tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Fri Jun 01, 2012 9:47 am Post subject: Gas heater switch question |
A long shot on this question, I know. I am installing a BA4 gas heater from a 411 in my bus. The switch I have is part number 411 963 107 C. The switch for the BA4 is supposed to be part number 411 963 107 A. It appears I have the one for the BA6. The terminal designations appear to be different on the switch compared to the diagram. Does this make a difference? Should I sell my BA6 switch and try to get a BA4 proper switch? _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Fri Jun 01, 2012 10:00 am Post subject: |
Are you using a timer switch you twist or a push pull type? The timer ones are specific to the heater, three types I belive. Your type the BA4, one for the BN4 and one for a BA6. I know the plug on the back of a BA6 to a BN4 are diffent (pretty sure) and not able to criss cross (some please correct if wrong).
So Id sell the BA6 and get a BA4 _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Fri Jun 01, 2012 10:13 am Post subject: |
This one you push in and turn to the right to set the timer. I am certain this is a BA6 switch. The BA4 one is different because the 411 has the option of using a clock to preset it coming on at a certain time which is awesome, btw. I guess I need to sell the one I have and get the proper one. Anybody need a BA6 switch? _________________ air-cooled or nothing for me
Posted: Fri Jun 01, 2012 10:33 am Post subject: |
tootype2crazy wrote: |
This one you push in and turn to the right to set the timer. I am certain this is a BA6 switch. The BA4 one is different because the 411 has the option of using a clock to preset it coming on at a certain time which is awesome, btw. I guess I need to sell the one I have and get the proper one. Anybody need a BA6 switch? |
Get the clock Make it fit the bus dash. Or maybe make a bus one work I have one for a T3. The bus, T3 and 4 had that cool clock option. Set it and forget it. _________________
t3kg wrote: |
1964 1500 S
