Malokin Martin Samba Member
Posted: Sun Jun 17, 2012 1:45 pm Post subject: Whats going on in my bellhousing? |
62 bus with original engine case.
I recently inherited a bus that was in some sort of inbetween stage of 6v to 12v conversion (possibly completed and driven that way, I don't know yet).
Either way, I got the engine out the other day and this is what I found:
Whats up with the metal bits? Leftovers from grinding?
Additionally, how does the grinding work look to people? Ugly but funcitonal?
Tips? Advice? |
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jun 17, 2012 5:44 pm Post subject: |
When the early type of pressure plate comes in the box it has clips stuck into it to keep it compressed. Those are the clips that should have been removed before installation of the PP. Doubt if anything got damaged, except maybe a few dinged FW teeth. _________________ In Stereo, Where Available! |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Sun Jun 17, 2012 5:46 pm Post subject: |
Eric&Barb wrote: |
When the early type of pressure plate comes in the box it has clips stuck into it to keep it compressed. Those are the clips that should have been removed before installation of the PP. Doubt if anything got damaged, except maybe a few dinged FW teeth. |
Truth. _________________ nothing |
Posted: Sun Jun 17, 2012 7:40 pm Post subject: |
Excellent! Thanks for the replies |
Clara Samba Member
Posted: Mon Jun 18, 2012 6:43 am Post subject: |
There is also an oil leak.
If it is stinky gear oil your need a new tranny shaft seal.
If it is engine oil, you need a new main seal/ o ring and might as well change the oil cooler seals at the same time. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Mon Jun 18, 2012 11:39 am Post subject: |
Eric&Barb wrote: |
Those are the clips that should have been removed before installation of the PP. |
For sure. I don't understand how the clutch even worked as that holds the pressure part from applying. |
