How To - One piece windows back to vent windows
Page: Previous  1, 2, 3  Next
54bugn
54bugn is offline
PostPosted: Thu Jul 19, 2012 1:30 am    Post subject: Reply with quote
Thanks Joey thats awesome, looks good, I am sure you are happy with the results. Makes my job easier now that I have a visual when I go to do mine. Home this Saturday see you shortly after that, and I will check out the new install in person.
Cheers,
Mike
"Schwing wrote:
You either have to be too cheap to hire a pro or determined to do it yourself, but it helps to be both!"
54 European Sedan deluxe
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=414940
gonebaby
gonebaby is offline
PostPosted: Tue Jul 24, 2012 8:35 pm    Post subject: Reply with quote
Joey i bought this 57 and of course there are No vent windows. Can i buy any year door to use the vents? Thanks Rob
Joey
Joey is offline
PostPosted: Wed Jul 25, 2012 3:38 am    Post subject: Reply with quote
Anything from '56 to '64 will work.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
gonebaby
gonebaby is offline
PostPosted: Wed Jul 25, 2012 1:44 pm    Post subject: Reply with quote
thank you..
marzano
marzano is offline
PostPosted: Tue May 07, 2013 5:21 pm    Post subject: Reply with quote
Very very nice job.
It will help me so much.
Thanks
Dum
65 brazilian bug - Fusca 65
Resto pix: http://www.flickr.com/ricardomarzano
http://www.forumfuscabrasil.com
gforcepdx
gforcepdx is offline
PostPosted: Mon Jun 06, 2016 11:28 pm    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
I wanted to thank you for the work you did here. I looked for three days to find this. I'm buying a 57 ragtop with one piece windows I need to reverse. well done sir... john
yes... I'm the one who destroyed this fine, vintage, automoble...
gforcepdx
PostPosted: Mon Jun 06, 2016 11:29 pm    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
Peter_KG
Peter_KG is offline
PostPosted: Wed Jun 21, 2017 1:54 pm    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
Great topic!!! Thanks!
Planning to convert the one piece windows of my '54 oval bug too...
Finally found all the period correct pieces! Shocked
Next step is to bend me an U-profile out of some sheet metal (1 mm thick?) for the support... I understand the profile should be 140 mm long, 18 mm wide... but how high did you make your support?
Thanks!!
Peter
VW Karmann Ghia '63
VW Kupla Dickholmer '64
VW Bubbla Oval '54
Joey
Joey is offline
PostPosted: Sat Jun 24, 2017 3:55 pm    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
From the bottom of the 'U' to the very top of the door skin is 11mm. It the measurement in blue in this diagram:
Joey
Peter_KG
Peter_KG is offline
PostPosted: Sun Jul 02, 2017 1:56 pm    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
Thank! You know how high, the actual channel (bracket) you welded in, was?
I'm planning to use sheet metal glue to avoid damage on my paint... Confused
Thx
Peter
VW Karmann Ghia '63
VW Bubbla Oval '54
vwbrewer
vwbrewer is offline
PostPosted: Sun Jan 28, 2018 12:53 pm    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
Depends on how much material was hacked and/or trimmed.
1957 Oval Rag
iamthewalrus30
iamthewalrus30 is offline
PostPosted: Tue May 12, 2020 7:53 am    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
I'm going to add this here just in case anyone recently is trying to add back their vent windows. My brother and I will be tackling this job for ourselves and is starting to gather the bits and pieces needed for the job.
He actually found this guy is Japan that is reproducing the inner metal that needs to be welding into the channel.
He bought the pair and is waiting to see if they will work for his 62' doors.
but if they do, this will save considerable time!
here is the link
https://www.ebay.co.uk/itm/VW-Bug-Beetle-Door-Wind...0903.m5276
shiddot
shiddot is offline
PostPosted: Sun Sep 20, 2020 9:31 am    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
Really interested to hear if these parts were any good, and if you managed to add your window vents back in successfully?
My ‘61 has one piece windows (fitted by a PO in the 90s). My near side window regulator now needs replacing so I’m contemplating reverting to the original two-piece windows, but finding donor doors is not easy/cheap.
Taking off the door card for the first time since I bought the car in 2005 has revealed some interesting butchery scars that I can only assume were required in order to fit the later regulator into the early door?
Shocked
(The piece of wood is wedging the glass up in place due to the regulator being stuck fully-open)
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Sun Sep 20, 2020 9:54 am    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
… and i want to go in the other direction - i want to go with one piece windows, but on ribbed units - not your 56 - 63 doors - z
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
pastellgreen
pastellgreen is offline
PostPosted: Mon Sep 21, 2020 12:06 am    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
Thank you very much!
After the last "to do list" I assume, it is not possible to change the outer chrome trim/scraper thing without touching the vent window? At my car, I'm only interested in changing this, because of a destroyed rubber scraper itself...
wbbbbbbb
wbbbbbbb is offline
PostPosted: Sat Apr 24, 2021 6:38 am    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
One piece windows back to vent wing windows, restoration!
I bought these from eBay seller: ysbugs
Found trough Samba forums but can’t remember who originally posted it, wish I could credit member?
eBay Listing: VW Bug Beetle Door Window Vent Wing Inner Assembly Frame 2pcs.
Looks like just what I need to restore vent-windows on my 64 chop! Paided $38.47, S&H+Tax on 04/17, Delivered 04/23. 6 days!
See pictures! PN: 50541 RH side pulled for pic’s. Used $2.00 swap-meet green wing, LoL!
https://www.ebay.com/itm/132121350567
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Thu May 27, 2021 4:42 pm    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
Thank you for posting this up!!!!!
Jimbo
TDCTDI wrote:
67rustavenger wrote:
shiddot
shiddot is offline
PostPosted: Mon Jun 13, 2022 3:17 pm    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
here is the link
@iamthewalrus30 – I would love to know how you got on with this? The eBay link is dead now so if you have any more info on sourcing the inner metal pieces from Japan that would be really useful.
wbbbbbbb
wbbbbbbb is offline
PostPosted: Tue Jun 14, 2022 10:31 pm    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
All I have and can tell you the seller, currently has nothing for sale. Not sure if or how they can be contacted through eBay?
ysbugs (3,577)
91.9% Positive feedback
Member since 2015
Location United States
As for installing these I don’t have the time to install right now. I’m moving and need to remodel house before I can get back to my cars.
wbbbbbbb
wbbbbbbb is offline
PostPosted: Wed Jun 15, 2022 3:55 am    Post subject: Re: How To - One piece windows back to vent windows Reply with quote
Found link to replacement channel!
https://www.universalautomotive.com.br/catalog/product/view/id/10327/category/2/
Page 2 of 3
