Sand rail off of the floor pan?
AustinBaja12342
AustinBaja12342 is offline
PostPosted: Wed Jun 06, 2012 4:04 pm    Post subject: Sand rail off of the floor pan? Reply with quote
I have seen plenty of sand rails but my dad had one that he said was built off of the floor pan, unlike the ones you see today. I was wondering if any one has done this or has a picture of one like this. I have been thinking about making one off the floor pan what are the pros and cons of this and not a kit like the Warrior? Thank you
ZARJDR
ZARJDR is offline
PostPosted: Wed Jun 06, 2012 6:02 pm    Post subject: Reply with quote
Here is one that originated in my home town, it has been in national publications. It retained the center tunnel and rear set, not really
any pan left, but you get the idea.
2006 RAM 1500 HEMI 4X4 92 LT250
06 Raptor DP1776 Sandrail
02 HONDA 400EX
03 YAMAHA WR450F 74 BAJA
AustinBaja12342
PostPosted: Wed Jun 06, 2012 8:53 pm    Post subject: Reply with quote
Thanks that helpful but I was looking for something that has the original wheel base and a roll cage.
pafree
pafree is offline
PostPosted: Wed Jun 06, 2012 9:28 pm    Post subject: Reply with quote
this is one of the better ones i have seen:
http://www.thesamba.com/vw/forum/viewtopic.php?t=457699&start=0
here is another. really basic but it grows on you:
http://www.thesamba.com/vw/forum/viewtopic.php?t=461879&start=0
cons: weight, limited on wheel base, and the tubes that make up the floor in a rail (unless you use heavier plate(more weight)) help the strength of the cage.
AustinBaja12342
PostPosted: Wed Jun 06, 2012 9:43 pm    Post subject: Reply with quote
thanks that was very helpful but why do people rarely do this, it seems easier than making a full on sand rail.
pafree
pafree is offline
PostPosted: Wed Jun 06, 2012 9:51 pm    Post subject: Reply with quote
it is old school. with a sand rail, all the works (clutch and throttle cable, shift bushings that are in the tunnel) are easy to get to. you can get that more laid back seating position. you can make the car as long or short as you want. just a neater package. less work unless you have a tubing bender and welder to slap a VW beam and transaxle on a rail and you are almost done.
nomis
nomis is offline
PostPosted: Thu Jun 07, 2012 11:39 am    Post subject: Reply with quote
You might find this interesting:
http://www.powersliderides.com/index.htm
probably not available by mail order though....
Look here for my baja videos: http://www.youtube.com/profile?user=nomis45mm&view=videos
AustinBaja12342
PostPosted: Thu Jun 07, 2012 9:44 pm    Post subject: Reply with quote
so is the actual sand rail better or is it just because it nicer looking and is easier to work on? And what are some pros/cons
PacificBaja
PacificBaja is offline
PostPosted: Thu Jun 07, 2012 9:50 pm    Post subject: Reply with quote
Rolling over would be a HUGE concern. I grew up buggying in the early 70's and Ive seen a few similar to the above.
AustinBaja12342
PostPosted: Sun Jun 10, 2012 8:54 am    Post subject: Reply with quote
i thought it would be fine with the roll cage or are you just talking about the first one?
AustinBaja12342
PostPosted: Sun Aug 26, 2012 9:12 am    Post subject: Reply with quote
does any one have some other pictures or videos of them?
