type-4 heat shield
Page: Previous  1, 2, 3
Hoody
Hoody is offline
PostPosted: Thu Jun 13, 2013 9:35 am    Post subject: Reply with quote
Thanks for the info Tom!
Wildthings
Wildthings is offline
PostPosted: Thu Jun 13, 2013 9:39 am    Post subject: Reply with quote
poptop tom wrote:
My CHT's (DD) are running the same as before I installed my heat shield this spring.
I wouldn't expect to find much difference in the head temps, heat shield or no. What I would expect to find and have found is a difference in how long the foam gasket lasts.
1975 Kombi
1975 Kombi is offline
PostPosted: Sat Dec 19, 2015 10:48 am    Post subject: Re: type-4 heat shield Reply with quote
Just throwing another idea out there but wouldn't header tape wrapping the muffler be a better way of keeping the heat in the muffler and while your at it wrap the entire heater boxes and pipes.
Brett
Hes decieving you boy! Reach into his pocket and take what hes got. Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Licensed pilot (single engine land VFR)
Rust In Peace: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v
SGKent Premium Member
SGKent is offline
PostPosted: Sat Dec 19, 2015 11:34 am    Post subject: Re: type-4 heat shield Reply with quote
if you do some searching you will find that the biggest complaint about header tape is that it causes massive rust due to trapped moisture. I have no experience with it as we always ran our headers bare, but there are hundreds of articles and posts from people who say the rust is real.
Godspeed to all who undertake a journey in a VW Bus.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing those right.
* VW Buses and VW cars share many of the same systems but if you haven't owned a bus and maintained it for awhile, you really don't know how different it is.
1971 (sold)
1977
Tcash
Tcash is offline
PostPosted: Sun Jun 19, 2016 7:24 pm    Post subject: Muffler Heat Shield Dimensions Reply with quote
72+ Muffler Heat Shield Dimensions
Tcash
Tcash is offline
PostPosted: Mon Jun 20, 2016 12:39 pm    Post subject: 039 119 227 type 4 exhaust heat shield Reply with quote
ROCKOROD71 wrote:
Figured I'd post this here for posterity instead of starting a thread. Just got my heat shield from CIP1, so here are some crappy flip phone photos:
Was kind of surprised to see a Jopex Group sticker on there. I'm wondering if these are new production or old stock of something they no longer make?
The quality looks ok, thick gauge metal, welds on the brackets, etc.
Th one thing I noticed right away was in the pics I've seen of the OG shields it looks like two pieces of metal, with insulation or something between, and one side folded over the other, then spot welded. This piece looks to be just two identical pieces of metal with many spot welds all the way around, doesn't look to have that insulation between the two. Comes with thee old shop wear resistant paint on it. I will strip, paint with VHT and bake ASAP.
Anyways, here are the part numbers:
OG VW: 039 119 227
Jopex/JP Group: 8182600500
Barcode sku: 5710412426361
Made in Denmark
We'll see how it installs/holds up! I was just glad to find one!
Magion
Magion is offline
PostPosted: Tue Feb 13, 2018 10:44 am    Post subject: Re: type-4 heat shield Reply with quote
I took mine out yesterday and as expected it has lots of surface rust. I am going with more parts to a place where you media blast yourself. My concern is what is inside between the layers of metal sheet? Is that some sort of asbestos?
And if it is, Is it safe to media blast (of course assuming I wont be blasting directly into the gap) in enclosed blasting box?
1975 Campmobile
Wildthings
PostPosted: Tue Feb 13, 2018 12:43 pm    Post subject: Re: type-4 heat shield Reply with quote
When I redid mine I just left the stuff out. In this particular instance I doubt the bit of extra insulation makes much difference. Hot air is going to get above the heat shield no matter what so all the shield can do is block the radiant heat.
aeromech
aeromech is offline
PostPosted: Tue Feb 13, 2018 12:47 pm    Post subject: Re: type-4 heat shield Reply with quote
I wouldn't worry about asbestos killing you. The cabinet ventilates into a filter system and you shouldn't be exposed to it.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Page 3 of 3
