flyboat Samba Member
Posted: Mon Jun 11, 2012 6:47 pm Post subject: Rear Disc brakes, Who's the best |
I have complained in another thread about my crappy rear disc brake kit. The pads don't sit square to the rotor and they vibrate and moan badly. I am going to buy another set but I don't want to make the same mistake. My current set is apparently an earlier Empi version. When I bought them the vendor did not mention they were Empi
What are you running with good success
I won't be buying Airkewld. That's alot of cash.
Thanks _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
09 Z06 Vette track car |
Jamies74sb Samba Member
Joined: March 22, 2011 Posts: 398 Location: Fresno ca
Posted: Tue Jun 12, 2012 7:55 am Post subject: |
I using the 944 Porsche rear . A/c industries in the front . It stops on a buck . I got lucky & found 2 at. A junkyard over here got the spare tire too . |
Posted: Tue Jun 12, 2012 6:01 pm Post subject: |
I thought about AC ind. for the rears. I have a partial set of 944,s Im saving for the next project _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
Posted: Tue Jun 12, 2012 6:19 pm Post subject: |
I havent figured out how to keep the front from squeeking tho just one side I don't know what that's all about I never had breaks do that before . |
lukel Samba Member
Joined: October 07, 2011 Posts: 213 Location: Bellingham, WA
Posted: Tue Jun 12, 2012 6:30 pm Post subject: |
I have AC's on my front and they work great! Easy to install, good price, Quiet.
I like them alot! |
Airkewld Samba Member
Joined: November 14, 2003 Posts: 3149 Location: Goodyear, AZ USA
Posted: Sat Jun 16, 2012 8:02 pm Post subject: Re: Rear Disc brakes, Who's the best |
flyboat wrote: |
The pads don't sit square to the rotor and they vibrate and moan badly. My current set is apparently an earlier Empi version. When I bought them the vendor did not mention they were Empi |
Are you saying that the caliper is mounted crooked or the caliper bracket is bent? I would suggest solving the issue that you have and save your money.
Not sitting square - Measure the distance from one ear to the blade of the rotor and from the other ear to the rotor. If it is off, fix it by straightening it be tapping it, surfacing it etc. If the castings have casting marks that are allowing th caliper to sit crooked, surface them so they sit flat.
Vibrate - More than likely, it is from the caliper being crooked but you can 45 the edges of the pads to eliminate the sharp edges. Another side of the coin would depend on the master cylinder you are using. If you are using a stock version and they vibrate or moan after you apply or during, you need to upgrade the master to a DISC master. Also having a properly adjusted e-brakes helps with that as well.
Although I would enjoy working with you, if you run our brakes and they do the same thing, the budget was blown for other reasons. Check it out and let me know what you find out. _________________ TheSamba members-only discount - Samba24
Win a FREE Chassis Rebuild - https://airkewld.co/WinAChassis
Learn from a PRO on Patreon - https://www.patreon.com/Airkewld
FAQ - https://airkewld.co/FAQ
View our Industry Leading Products - https://www.airkewld.com/Products-s/2322.htm
We made a iPhone Ringtone with a Classic VW Turbo Engine - https://airkewld.co/RingtoneTurbo
YouTube Channel - https://airkewld.co/SubSamba |
Posted: Sat Jun 16, 2012 8:36 pm Post subject: |
The caliper seems to be manufactured out of spec. As it is, the pads hit on the outside of the rotor (outside being the largest diameter portion of the rotor). The inside of the pads are off the rotors by .025-.035". So teh only portion of the pads that hit the rotor is the very outer portion. It marks the rotor about 3/8" width. Also, when the brake pedal is pressed. The caliper flexes and makes the condition worse. Nothing seems to be bent, just poor quality parts. This is the case with the left and right side. I thought about grinding the pads so the outer portion is thinner to make teh pad have full contact with the rotor. But I'd rather have it correct as it should be. This is not a problem that has just acurred. It was this way as installed new. The brackets are stamped steel. but that doesn't make teh pads hit on the outside and not on the inner diameter. As I can tell, it is a function of the caliper itself. If I removed teh caliper from the bracket and pressed teh beake pedal the pads would come together and make contact at the outer portion with no contact at teh inner portion. _________________ 79 super Vert
62 Ragtop Bug
66 tintop Westy
Porsche 914
