Is this a split clock?
Disc
Disc is offline
PostPosted: Sat Jun 02, 2012 5:35 am    Post subject: Is this a split clock? Reply with quote
!!! THE CLOCK IS NOT FOR SALE!!!
This clock is a gift to my boss from his friend with another bigger dash mounted ('55 - oval?) clock. My boss was told it is '47-'48 clock but not sure. Clock is hand wind up from behind, approx. 50 mm. in diameter, with all original parts and working, was mounted on a chromed plate for table use since many years. It's not VDO clock, may be ZF of or ZE? What is correct use of this clock?
I've found simmilar, but VDO clock in Ebay.
Click
More info about that clocks will be good Smile Thanks!
The glory never gets old, just need new paint.
Nick
Wiggy
Wiggy is offline
PostPosted: Sat Jun 02, 2012 6:15 am    Post subject: Reply with quote
Yep. Awesome score.
Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval
Wiggy
Wiggy is offline
PostPosted: Sat Jun 02, 2012 6:16 am    Post subject: Reply with quote
Btw it's an accessory clock that is used with split window glove box doors.
Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval
56reddy
56reddy is offline
PostPosted: Sat Jun 02, 2012 7:30 am    Post subject: Reply with quote
This is the clock that I have. The face looks identical, but the rear winder looks different. Maybe my clock is a later model.
1953 Zwitter 3 fold ragtop.
IN2VWS
IN2VWS is offline
PostPosted: Sat Jun 02, 2012 5:38 pm    Post subject: Reply with quote
The clock in the OP appears to have raised dots at each hour. Is this correct or an optical illusion?
The clock shown above appears to not have these dots, and the thickness of the numbers are finer on the OP's clock.
Photobucket sucks
Suboval
Suboval is offline
PostPosted: Sat Jun 02, 2012 5:57 pm    Post subject: Reply with quote
Raised dots is correct.
It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history.
johnshenry Premium Member
johnshenry is offline
PostPosted: Sat Jun 02, 2012 7:53 pm    Post subject: Reply with quote
Don't you mean that the numbers on the clock above are *thicker* than the OPs clock? Looks that way to me....
John Henry
'57 Deluxe
'56 Single Cab
56reddy
56reddy is offline
PostPosted: Sat Jun 02, 2012 8:02 pm    Post subject: Reply with quote
There are definate differences in the faces upon closer inspection. My clock has thicker font and non-raised dots. I was under the impression that my clock was 1951-52 clock.
IN2VWS
IN2VWS is offline
PostPosted: Sat Jun 02, 2012 9:25 pm    Post subject: Reply with quote
Yeah......thats what I said, didn't I?
Photobucket sucks
IN2VWS
IN2VWS is offline
PostPosted: Sat Jun 02, 2012 10:04 pm    Post subject: Reply with quote
The user =Petri Nut*1= also has one the same as the OP's clock.
The VDO catalogs list both the VW and Tempo versions as having luminous dots.......but it doesn't list them as being for a split Bug. The clock that would go in a split bugs glovebox lid would be 60mm.....wouldn't it?
IMG_0013 by IN2VWS.INFO, on Flickr
IMG_0014 by IN2VWS.INFO, on Flickr
Photobucket sucks
Suboval
Suboval is offline
PostPosted: Sat Jun 02, 2012 10:24 pm    Post subject: Reply with quote
IN2VWS wrote:
The VDO catalogs list both the VW and Tempo versions as having luminous dots...................
That would explain the dots and the extra paint(?) on the ends of the two clock hands.
IN2VWS
IN2VWS is offline
PostPosted: Sat Jun 02, 2012 10:27 pm    Post subject: Reply with quote
There was a guy selling fake clocks 4 years ago:
http://www.thesamba.com/vw/forum/viewtopic.php?t=304494
Photobucket sucks
oval53/split52
oval53/split52 is offline
PostPosted: Mon Jun 04, 2012 12:27 am    Post subject: Reply with quote
It depends on the glovebox lid. Perohaus glovebox doors has got 60mm holes, and the more common version used in split-dash-Karmann-Kabs got holes that will fit 52 mm gauges.
http://outlavws.blogspot.com
IN2VWS
IN2VWS is offline
PostPosted: Mon Jun 04, 2012 5:43 am    Post subject: Reply with quote
Thanks.
Is the Perohaus version the same as the Happich version? The Happich version has the round horn grills mounted to it.
Photobucket sucks
oval53/split52
PostPosted: Wed Jun 06, 2012 4:22 am    Post subject: Reply with quote
I assume you are refering to the aftermarket Happich version found in catalogues from the 50ties?
Perohaus version looks like this:
http://www.thesamba.com/vw/classifieds/detail.php?id=425540
ACO like this:
http://www.thesamba.com/vw/classifieds/detail.php?id=57017
And Karmann factory-delivered-look like this. There are different kinds of locks for these. (Happich) Some of these are probably period aftermarket.
http://www.thesamba.com/vw/classifieds/detail.php?id=412545
Thanks.
IN2VWS
IN2VWS is offline
PostPosted: Wed Jun 06, 2012 3:57 pm    Post subject: Reply with quote
Yes. The Happich and the Karmann versions look the same to me.
I have a set that came with my split, and they accept a 60mm clock.
So, is the Karmann version nearly the same as the Happich version, with the exception that the horn grill is 52mm?
I found some clearer pics for reference.
IMG_0450 by IN2VWS.INFO, on Flickr
1950 catalog
1953 catalog
1953 Happich catalog
Photobucket sucks
