for 4 spring& 2 locater plates should be between $60.00 & $88.37 retail. or just grab some out of a gm or mopar product. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 73080 Location: Sneaking up behind you
Posted: Tue May 29, 2012 3:03 pm Post subject: |
One size fits all... too stupid.
Works on split case, swing axle, IRS and even New Beetle  _________________ Glenn
"You may not get what you pay for, but you always pay for what you get" |
Posted: Wed May 30, 2012 8:41 am Post subject: |
I would think they just found the size that fits in there,probably not realy made for a vw, but just replacement parts.but what is realy made for these things any way???nothing fits, so ..... |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 19953 Location: Just a tiny bit west of Yosemite Valley
Posted: Wed May 30, 2012 9:40 am Post subject: |
I thought Limited Slip was spelled QUAIF (or similar spelling)...
Posted: Wed May 30, 2012 9:44 am Post subject: |
I thought qualif was speled TBSD, or thorson gleason.
a limited slip is a totaly different thing.it's clear in the front & see through in the rear.  |
ISPWEST_SAMBA Samba Member
Posted: Fri Jun 01, 2012 8:34 pm Post subject: |
about a year an a half ago I had a NOS LSD for a 002 transmission it was very similar in design to that eBay listing , but complete so they did / do exist and work, from what I was told not as good as a clutch type or screw type LSD and did wear due to the heavy spring pressures
002 photos below...
http://www.thesamba.com/vw/classifieds/detail.php?id=1087734
Altema Samba Member
Joined: June 20, 2010 Posts: 2902 Location: Lower Michigan
Posted: Sat Jun 02, 2012 6:02 am Post subject: |
Using your gears as friction surfaces? No thanks. A proper friction-based LSD with use clutch plates. Torsen or Peloquin diffs are good alternatives.
But... didn't VW off a factory limited slip diff at one time?
Paul |
bumblebeecaz Samba Member
Joined: October 23, 2006 Posts: 265 Location: virginia
Posted: Sat Jun 02, 2012 7:01 am Post subject: |
i think it was a ZF diff that was used factory at one time |
Posted: Sat Jun 02, 2012 8:07 am Post subject: |
ive got a swing superdiff I was goint to add clutches & irs out put shafts to and use it as an irs, and the screw in sides can be used for preload& set the torque breakway.just havent goten to it yet. |
