Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Thu Oct 16, 2014 9:11 am Post subject: |
just pulled the bumper straight...the rest should be fixable with a hammer
before
after
_________________ Stuart Zickefoose
206-841-7324
[email protected] |
1blk66 Samba Member
Joined: June 08, 2013 Posts: 7 Location: Vancouver, BC
Posted: Mon Nov 10, 2014 11:26 am Post subject: did you ever get the A/C back in and working? |
Hi, I have a 72 with the same looking A/C set up.
Also, where did you end up getting your replacement pop top canvas from?
Thanks |
Posted: Mon Nov 10, 2014 3:55 pm Post subject: |
We homemade ours, but its too small, id recommend a busdepot or gowesty one, but spend the extra and get a high quality, as the low quality ones really suck. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Dec 08, 2014 11:21 pm Post subject: |
so the motor on this, i found to have a fairly large issue. i found the distributor drive gear to have centrifugal play in it, an amount that tosses my timing near 10* of play.
i took the drive gear out, and it has both shims under it, and the gears both dont show major signs of wear, but yet it definately has play.
help?
am i seriously looking at a worn out brass gear on the crank? i am NOT rebuilding this motor...if its done, its done and im finding a nice subaru doner...
would like to push this motor through next summer if i can.... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
1967250s Samba Member
Posted: Tue Dec 09, 2014 12:33 am Post subject: |
I thought it was only supposed to be one shim under the dist drive gear. Better check yer manuals. _________________ '72 Elm Green Deluxe |
Posted: Tue Dec 09, 2014 12:37 am Post subject: |
I thought it was only supposed to be one shim under the dist drive gear. It actually has three bumps that would make the gear jump if you had more than one( at least mine did). Better check yer manuals. _________________ '72 Elm Green Deluxe |
Tcash Samba Member
Posted: Tue Dec 09, 2014 7:21 am Post subject: |
Stuartzickefoose wrote: |
To confirm the timing variation is in the dist drive.
Pull the dist and use a big screwdriver and twist the dist drive gear clockwise and counter clockwise and see what you get.
Someone has shimmed the drive gear. This is ok. It is an old Wilson tip. It keeps the dist drive gear from riding up and down and causing timing variations.
help?
Maybe the drive gear. You can try to replace that first.
would like to push this motor through next summer if i can.... |
Good Luck Stuart |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Fri Dec 12, 2014 3:00 pm Post subject: |
Play like this?
Have you actually observed the timing scatter? What distributor? Make sure your spring is seated properly, mine worked its way down once; don't let that happen. If DVDA, try an SVDA and report back.
www.airschooled.com |
Campin68 Samba Member
Joined: March 22, 2014 Posts: 79 Location: Issaquah, WA
Posted: Tue Dec 16, 2014 7:08 pm Post subject: |
Hi Stuart. I enjoyed reading the thread and even got a little teary over the adventures you and your dad had. I look forward to meeting up soon.
Josh _________________ I'm doing all of this for the first time.
Rita, '68 Camper |
Posted: Sat Dec 27, 2014 6:56 pm Post subject: |
The bus is officially parked till a motor swap can be done.
Clutch is slipping badly, multiple oil leaks, suspect a valve pulling through the head, and a worn distributor drive gear. Next step is a fresh engine and trans, and unless i find a cheap useable motor ready to swap In, its getting a subaru. The condensor has the mounts already, so no a whole lot to it besides cost and time. Its been fun Mr. sticky, till next time.
Dads now daily driving my new camaro.... _________________ Stuart Zickefoose
206-841-7324
[email protected] |
bigluelok Samba Member
Joined: January 28, 2009 Posts: 55 Location: Altadena, CA 91001
Posted: Wed Dec 31, 2014 2:25 pm Post subject: |
just making sure i can find this thread tonight when i get home. _________________ Thanks for your time,
Luis
Click to view image |
Trailjunky Samba Member
Joined: April 04, 2005 Posts: 476 Location: Ellensburg, WA
Posted: Wed Dec 31, 2014 3:37 pm Post subject: |
I don't know if anyone has mentioned this, but the tallest snow covered peak on the left is Mt. Stuart...Stuart. _________________ 1970 Westfalia w/ Adventurewagen Top |
Posted: Mon Jan 05, 2015 12:43 am Post subject: |
Definately want to go explore my mountain someday...you down? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Mon Jan 05, 2015 2:24 pm Post subject: |
The Teanaway valley is a great place to bus drive. Many great options for bus pilots to consider. The FS road that dead ends at esmerelda basin trailhead is a short but fun drive. From there, its five miles round trip hike to longs pass where Mt. Stuart is all up in your face.
I'd be down for a Teanaway trip once I have brakes again. Time to start selling stuff. _________________ 1970 Westfalia w/ Adventurewagen Top |
Brian Samba Moderator
Posted: Fri Jan 09, 2015 3:59 pm Post subject: |
Brian wrote: |
i know. but they are going to get to drive the 80 i just got (see signature line) and i still have my 78. and my squareback. and we done have enough parking to keep them all. sticky needs a new loving home! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Thu Jan 22, 2015 7:36 pm Post subject: |
just wanted to sum up this thread. the bus was driven onto the truck today. sort of a semi sweet bitter sweet kind of thing. as we drove our final block together, the oil came on and stayed on, and was on throughout the entire loading process for about 5 minutes. finally went off once it was on the truck. got to drive it up on to the truck myself, since he was throwing a fit and barely wanted to make it up the slope.
video here:
Stuart drives sticky the last time:
ill upload some final pix in a bit. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Zelten Samba Member
Joined: September 16, 2008 Posts: 1335 Location: Issaquah
Posted: Thu Jan 22, 2015 8:21 pm Post subject: |
I'm sorry for your loss. Is it going to Europe? And why didn't he have you put it on the bottom of the trailer? _________________ 1978 Delux Campmobile
03 Jetta TDI
15 Q7 TDI |
Posted: Thu Jan 22, 2015 11:36 pm Post subject: |
Such a sweet video!
It probably wouldn't fit on the bottom.
This way, it can leak oil all over some soft-top Corvette.
