aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Mon Dec 04, 2017 8:03 pm Post subject: Re: 68 transmission leak |
Maybe pull it apart and measure the oil seals, then get your parts?
Your transmission isn’t rebuildable. Just want you to know that for when the time comes. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
bigbore Samba Member
Joined: December 19, 2003 Posts: 3297 Location: Wasilla Alaska
Posted: Mon Dec 04, 2017 8:19 pm Post subject: Re: 68 transmission leak |
Sure it's rebuildable you just have to have all the one year only parts and the one year only jig to put it together. _________________ where its cold and snowy |
Posted: Mon Dec 04, 2017 8:23 pm Post subject: Re: 68 transmission leak |
Hot damn, Mike’s back _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
basic_bear Samba Member
Joined: July 15, 2013 Posts: 61 Location: Sudbury, Ontario
Posted: Tue Dec 05, 2017 5:20 am Post subject: Re: 68 transmission leak |
I'm stuck with the wrong years for bus ownership. The 72 seems to have a few "one year only" parts and pieces as well. I'm getting my parts from German Supply in Toronto. www.germansupply.com (Scott Lyons)
I got a puller on the cover and it appears to be working. I didn't have the time to get it off completely.
Being that I may have to replace the whole transmission one day; what year would be suitable for replacement. 1968-1971? Thanks _________________ 1972 westy deluxe, Niagara Blue
1958 Panel, Dove Blue
1969 beetle purple |
Posted: Tue Dec 05, 2017 5:45 am Post subject: Re: 68 transmission leak |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Tue Dec 05, 2017 6:15 am Post subject: Re: 68 transmission leak |
Ok, you need to STOP right there! Remove the puller before you really break something.
You need to remove the cv joint flange first! _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Tue Dec 05, 2017 7:13 am Post subject: Re: 68 transmission leak |
I turned the puller by hand and luckily didn't force anything. As soon as I felt some resistance I stopped to regroup.
Now I get that there is a clip that has to be removed first. The clip is in the axle shaft which holds the CV joint flange in place. Once this clip is removed the joint flange comes off and then the drive cover.
The drawing I was using didn't show the clip or axle shaft, however I was able to find alternate drawings that show both the clip and axle shaft. Thanks Hazetguy! _________________ 1972 westy deluxe, Niagara Blue
Posted: Tue Dec 05, 2017 7:45 am Post subject: Re: 68 transmission leak |
I'd try and find a 1969-1970. That way you can use your existing clutch plate and throw out bearing. The 1971 was upgraded to use a guide for the throwout bearing but you'd need the matching clutch kit for all the parts to play well together. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1086 Location: wherever my baywindow takes me.
Posted: Tue Dec 05, 2017 7:48 am Post subject: Re: 68 transmission leak |
bigbore wrote: |
Sure it's rebuildable you just have to have all the one year only parts and the one year only jig to put it together. |
True to a point. There was a very good reason that is a one year only gearbox. In fact it isn't even a "one year only" transaxle. These gearboxes were not installed much past six months of the production run. This was due to the fact that the pinion bearing and the method used to retain it was a very bad design and were prone to self destruct the ring and pinions.
VW dealerships repaired and replaced many under warranty. The design was quickly abandoned. I do have all the tools necessary to rebuild one of these if I want to. But I don't as a rule because of its bad design. It is easier and much better to go to the more common three rib 002 design.
Mi dos centavos. |
Posted: Tue Dec 05, 2017 7:02 pm Post subject: Re: 68 transmission leak |
I would feel better if this trans was a rare and a collectors item rather than a dud. But so be a it. Thanks for the info _________________ 1972 westy deluxe, Niagara Blue
Posted: Tue Dec 05, 2017 8:04 pm Post subject: Re: 68 transmission leak |
sodbuster wrote: |
bigbore wrote: |
Mi dos centavos. |
I agree.
I did rebuild one a few years ago I happen to have all the 68 only parts I needed to use up and I had a customer that had to have it. _________________ where its cold and snowy |
lintbrush Samba Member
Joined: October 10, 2013 Posts: 269 Location: Campbell, California
