Lohe Samba Member
Joined: June 26, 2007 Posts: 662 Location: Chandler, Az
Posted: Tue Jun 05, 2012 8:29 am Post subject: Panel removal help |
Ok I need a quick 'schooling' please!
I have a 59 panel which has been SERIOUSLY bondo'd and has SERIOUS frame rust (basically the entire frame is falling apart, it has huge amounts of bondo on every panel except the upper half of the bus and even panels of sheet metal riveted all over the place.. it's totally not saveable without MAJOR work and cash).
I also have a 60 panel which has a good frame and just your normal rust in the normal places.
What I want to do is remove the upper side sheet metal from the 59 and weld them on the 60.
I have some spot weld removal 'bits' from Harbor Freight and a mig welder. Is there an easier way to do this? |
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Tue Jun 05, 2012 8:40 am Post subject: |
I try not to drill through both panels if possible. Sometimes I will use a small angle grinder to remove just the back side of a spot weld, if I can sacrifice the back piece. Sometimes I just use a center punch and a regular drill bit. |
werksberg Samba Member
Joined: February 08, 2005 Posts: 2151 Location: Prescott Valley, AZ
Posted: Tue Jun 05, 2012 10:54 am Post subject: |
Eastwood & other tool suppliers has a special spot weld hole saw bit....has a live center on it. _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
Z Samba Member
Joined: June 15, 2003 Posts: 2517 Location: galveston, tx
Posted: Tue Jun 05, 2012 9:50 pm Post subject: |
I found the HF bits too soft - they dulled VERY quickly. Bought a set from the Snap-On truck and they were awesome. |
Posted: Tue Jun 05, 2012 10:00 pm Post subject: |
Lohe Samba Member
Posted: Wed Jun 06, 2012 8:05 pm Post subject: |
Thanks guys, I'm going to try an angle grinder since the lower panels are absolutely shot. The only reason I'm swapping out the panels is I got a KILLER deal on the 59 and if you wanted to rebuild it you would literally have to rebuild the entire 'frame' and the floor and most of the other metal, basically just make an entire bus out of green panels and put the plate on it.. and the 60 has windows cut in it and I really want factory side panels! |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 970 Location: Ocean City > Boca > Pompano > Kirkland > Eugene
Posted: Wed Jun 06, 2012 9:14 pm Post subject: |
Seems like you could patch it easier (and cleaner). Then swapping the belt line up? _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Single carbs are for lawn mowers! |
Don't forget those seat-belts!
Click to view image |
Lohe Samba Member
Posted: Thu Jun 07, 2012 6:03 am Post subject: |
KevinAlbrecht wrote: |
Seems like you could patch it easier (and cleaner). Then swapping the belt line up? |
I think the end result of swapping the outer shell is going to be cleaner, but yes, probably a lot easier just to patch it. So much less fun though! |
Posted: Thu Jun 07, 2012 6:55 pm Post subject: |
Lohe wrote: |
I would think lining up an upper sectioned half is fraught with complications a "non-professional" would not have the experience to be able to recover from completely, and and then you would be left with a hack job that you would need help fixing.
Vs.. Patching some windows that could be worked on after the fact, as time facilities and budget permits.
Now, I you may have mad skills, so more power to you.. but I would hate for you. I get yourself in a situation that no one wants to be in. _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Posted: Thu Jun 07, 2012 6:56 pm Post subject: |
Lohe wrote: |
Wait, what...?
WideFive wrote: |
