ferball Samba Member
Joined: August 25, 2014 Posts: 34 Location: New Hampshire
Posted: Tue Jul 19, 2016 5:18 am Post subject: Reverse Electrolysis |
Has anyone used "reverse electrolysis" to clean their cylinders? I have had quite a bit of success bringing my engine tins back from the brink of death with this technique. I am planning on trying out on my cylinders and valve covers this week but wanted to know if there was any concern about weakening the steel from a chemistry stand point before I take the plunge. |
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1399 Location: Cambridge, MA
Posted: Wed Jul 20, 2016 6:12 am Post subject: Re: Reverse Electrolysis |
Electrolytic rust removal won't make the metal any weaker than it already is. It doesn't remove any metal or alter the chemical makeup. In fact it technically converts rust back into metal (well, powdered metal). I'd say go for it. On cylinders, only thing I'd watch out for is "flash rust" after you remove them from the water bath. A spray with WD40 should prevent that. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
sdavidg Samba Member
Joined: June 13, 2016 Posts: 28 Location: Sacramento, CA
Posted: Wed Jul 20, 2016 1:59 pm Post subject: Re: Reverse Electrolysis |
If you take the plunge i'd be interested in seeing the before and afters, and maybe some pics of the process. |
Lil Lulu Samba Member
Joined: December 08, 2007 Posts: 1745 Location: Mouth of the Columbia
Posted: Wed Jul 20, 2016 2:14 pm Post subject: Re: Reverse Electrolysis |
Used this process for years. Works like magic. No damage. I let it flash rust again and then use Jasco Prep and Prime (Ospho X 10) then paint. Would not use the Jasco on cylinders tho. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles |
Posted: Thu Jul 21, 2016 6:24 am Post subject: Re: Reverse Electrolysis |
The cover on the left is after an overnight soak and quick rinse. The cover on the right is untreated. I will probably let it soak another night.
My next question on doing the cylinders is should I paint? I know current wisdom is painting cylinders is stupid and bad idea and only done by teenagers who don't know any better. But my experiance with the tinware is that if I don't paint it or treat it with something the rust comes back with a vengeance. how bad is a light coat of high temp paint for the cylinders/cooling "system"? |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri Jul 22, 2016 2:28 pm Post subject: Re: Reverse Electrolysis |
Paint would burn right off the cylinders and make a mess, stink like hell. The remaining mess will reduce the cooling too. _________________ '65 Beetle "Lil' Lulu"- Ruby Red
Posted: Fri Jul 22, 2016 4:28 pm Post subject: Re: Reverse Electrolysis |
Some people do paint cylinders with high heat enamels meant for engines. But the consensus AFAIK is that it reduces the cooling ability albiet not dramatically and is therefore not a recommended practice. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4538 Location: Arizona Highways
Posted: Fri Jul 22, 2016 5:37 pm Post subject: Re: Reverse Electrolysis |
ferball wrote: |
I know current wisdom is painting cylinders is stupid and bad idea and only done by teenagers who don't know any better. |
not sure where or when this consensus was reached, but I don't agree with it.
just built an engine with some cylinders i painted about 5 years ago and drove for 7000 miles.
they look and cool just fine.
you do know that you're not supposed to paint the insides, right _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
SGKent Samba Member
Posted: Fri Jul 22, 2016 6:02 pm Post subject: Re: Reverse Electrolysis |
Raul talked about it a couple times and suggested google videos on it.
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jul 22, 2016 6:43 pm Post subject: Re: Reverse Electrolysis |
borninabus wrote: |
ferball wrote: |
you do know that you're not supposed to paint the insides, right |
I paint all mine, it's prettier and stays cleaner, no heat issues either and some are approaching 30K miles. BBQ paint is perfect, if you are getting hot enough to burn that off you have other bigger issues. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
old DKP driver Samba Member
Joined: March 30, 2005 Posts: 4145 Location: Los Gatos,Ca.
Posted: Fri Jul 22, 2016 11:11 pm Post subject: Re: Reverse Electrolysis |
I also painted the cylinders on early 1200-1600 engines as most did back
in the day but, i quit when i heard it was not needed with cast-iron cylinders.
But, i have cleaned a lot of parts with Electrolysis over the years and i never
knew Raul did it too!
Small World _________________ V.W.owner since 1967 |
Posted: Wed Jul 27, 2016 8:38 pm Post subject: Re: Reverse Electrolysis |
I soaked a cylinder with decent results and it cleaned up nice, the only problem is the post bath scrub between the cooling fins. I probably won't paint because it looks decent and I am not sure the paint will last because I can't get wipe all the dust out between the fins. Anybody have a trick that works for getting it clean between the fins? I am happy with the job my wire brush did but I am open to suggestions. |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Wed Jul 27, 2016 11:14 pm Post subject: Re: Reverse Electrolysis |
busdaddy wrote: |
I paint all mine, it's prettier and stays cleaner, no heat issues either and some are approaching 30K miles. BBQ paint is perfect, if you are getting hot enough to burn that off you have other bigger issues. |
Black is the best color for absorbing and shedding heat. The value of black paint versus bare metal would depend on the ability to shed heat versus the insulation qualities of the paint. I doubt that a coat of black paint provides much insulation.
Damn: An opinion attempting to trump fact. I've been on the Vanagon forum too much.
Aloha
tp |
Maticus Samba Member
Joined: September 02, 2015 Posts: 25 Location: Louisiana
Posted: Thu Jul 28, 2016 12:13 am Post subject: Re: Reverse Electrolysis |
My experience with electrolysis was very positive (no pun intended) when I was restoring my gas tank. It was from a very crusty, filter-clogging mess to very nice, clean tank.
My setup:
I used my car's battery (she wasn't going anywhere anytime soon ) with a trickle charger attached to it, because the charger didn't just give off power all by itself.
As the videos above warned, you DO NOT want to have any open flames or allow electrodes to spark and ignite the Hydrogen gas coming from the electrolyte solution.
For de-rusting the cylinders, I think it would be a very good option. It doesn't take away the base metal so it wouldn't affect the bore negatively (pitting, warping) and it would be gentle on the valve covers. _________________ 1969 Rust Bugget AKA "Blitzkrieg" |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Thu Jul 28, 2016 6:19 am Post subject: Re: Reverse Electrolysis |
Bob Hoover has a good article on painting cylinders.. He essentially makes the argument that unpainted metal is best, but when it rusts you have a worse heat conduction than if you'd just painted it black to begin with _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Thu Jul 28, 2016 7:20 am Post subject: Re: Reverse Electrolysis |
ferball wrote: |
Anybody have a trick that works for getting it clean between the fins?. |
Sandblasting has always worked for me.
How about some Rust-mort/Ospho?, that stuff takes off the loose flash rust after a muriatic dip, maybe it'll work down in between the fins too? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Thu Jul 28, 2016 7:23 am Post subject: Re: Reverse Electrolysis |
I'd use radiator paint if you must paint a cylinder. It is a thin black paint designed for minimal heat transfer loss. Use as light a coating as you can get by with. Some radiator shops used to just thin their paint way down so the coat was thin. Some very long discussions on this topic go on in the racing world especially when the radiator is limited in size or thickness.
A US Navy commissioned study available online shows that painted metal surfaces regardless of paint type emit 95% - 98% of the amount of heat they did prior to being painted. The paint acts as an insulator. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Jul 28, 2016 10:28 am Post subject: Re: Reverse Electrolysis |
Here is one of my cylinders after soaking, the bath dislodged some rotted cooling fins, ideally I should replace the it but the budget and time constraints won't allow it. |
SGKent Samba Member
Posted: Thu Jul 28, 2016 10:41 am Post subject: Re: Reverse Electrolysis |
ferball wrote: |
you gotta be kidding me that you are going to use those cylinders. Find someone who is rebuilding a motor with new pistons and cylinders, and buy their old ones. I've thrown away ones that were 20X better than yours because they were junk. If the outside looks like that the inside will have pits that will cost a huge amount of compression and oil leakage. In the end you'll end up building a worn out engine that runs terrible. Really!
here is a 93 mm set for $40.
http://www.thesamba.com/vw/classifieds/detail.php?id=1953498 _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
