My 1964 Birch Green Canadian Squareback
Page: Previous  1, 2, 3 ... 10, 11, 12, 13, 14, 15  Next
bobnorman
Samba Newfoundlander
bobnorman is offline
PostPosted: Mon Apr 09, 2018 12:14 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Thanks Bob. I actually have an NOS dampner and tail pipe that I bought around the same time as my other muffler. As for the gray, a lot of this muffler still has the original coating on it. I’ve uncovered it with a wire brush on the angle grinder - it’s a lot tougher than I thought it would be. I thought it was like rattle can gray primer, but it’s more like epoxy.
I’ve been trying to keep the original finishes on this car where and when I can. I may touch up a few spots where the metal is bare or where I’ll be welding though.
Air does not freeze. Air does not boil.
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
bobnorman
PostPosted: Wed May 30, 2018 4:26 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Small update. Engine is mostly cleaned up and back together now with new rings, exhaust valves, main seal, and other seals. I cleaned and treated the tins with phosphoric acid followed by a spray on rust converter. Looks ok, and keeps the original finish. Still waiting on the new clutch and TO bearing. Interesting that the clutch too had the VW Canada re-manufactured logo on it.
Finished up the muffler the other night, some before and after, 'cause I know you like pics. I ended up painting the whole thing as there were just too many areas that needed work.
Other end, no before pic but had similar damage, I assume from someone hammering on it to get it off.
Have to bolt on the exhaust on next, finish tidying a few things in the engine bay, then I can fire it in and hopefully fire it up.
bobnorman
PostPosted: Thu Jun 14, 2018 11:59 am    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Another small update. Engine is back in, but it’s clear that it still needs to tuned it correctly, as it's not idling right yet. Put on a new NOS progressive linkage set up on as the old one was a bit sloppy.
Here it sits
And a before and after...
I might have mentioned, I'm going for the 10 year-old used car look. Very Happy
I need to get to choke adjusted and get it properly warmed up before I can really start to determine what's going on, and try to correctly adjust the volume and idle screws. I did notice a little blue/whitish smoke, I’m hoping this would be normal until the new rings seat. I also torqued the axle nuts and had a stab at bleeding the brakes, so I should be able to get it off the axle stands and take it out of the garage in the next couple of days so I can let it run for a while.
gt1953
gt1953 is offline
PostPosted: Thu Jun 14, 2018 7:34 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Nice that it is getting back on the road. My recent purchase well March of this year, is still in progress. I like the single side draft kinda neat actually.
72 type 1
72 Squareback
260KMN
260KMN is offline
PostPosted: Thu Jun 14, 2018 11:20 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Great work on that muffler there bob. Just goes to show pretty much anything in steel is repairable if you take the time. Looking good
bobnorman
PostPosted: Wed Jul 11, 2018 7:54 am    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Thanks again for the support guys. Yes, with enough patience, anything steel can be bashed back into decent shape, even by a novice like me.
I'm still chipping away on the old gal. Now that the weather has finally turned decent, I’ve got her outside trying to get the engine tuned.
I think I may have a vacuum leak as turning the volume control screw doesn’t seem to do much, at least, not most of the time. Is there a setting I should be starting with? I had the volume screw at 2.5 turns to start. I also noticed I have a leak from the fuel pump. I think it’s from the top. I’ll take that apart again and see if I can figure out why. Also, the shifter is still not exactly where I want it. I’ve never had so much trouble getting a shifter adjusted correctly before!
Aside from that I have a horn issue to solve (grounding somewhere when turning the wheel), and have to reinstall the front fender and lights. The list is getting pretty short, I just wish I had more time to take care of the things on it!
MonT3
MonT3 is offline
PostPosted: Wed Jul 11, 2018 1:19 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
It’s looking good man! You’ve come a long way with it so be proud of your accomplishmenta nd some really big milestones you met. It’s around the corner and soon you’ll be taking it for a spin down the road. Doing great! Cool
MonT3
67 Squareback
64 Squareback
63 Squareback
Engine rebuild
Trailer rebuild
Mike Fisher
Mike Fisher is offline
PostPosted: Sun Jul 15, 2018 10:23 am    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Great that you have it running although poorly so far. Twisted Evil Spend your time/money on the drivetrain & interior.
My exterior diamond blue respray looks very close to the OG interior diamond blue. Spray your exterior only in the original color & save thousands of hours you'd need to strip/repair the funky OG paint! Idea
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
bally
bally is offline
PostPosted: Wed Oct 24, 2018 7:38 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
I love the way you're approaching this project, your skills and your excellent recording of it. Thanks for taking the trouble - I'm looking forward to future updates already. Cheers. Dave
bobnorman
PostPosted: Tue Oct 30, 2018 7:30 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Thanks for the comments guys. Yeah Mike painting the car would definitely be quicker and easier but I am doing my best to preserve the originality on this car and that includes the original paint. I haven't done much work on the car lately to be honest, I've been distracted by this beautiful green creature that showed up in my garage displacing my other less beautiful green creature.
The car was here a little longer than expected but is now returned to its rightful owner. So I was able to bring the squareback back in the garage. Good thing too, I ended up installing the Brazilian door seal and it's basically the same as if there was nothing there in terms of water tightness we had a few big downpours in the last couple of weeks and there was about 2 inches of water sitting in the driver's side pan.
So, in terms of progress the car is running really well now. I seem to have sorted out the carburetor, she starts and idles great. I straightened out the front driver's fender and reinstalled it. It looked okay to begin with but when I put on the signal light it was clear that it had been misshapen at some point. I installed the bumpers and I also sorted out the horn. I actually took the column apart three times to try and figure out where it was grounding. No dice. It's obviously something in the area of the bearing- so in the end I installed a button. That'll do for now. Also attempted to touch-up the paint a little on the front fender and driver's side of the bonnet- came out pretty good if I do say so myself.
So here's a couple of pictures just after I pulled it outdoors.
And a picture pretty much as she sits now inside the garage. I'm happy with the paint blending on the hood and fender, even though it's only roughly done at this point.
Bobnotch
Bobnotch is offline
PostPosted: Wed Oct 31, 2018 11:18 am    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Looks good Bob. Very Happy The blend job came out good, can't hardly tell from here. Wink Laughing Cool
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Erik G
Erik G is offline
PostPosted: Wed Oct 31, 2018 12:01 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
the door seals probably are not the problem in my opinion. water on the floor is usually from the front vents / hoses or bad windshield seal
car looks great, love the OG paint underneath
old_man
old_man is offline
PostPosted: Wed Oct 31, 2018 12:30 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
That's a beautiful 911
Bobnotch
Bobnotch is offline
PostPosted: Thu Nov 01, 2018 12:43 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Actually those Brazilian door seals suck. I'd rather have good used German seals than those. BTDT before, and got new German ones (worth the extra money).
Tram wrote:
Tram wrote:
bobnorman
PostPosted: Fri Nov 02, 2018 11:39 am    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Yeah, the irony is, I have a set of new German seals, but elected to put on the Brazilian one anyway. I figured it'd do for now (there was no seal at all in the DS door), and next year I'd tear both doors down and replace all the seals/channels/sliders etc. in one go. I'd heard they were crappy and fell apart fast, but I didn't expect them to leak like that.
I'm pretty sure it is that seal versus the vents, I did feel up around there and it was dry. I may get inside while someone hoses the car down just to make sure. Better do it soon though...winter is fast approaching. Sad
Mike Fisher
PostPosted: Fri Nov 02, 2018 1:01 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
I have to admit that your OG paint does look good w/blending in new paint where needed!
Forget that I suggested just spraying it all PPG etc Green. Rolling Eyes
fes
fes is offline
PostPosted: Thu Nov 08, 2018 4:42 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
[quote="bobnorman"][quote="Bobnotch"]
I'll volunteer for that job.I'll drink a beer of yours and have a laugh at your bewildered face while I'm blasting water at your car as you're inside wondering where the rain is pouring in from..sounds like an easy job Surprised
'68 Campmobile-Pedro
'15 Golf-Stella Blau
'56 Oval-The Turd (for now)
bobnorman
PostPosted: Mon Jan 07, 2019 2:43 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Nothing really to report in terms of an update. I didn’t get to do a leak test on the door seal (sorry fes), ran out of time before the cold and snow hit us. I’m shifting gears for the winter and will be getting back to work on my Ghia chassis. First order of business is to prepare and replace the transmission that I robbed for this thing.
Here she is one fine day when I pulled her out to move a few things around in the garage.
Jason37
Jason37 is offline
PostPosted: Mon Jan 07, 2019 7:06 pm    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Too bad mines apart, we are having a tremendously mild winter here. What is all that white stuff on the ground?
Bobnotch
Bobnotch is offline
PostPosted: Tue Jan 08, 2019 10:24 am    Post subject: Re: My 1964 Birch Green Canadian Squareback Reply with quote
Exactly. We had a brown Christmas, and decent weather. Supposed to cool back down starting tonight. We've had a couple of dustings, but nothing like what you have in that pic.
If it wasn't for all the salt, I'd have my Notch out getting some exercise.
Tram wrote:
Page 11 of 15
