tkgeorge_99 Samba Member
Joined: September 30, 2010 Posts: 149 Location: Sacramento
Posted: Fri Jun 08, 2012 7:34 pm Post subject: flywheel o ring problems! |
Okay, I am getting a little frustrated. I have a 1970 with a newly rebuild type 1, 1600 DP. I have installed the bus's engine twice now > ! The first time, I got some oil leaking at the seam from engine to transmission. This was the first time I have ever changed a flywheel so I followed the book and did my best.
So, I called an experienced vw friend who was nice enough to come over and help me try it again. When we pulled off the flywheel, the o ring was mashed and causing the leak. So we remeasuered the end play- looked good at .004. He helped me carefully install another o ring. we lubed it real nice and made sure it was seated in the groove. And he helped me carefully re install flywheel- torqued to 220. Put the engine back in and now I am having the same oil leak as before. After my test drive I am getting a puddle about 3in across. I am using a lighter weight oil 20w-50 right now for break in. So luckily the o- rings are cheap but it does take me a few hours each time to pull the engine and I am getting pretty frustrated. Not to mention my wife, who is gettting very tired of me working on the bus. Anyone have any ideas of why this keeps happening? Any suggestions for next time?! |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Fri Jun 08, 2012 7:48 pm Post subject: |
Usually, when the o-ring leaks, you get oil on the clutch disk. If the disk is dry, then it's more likely the main seal. Installation of this seal is somewhat critical, which is to say, if it's not done correctly it will distort and leak. You can't just hammer it in - it really needs to be pressed in carefully and symmetrically with an appropriate tool, and to the proper depth. The mating position on the flywheel needs to be correct. This mating area must be the right diameter. The seal must be pre-lubed. The drain hole behind the seal needs to be checked that it is clear and clean, otherwise the oil level behind the seal will be too high or under pressure.
Other possibilities are the cam plug, oil galley plugs, or crankcase ventilation issues.
It is assumed that the crank is in the exact center of the seal. On an improperly line bored case, this may not be so, so check it.
I always recommend running the engine out of the bus. All you need is an old bell housing to hold the starter. _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
ddesh Samba Member
Joined: February 20, 2005 Posts: 165 Location: NW AR.
Posted: Fri Jun 08, 2012 8:01 pm Post subject: |
Also check the case for a crack behind number 3, just another area to check. |
Desertbusman Samba Member
Posted: Fri Jun 08, 2012 8:21 pm Post subject: |
220 ft/lbs? That's not tight. Spec is 253 but probably most of us go tighter.
I don't think that anyone would consider 20W-50 as a lighter oil or a break-in oil for that matter.
Did you follow Tom Wilsons instructions on installing the seal, O-ring, and flywheel? And a sealant? I used Permatex Aviation on mine. What about a wear groove on the flywheel? Sometimes selectively installing the seal at a different depth is what's needed.
This time take special care in inspecting the plugs and maybe do Wilsons proceedure for checking for the #3 area case crack. I had a case that I had carefully inspected but had a pro builder go over it for cracks. And it did have a crack behind #3 where Wilson describes it. Naturally I havn't used that case but carefully looking at the area where the crack opens up you just plain can't see it even after knowing where it is. _________________ 71 Superbug
71 Westy |
SGKent Samba Member
Posted: Fri Jun 08, 2012 8:25 pm Post subject: |
there are several other common reasons oil leaks there, several which have been discussed.
1) *bad or hardened main seal and/or groove in the sealing surface on the flywheel
2) *shims have cut a groove in the crank thru to the dowel pin holes
3) *case has cracked. Behind #3 is common but there are other spots.
4) the fastener at the base of the case near the flywheel is missing, *stripped or loose.
5) *The oil is not engine oil but rather transmission fluid from a bad input shaft seal
6) The cam plug was not installed properly and is leaking.
7) oil is running back from a cylinder giving the illusion it is leaking from the engine to transmission seam.
There are probably more I have not seen or heard of. Things like the crack behind #3 can be protected against before it cracks by sending the case to someone who welds plates in those areas to strengthen the case. I have put * by the ones I experienced in 400,000 miles driven in my 1971 dual port during the years I owned it. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Fri Jun 08, 2012 8:44 pm Post subject: good advice |
Okay- thanks everyone so far. Since the last o ring was mashed, I assumed that was the problem.Clearly the mashed o ring was a problem but perhaps not the only problem.
Maybe the main seal as well? The clutch was completly dry. Does everyone agree that with the o ring the clutch plate would probably be wet? thus indicating a possible main seal issue as well as the mashed o ring.
so I have several good suggestions that I will follow up on. First, running the engine outside the bus. I don't really have a set up for that but perhaps I could find a friend or take it to a shop to have it looked at. That would give me a pretty good idea of where its leaking from, right?
The case is a never used brazilian universal, so I don't think it has any cracks but a close inspection might be in order.
I am sure its engine oil and not transmission oil. I had this bus running with previous engine with not problems with imput shaft seal. and it doesn't smell or feel like the heavy weight gear oil.
So unfortunately it sounds like it could be number of problems. So I will pull the engine- AGAIN. try and run it out of bus, if I can find a way to do so to see what going on. If I can't then I will take off the flywheel, check the o ring. maybe pull the main seal and give that a go again and try again. Or I may bit the bullet and give up and take it to a vw shop to have them figure it out. |
SGKent Samba Member
Posted: Fri Jun 08, 2012 8:59 pm Post subject: |
usually when oil gets onto the flywheel from the glandnut area there are some holes in the flywheel that let the oil run onto the back of the flywheel to keep it off the clutch. You may want to look at the back of the flywheel when you pull it. Also wipe the case with a rag and some solvent. Let it dry and see if oil appears anywhere. You could have something like a pinhole in the casting that was missed in quality control when they made the case. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Fri Jun 08, 2012 9:33 pm Post subject: |
Would this dye and an ultraviolet light help in finding the leak?
aeromech wrote: |
dan macmillan wrote: |
aeromech wrote: |
Save yourself the work and time of the initial degrease. Add some ultraviolet dye for engine oil, run the engine then take a black light and look for the signs of the leak. Once found you can repair the leak and wash it all at at the same time. If you leave the dye in the engine you can trace future leaks. |
That's a new one for me. Where can a person locate some ultra violet dye? I guess you need a black light too, huh? |
Many auto part suppliers carry the dyes and lights. Different dyes for engine oil, transmission, coolant, AC refrigerant. AC Delco/General Motors dealers have their own line http://www.acdelco.com/html/pi_vehcare_mech.htm
Click the select button and choose gas engine fluorescent oil dye
Yes you need a light, they sell a UV flashlight for the purpose http://0-0-0checkmate.com/Hot/Black_Lights.html or check ebay |
That's a very cool idea for finding a chronic oil leak. At my old airline I would clean the area very well and then use a spray can of developer. This would dry as a white powder on the engine and then any seeps would stand out like a sore thumb. The developer was normally used when doing dye penetrant non destructive testing (looking for cracks). |
Aloha
tp |
Posted: Sat Jun 09, 2012 8:30 am Post subject: actual o ring self destruction quetions |
Okay- well it will be a few days but I'll pull the engine and see what I find. Thanks for everyone's help. I am hoping that its just another bad o ring or perhaps a main seal thats not seated properly.
I was a huge step for me to swap enigines, definately out of my comfort zone mechanically so I was really hoping that it would have gone smoother. But on the upside, the new engine sounds and runs great. Its just a matter of finding what going wrong with the oil leak up front.
So if I pull it off again and find another mashed o ring, what next? Is there something that I am doing or could be causing the o rings to self destruct? I want to believe its something simple . . . |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Sat Jun 09, 2012 8:54 am Post subject: |
If it's the o-ring again, I would suspect someone has sold you some improper parts. When installed, the o-ring is barely
visible in its groove in the flywheel, it's hard to imagine what could cause a correctly sized o-ring to keep getting mashed.
Also, I think real VW o-rings are graphited, no lubrication needed.
Could also be a burr or lack of slight chamfer on end of crank. _________________ '67 bug: seized by the authorities
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sat Jun 09, 2012 9:18 am Post subject: Re: actual o ring self destruction quetions |
tkgeorge_99 wrote: |
It is a good idea to get a little triangular file out and lightly dress the very edge of the crankshaft for a very small chamfer. At the very edge, a 45* chamfer of no more than a tenth of a millimeter. This helps the o-ring ride the edge faultlessly. You must set up the operating theatre like battlefield brain surgery, no metal flakes getting into places they do not belong. A piece of sticky saranwrap works pretty well.
Please check the fit of the front main seal over the flywheel. It should take a little pressure to get the lip over the shoulder. There are such abysmally awful parts out there these days that the word "new", as in "new main seal", does not mean that you don't have to inspect it very carefully. I installed some no-name front seal on a Type 4 engine that was a finger press-fit into the case. That sort of loose fit will fall out when the engine warms up.
Does this engine have pressed in gallery plugs or tapped threaded gallery plugs? If they are steel, check each one for security in the tighten direction only. If it moves under modest torque, remove it and either put in a good thread sealant like the Victor Reinz Vanagon head sealant, or go for the gusto and use slow-set JB Weld in the threads and on the perimeter of the plug at the case. This must be alcohol cleaned and perfect before application.
Gallery plug leaks can drive you crazy. They leak only when the engine is warm under oil pressure. If you clean it at home in the garage, and it is perfectly dry the next morning "yay, I fixed it!" but 30 miles of driving later, it has a pool under the engine at the gas pumps, that points towards gallery plug.
Colin _________________ www.itinerant-air-cooled.com |
Posted: Sat Jun 09, 2012 10:54 am Post subject: gallery plug leaks |
Hmmm. . . to show my ignorance I don't even know what that is, which gives you an idea of why this is so frustrating for me. For more background, I bought this long block, switched over all the things like generator, oil cooler, etc and then had to switch flywheels because the flywheel that came with engine had a different size clutch. Don't worry it was a 12V flywheel as well. Both flywheels have the same outside diameter and same teeth. So I put my old flywheel from the orginal engine onto the new longblock. On the orginal engine, I had no issues of leakage from the front.
So Gallery plugs. . . could you give me an idea of where to look for them? And does that sound characteristic of the leaks I am describing?
When I first fire up the engine at a fast idle and then let it idle for a few minutes- very small leak- maybe a drop forming on bottom of case. If I actually drive, even a short distance, a mile or so, I get a puddle about 3 inches across as it drips out.
I am pretty sure I got the right o ring- a reputable vw place sold it to me as well as my friend who has done this a dozen times verified that it looked right. I wonder if I have a burr on the crankshaft or as someone else noted, perhaps while setting timing or putting on belt I turned engine over while the o ring didn't have proper lubrication and it mashed. Could that have happened? |
Posted: Sat Jun 09, 2012 12:18 pm Post subject: |
It's most likely just a damaged inner sealing surface on the main seal. get a new one and put it in. Get the red German seal.
If you don't have Tom Wilson's engine building book get it now. Between Colins advice and Wilsons instructions, just go do it. _________________ 71 Superbug
71 Westy |
Posted: Sat Jun 09, 2012 7:57 pm Post subject: wilsons book |
yeah I have the wilson book and it is getting well used. I have finally figured out a plan after sorting thru all the helpful advice.
I am going to pull the engine, take off flywheel, look at o ring, make sure there aren't any burrs or damage to crank end. carefully inspect mating surfaces. Take out main seal, look around real well for problems. Replace o ring and main seal following the book to the letter, retorque gland nut to 220+, and re install an pray I have found the problem and the leak stops. |
Posted: Sat Jun 09, 2012 8:26 pm Post subject: Re: wilsons book |
retorque gland nut to 220+, |
Where do you keep comming up with this 220 ft/lbs?. Not from Wilson, Bentley, or anyone on the Samba. _________________ 71 Superbug
71 Westy |
eashc Samba Member
Joined: April 10, 2012 Posts: 340 Location: Ventura County
Posted: Mon Jun 25, 2012 8:54 am Post subject: |
220 sounds light to me also. I always went for close to 250 as possible. |
SGKent Samba Member
Posted: Mon Jun 25, 2012 11:13 am Post subject: |
253 on the single gland nut. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Jun 25, 2012 2:05 pm Post subject: |
This get scary after a while _________________ 71 Superbug
71 Westy |
Posted: Mon Jun 25, 2012 8:04 pm Post subject: |
254 on the drum nut, clockwise both sides
Aloha
tp |
