mgp51 Samba Member
Joined: February 03, 2014 Posts: 9 Location: Lakewood, Washington
Posted: Mon Mar 03, 2014 9:01 am Post subject: dent above left front fender |
i am new to samba. Joined last month and this is my 2nd inquiry. I'm restoring a 67 bug. Getting ready for some body work and notice that when I pulled the left front fender there is a small ripple in the body just above where the fender bolts to the body and runs down to the door hinge. Did not notice it when I bought the car. It's white. Question is, can this be pulled out or does that particular panel need to be replaced. Car does not appear to have had any front end damage. Seems to be intact. Any help or suggestions would be appreciated. |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Mon Mar 03, 2014 9:20 am Post subject: |
Hard to say without seeing it. Can you post a picture? Most stuff can be straightened, but that can be a hard area to access, and you certainly don't want to make it look worse. _________________ Plate of shrimp |
mgp51 Samba Member
Posted: Mon Mar 03, 2014 9:40 am Post subject: |
Thanx. I'll try to get a picture posted by tonight. It is a tough area to get to |
buguy Samba Member
Joined: November 17, 2003 Posts: 4915 Location: Port Orange, FL
Posted: Mon Mar 03, 2014 6:35 pm Post subject: |
There isnt much that cant be straightened. But you may want to take it to a compitant body shop that has the tools to do it right. |
mgp51 Samba Member
Posted: Mon Mar 03, 2014 7:07 pm Post subject: |
Thanks all. I've been sanding and fixing little dents so I will take it to the shop thats going to finish the prep and paint and let them handle it. Thanks again for the advice. |
djway3474 Samba Member
Joined: August 19, 2011 Posts: 2582 Location: The Real NDK So Cal
Posted: Tue Mar 04, 2014 12:36 am Post subject: |
sounds like a front quarter panel distortion from a slight front bumper impact. if that is it you need to get it on a stretcher as the inner panels are also out of position |
