Sage79 Samba Member
Joined: September 13, 2008 Posts: 433 Location: Holland MI
Posted: Thu Jun 14, 2012 6:22 am Post subject: |
I originally installed the BD seal w/o bulb on my '79 but the roof rack rattled at speeds over 45 from air pressure. I spliced in a length of bulb seal (left over from the pop-top) to the front section between the mounting screws. That stopped the air flow rattle but still allows plenty of drainage on the sides. Best of both. _________________ Dirk
'79 Westy 2.0FI
'73 Sportsmobile 1.7dual Solex 003Auto - now my daughter's
'77 delux 2.0FI 090Auto - now my son's |
Bala Samba Member
Joined: December 04, 2003 Posts: 2613 Location: Austin, TX
Posted: Thu Jun 14, 2012 7:02 am Post subject: |
busdaddy wrote: |
Javyd wrote: |
What web browser are you using because I don't see that either! |
I've got IE8 or 9 or something and it works for me, I like it, no more BEEP! BEEP! to scare the shit outta you if your kid forgot to turn off the speakers |
IE7 here (at work).
Yeah, that beep could be a little annoying, more so when you have head phones on!
I like that they still have the "wish list" option.
I use that all the time. You do have to create a new account, so your old
wish lists are lost I guess. No big deal. _________________ 1976 Westy
1966 Beetle |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Thu Jun 14, 2012 7:31 am Post subject: |
Yeah, Im going to need some pictures here. I have no fucking clue what y'all are yammering on about.
Please pardon mys ignance. _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
poptop tom Samba Member
Joined: July 27, 2004 Posts: 1607 Location: The Hoosier State
Posted: Thu Jun 14, 2012 7:59 am Post subject: |
I purchased that kit (granted this was six years ago) and its worked pretty darn good.
http://www.busdepot.com/WESTYRUBBER
It appears to be the same thing they have been selling for awhile.
Mine has an inside bulb around the large poptop section.
A flat piece that fits around the front of the poptop where the main tent screen is. Which allows a tiny bit of air to get in, but nothing noticeable other than my original tent gets filled with some air inside the cabin area.
And a seal (looks like a piece of rubber trim that pushes up onto the bottom portion of the rack. Thisseal has worked really well. I haven't noticed any issues at all with it. I'm 99.9% sure it isn't blubed on the inside. _________________ '76 Deluxe Campmobile |
Bev1 Samba Member
Joined: June 13, 2012 Posts: 5 Location: Twin Cities area, MN
Posted: Fri Jun 22, 2012 11:35 pm Post subject: Q about proper prep before placing on the seals here...and |
Hi, I'm new to this site. I too just got a full set of new seals with a bulb from Werksburg (well the flat top pop top seal has no bulb and it's the only one that needs to be glued). What is the best glue and technique too.?
I have a few questions and searched and so far only got part answers.
How do I prep the topper fiberglass edge removing the old, glued seals and make sure the top edge is clean enough to make the Werksburg seals I got that compress on work well, stay on, and not leak?? I have a '79 sage green Westfalia stick and am going to part with it after 21 years (sob, sob) because I have pain issues making her too hard to drive for long periods. I've been trying to get her road worthy and drum up interest to get others to buy her. I don't want to give her away and I'd like the new owner to take care of her. I was ill for so long (several years) and didn't take care she didn't get some (gasp) rust eating at her . It's not as bad as floors rusted through, but I'd say she's between condition 3 and 4 right now. But, her interior and engine are in great shape ... < 83,000 original miles mostly HWY. I digress...
The question here is about proper prep before placing on the seals.
I am concerned about not taking off the gelcoat, but heck, that gelcoat may already be off. I have not cleaned the "white" top. Where do I go to read about properly cleaning the top and making it nice and white too? I read one forum conversation and most everyone had a different opinion what was the best way to clean and brighten the top. Should I try doing that after taking seals off and then put new seals on? I'd rather the new owner do all that.
I like Westfabulous's hint for the luggage seal (I got the bulb seal for the luggage top too):
"go to the Home Despot and buy a package of small clear silicone cabinet door bumpers with the self adhesive back. Stick them to your bus in a few spots, underneath the seal, and they will hold the bulb off the bodywork, and facilitate water egress." |
Jockomo Samba Member
Joined: October 11, 2006 Posts: 163 Location: Lafayette, LA
Posted: Sat Jun 23, 2012 7:02 am Post subject: Re: How to save 20 bucks |
Glenn wrote: |
This should of been posted in the feedback topic. |
Maybe so, but then again I know I would not have seen it there and therefore would have made the same mistake as I have that part on my shopping list.
Thanks for the heads up.
Oh and for you guys who can't see the new site, Try hitting F5 to refresh your browsers cache _________________ '75 Westy with '78 2.0L engine. |
Hoody Samba Member
Posted: Sat Jun 23, 2012 7:24 am Post subject: |
Bev 1 I would send back the luggage rack portion of the kit to werksberg. I would ask them to send you a length of seal the same size with the bulb. Maybe their front luggage seal is different but it sure looks the same as the 1st one I through money away on from the BD. you should not have to glue that seal on period. Several places sell that seal with the bulb with no gluing required. If you glue it on and you get the same results many of us have you will really have a problem on your hands. |
Bev1 Samba Member
Posted: Sat Jun 23, 2012 7:47 am Post subject: |
Thanks Hoody for replying. The luggage rack seal does not need gluing and has the bulb. Its only the Pop Top flat seal without bulb that they say to glue.
My top Question here is how to prep getting the old, bad seal glued on off (mainly the Pop top sections are critical now).
Do I just have someone scrap it off? Someone posted to sand the left over old seal, but I think that will remove any gelcoat that might be there. I want this done right the first time and not damage to Top.
_________________________________________________________-
Life is a test. It is only a test. If this was your actual life, you would have been given better instructions. |
cefalu Samba Member
Joined: May 14, 2012 Posts: 135 Location: San Francisco Bay Area, CA
Posted: Sat Jun 23, 2012 8:44 am Post subject: |
I just restored the pop top on my '74 Westy. I also used the Bus Depot seals. I have not driven my bus yet, but the seals were easy to install. No gluing is required.
However, I took the front and back tops off, since I wanted to install a new canvas boot and paint the whole top too.
I think it would be very difficult to install the luggage rack seal with a bulb if the luggage rack section was installed. Removing the luggage rack section requires access to 4 bolts under the roof which requires removal of the wood ceiling above the drivers section, which was a little tricky. As I recall the original seal on the front had no bulb.
Once I get an engine installed and get it on the freeway I will report back regarding the BD luggage rack seal, and the wind vibrations.
Regarding the glue I encountered, I used a carpenters wood chisel to carefully scrape away the old glue. Then I painted the whole top with Rustoleum as described elsewhere on this site. I also installed a new Bus Depot pop top boot, it fit perfectly and I can't imagine installing the boot with the pop top in the bus. _________________ 1970 Jeepster Commando
1974 Volkswagen P27 Westfalia Camper
1974 Mercedes SL350 Euro Market Model
1974 Jeep J-20 ZZ
1985 Alfa Romeo GTV6
2005 Toyota 4Runner V8 Sport
2008 Mercedes E350 Wagon
2018 Lexus GX460 |
Hoody Samba Member
Posted: Sat Jun 23, 2012 9:07 am Post subject: |
Sorry Bev for misreading your post. The BD flat seal requires no glue and is 20 dollars. For that much cash personally I would not mess around with any glue. I do not remember there being any residual glue when I removed my original one. If there was any it came off easily when I wet sanded the entire top with 400 grit. So I guess my best guess would be to tape off the edge and wet sand with 400 grit the 1/4 -5/8ths inch that the seal will push on to. One thing I will add is leave an extra 1/4 inch on both sides of this seal to allow for when the top is lowered. I am on my second seal because of this. Another reason not to use glue. Hope this helps. |
69satellite Samba Member
Joined: January 14, 2008 Posts: 208 Location: Kerrville, TX
Posted: Sat Jun 23, 2012 11:01 am Post subject: |
so what seal kit is the best to go with? seems theres issues with bus depots and some thing with werkberg luggage rack seal. I need a seal kit for my early style poptop and only want to have to buy this once. |
Bev1 Samba Member
Posted: Sat Jun 23, 2012 9:18 pm Post subject: |
Thanks Cefalu and Hoody. I appreciate the advice! Will try to tackle the pop top push on seal this week. I'm not sure where is the best forum area to update the progress. Seals: here - yes. VW selling, different topic area, but where? I'm noticing a number of people coming to see my 79 Westy and "test drive it" who use to own one. I think they are not serious buyers, but just want to go for a joy ride. Others come and don't even know the top pops up. Again, not serious buyers. I think I'll figure out how to sell it here on Samba. Maybe trade with some cash for a good Westy automatic this old body can hack. |
bugger101 Samba Member
Joined: September 04, 2010 Posts: 1559 Location: orlando
Posted: Sun Jun 24, 2012 6:03 am Post subject: |
notchboy wrote: |
Please pardon mys ignance. |
I am in the same boat _________________ 75 west deluxe http://www.thesamba.com/vw/forum/viewtopic.php?p=5270450#5270450
2010 ford focus |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Sun Jun 24, 2012 6:33 am Post subject: Re: Q about proper prep before placing on the seals here...a |
Bev1 wrote: |
Hi, I'm new to this site. I too just got a full set of new seals with a bulb from Werksburg |
i was less than impressed with that same seal set up. my poptop now whistles like mad on the highway _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Westfabulous Samba Member
Joined: January 07, 2007 Posts: 4207 Location: The tropic of Canada, dodging the giant flying moose of Surrey!
Posted: Sun Jun 24, 2012 7:21 am Post subject: |
As mentioned earlier, I have the bulb seal all the way around the bus. It is the only way to go in my opinion. Once and a while I'll pull the seal off the luggage rack and wash underneath. It can be put back on with the luggage rack in place; there is no need to remove it. There is no glue needed to secure it either. Click on the picture and you can see a larger picture of the seal and in particular the bulb.
_________________ *****************
"I will gladly pay you Tuesday for a hamburger today." |
Hoody Samba Member
Posted: Sun Jun 24, 2012 8:56 am Post subject: |
In answer to the question as to which is the best kit. The pop top seal and flat seal from BD are excellent. No complaints at all. The issue I had was with the luggage rack portion of the kit. Honestly I do not think they should even offer the "trim peice" with out the bulb. I am sure you can purchase their kit with the luggage rack seal with the bulb. As several people have stated there is no issue of water retention with the bulb. Personally I would not purchase any of these seals if they required glue. |
Posted: Sun Jun 24, 2012 5:37 pm Post subject: |
Westfabulous wrote: |
Are we talking about this kind of seal here???
t3kg wrote: |
1964 1500 S
Posted: Sun Jun 24, 2012 8:07 pm Post subject: |
notchboy wrote: |
Well, with all that glare coming off your shiny paint, it's hard to say for sure......but I would have to say yes from what I can see. Mine looks to be a thicker type of rubber though. _________________ *****************
Kirk Samba Member
Joined: December 05, 2003 Posts: 5487 Location: North Texas
Posted: Sun Jun 24, 2012 9:10 pm Post subject: |
Stuartzickefoose wrote: |
busdaddy wrote: |
Javyd wrote: |
i liked that beep.... |
HAted that beep. Always got me at work. _________________ MAKE FORUMS GREAT AGAIN
Bear
Coble
Super
Oppenheim |
werksberg Samba Member
Joined: February 08, 2005 Posts: 2151 Location: Prescott Valley, AZ
Posted: Mon Jun 25, 2012 12:34 pm Post subject: |
As IMO both Bus Depot and myself sell 2 different kits for both early and late bays.
A cheaper one with the trim for the luggage rack (more factory correct) and a little more expensive kit that has the luggage rack seal like the pop top bottom.
In my instructions for the luggage rack seal kits, I suggest to removing some of the bulb seal off the ends for water run off or slit the seal in the front or the back (late vs early bays) for water run off.
But most choose the cheaper kit.....
There never was any gel coating on these Westfalia FG tops. Just as instructions state, clean the lip where you need to glue the HD flat seal, apply some glue, apply seal and you might have to tape it into place until the glue sets up....
It's not rocket science. _________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
