Vana Guy Samba Member
Posted: Tue Jul 26, 2022 12:49 pm Post subject: Rear seat remove, '90 tin top, seat that folds into bed SOLVED |
Been searching around a bit but can't seem to find anything on removing the rear seat that folds into a bed.
I need to fix the rear heater, and there is a bar that runs across the underside of the seat that prevents the heater cover removal.
Any help would be appreciated. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9615 Location: Western WA
Posted: Tue Jul 26, 2022 1:49 pm Post subject: Re: Rear seat remove, '90 tin top, seat that folds into bed |
Cool.
Easy question because I did it a couple weeks ago.
I had to unscrew the front wooden kick panel.
Byut then my bar flexed far enough by hand, to get the heater cover off.
I pulled HARD on it by hand and was able to get the heater cover off, and back on. _________________
....KTMs, GasGas, SPOT mtb
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Tue Jul 26, 2022 2:59 pm Post subject: Re: Rear seat remove, '90 tin top, seat that folds into bed |
Figured it out.
Lift bench up and remove 4 small bolts securing bench to seat frame, located 2 on each side of bench bottom on the ends. Bench lifts out easily. You have to remove bench to access the bolt(s) in next step.
There are 2 large bolts on each side of van securing seat frame. Just remove the 2 on one side, you can then easily pull the bar far enough to remove heater cover.
Done |
