levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Wed Jun 13, 2012 6:00 pm Post subject: pin at the bottom of brake backing plate/brake assembly |
So, there it is.
You say "yes, that is a pin"
(thank you if did not follow that with "pinhead")
It looks identical on the other side btw.
That little bastard has to be punched out of there, of course.
Couple of things make me curious about this one.
Seems to have a brassy coloration to it, that wouldn't be a brass pin would it?
Is this supposed to be a reusable pin ?
Can it be knocked out with a standard punch or do I need a brass drift ?
Is it directional? Can I punch it out either way?
...so many questions for a little pin that I never saw before, and why would they use a pin in this spot anyway? What's wrong with a bolt? _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1890 Location: Sidney B.C. Canada
Posted: Wed Jun 13, 2012 6:09 pm Post subject: |
use a brass drift, do not use a steel one. You don't want to mushroom the end.
it was a steel pin in my van, and it is re-usable.
alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Posted: Wed Jun 13, 2012 6:24 pm Post subject: |
It is a steel pin but the coloring looks like the R word(rhymes with dust) . It is 10mm x 22mm if you need a new one. They can be driven out in either direction but you can usually get better hammer blows driving it in from the backing plate towards the tranny.
I just use a steel pin punch about the same size and a single jack hammer to drive them out. A brass drift pin wouldn't be a bad thing though. |
Franklinstower Samba Member
Posted: Wed Jun 13, 2012 7:08 pm Post subject: |
mine popped out easy when I did my rear brakes by banging on the rear backing plate with a rubber mallet (i think? )
look here, page two: http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=20
Paul _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
levi Samba Member
Posted: Wed Jun 13, 2012 9:33 pm Post subject: |
thanks folks, shot it with some pb blaster, and we'll see what happens in the next couple days. _________________ One of these days I'm gonna settle down,
silverbulletuk Samba Member
Joined: February 02, 2010 Posts: 206 Location: NW Surrey, UK
Posted: Thu Jun 14, 2012 6:48 am Post subject: |
Those dowel pins are pretty hard, you won't bruise them using a flat-ended punch, just strike it with conviction, good and square with a #2 hammer. A soft drift will probably mushroom first! _________________ 1986 syncro twin-slider rhd, 3.2S Oettinger wbx6
1990 SA Microbus - Supercharged wbx going in with UN-1 trans.
www.025motorsport.com |
epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Wed May 24, 2017 12:44 pm Post subject: Re: pin at the bottom of brake backing plate/brake assembly |
Just got this little baby knocked out... I punched it from the front side > single strong blows with a big hammer did nothing. Then I tried fast repeated strong blows and it started to move... kept on doing that fast and strong and it came out.
_________________ www.edwardpowell.com |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Tue May 29, 2018 7:11 pm Post subject: Re: pin at the bottom of brake backing plate/brake assembly |
I’m building up a new set of rear brakes on a new backing plate to replaced the rusted out originals. After driving out the dowel pins I got to wondering why they are there in the first place. The two hardened M10 bolts that fasten the brake pivot bracket to the hub casting appear to be sufficient to anchor the brake shoes against rotation. Maybe they were designed to be an assembly aid at the factory. I am thinking about leaving them out on reassembly. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
