purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Wed Dec 05, 2012 9:28 pm Post subject: |
No hightop updates, got side tracked with the another engine swap, and the suspension R&R...I am pretty much done outside, except finishing my tire carriers I made up,
Still gotta make the tire mount and machine a billet hold down knob, I am making one for the passenger side to hold a couple gas cans and my honda generator. |
Posted: Wed Dec 05, 2012 9:37 pm Post subject: |
With the added hightop I HAD to rebuild my frontend, stuff was shot and side winds would cause my frontend to lift and I almost lost control once, I had almost 2mm of slop in my balljoints
the old...
Wifes cutting board snatched from the kitchen,
All new bushings, balljoints, tierods, dust sheilds, rotors, pads, bearings, GW 1.5'' lift springs and balljoint spacers
Welchmaster Samba Member
Joined: January 26, 2011 Posts: 445 Location: Milwaukie, OR
Posted: Wed Dec 05, 2012 9:48 pm Post subject: |
Very impressive mike! My favorite high top locally here in the NW. _________________ ________________________
90 2wd Orly Blue Multivan weekender. "Van-Duzer"
"Further up, further in!" |
Posted: Wed Dec 05, 2012 9:56 pm Post subject: |
Welchmaster wrote: |
Very impressive mike! My favorite high top locally here in the NW. |
Thanks! |
Jedi Samba Member
Joined: October 23, 2007 Posts: 734 Location: Cool California
Posted: Thu Dec 06, 2012 1:59 pm Post subject: |
Now you just need a syncro drive train so you don't have to chain up _________________ 1961 Westfalia SO23 Mango Green/Seagull grey
1961 Westfalia SO34 T/BW
1961 Westfalia SO34 SWR
1964 Westfalia SO33 pearl white
1965 Westfalia SO42 Velvet green
1986 Syncro Wolfram grey with black int GL
1986 Syncro Doka
1987 Syncro Sevana beige Adventurewagen
1987 syncro Sevana beige GL
1973 Pumpkin orange Thing
2 1963 Rag top bug's
1965 Manx
1970 Single cab
1971 combi
1990 Vanagon GL
2007 Audi A4 3.2L quattro |
Posted: Sun Feb 10, 2013 9:09 pm Post subject: |
Not a whole lot getting done on the van but I need to get on it hard.
Installed truck mirrors on it today (I used well nuts...aka rivi nut)
before
after
Next on my list is aux power setup, my current battery bank is only a small deep cycle and with a propex, dvd, cell phone chargers it doesn't leave me with much.
I am considering replacing the batt I have under the drivers seat with 4 UB12220's, I'll be adding a solor panel on the rear of the top at the same time, I need to get all my wires in place for the solar panel so I can install headliner in the top....the spaceship look inside is getting old. |
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 920 Location: Sammamish, WA
Posted: Sun Feb 10, 2013 10:08 pm Post subject: |
Mike, it's looking more awesome with every new update - be prepared to give a tour and answer 32,564 questions from me if you bring it to Walla-Walla _________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
Posted: Sun Feb 10, 2013 10:21 pm Post subject: |
Oh I'll be there with it! |
Posted: Mon Feb 25, 2013 9:59 am Post subject: |
Ok now on with the hightop stuff but a few things I have to decide on before I put headlinder up..
I will be adding a solar panel to the rear and I want to conceal wires behind headliner in a smaller piece of conduit.
It looks like an 85watt panel is about as big as I can put in the rear nook that my top has, there are a gazillion options
I run a propex 2800, adding a truck fridge...so my power needs are fairly high. |
J Charlton Samba Member
Joined: August 24, 2007 Posts: 1546 Location: The True North Strong and Free
Posted: Mon Feb 25, 2013 11:45 am Post subject: solar |
I agree - $500 seems to be a lot - I suggest that you talk to them, I think that an inverter is included in that price and you may not need it. Also, on their site there are some examples of racking that will allow you to tilt the panel up to maximize output.
Pm me about some gutter mounted heavy duty racking that I have developed for the high tops. _________________ NAHT hightop availability May 18 2023 -
Bend Oregon - for Oregon, California- (7 tot , 3 available), Kennewick Wa (6 tot, 1 available), Small Car Performance Fife Wa. (7 tot 4 avail ), Fairbanks Alaska (1 tot 0 avail)
Future availability TBD : Springfield Mass. Staunton Va, Florida, Colorado, Grand Junction Co., SLC probably late 2024 |
Posted: Sat Mar 30, 2013 9:22 am Post subject: |
I finally have my panels mounted in place, I've put them in a clamshell frame with hinges (I plan on using a small electric lift to tilt panels, this is for down the road)
I used evercoat 810 med epoxy on the frame to roof, Its not going anywhere, plus I had half a tube left from gluing the top on.
the little metal tab is going to get trimmed and a hole drilled through it for a handle, I can tilt up the panel now to work on it.
I am using the yoosmart 1214 (aka tracer 1214) for my charge controller and this will be feeding a bank of 6 ub12220 batteries...
My big step today will be drilling a hole for the wires leading from the panels, I plan on using a 16gauge extention cord for this, as it appears that this has worked well for others on here...I am not convinced that just drilling and sealing is what I'll be doing though, I want to find a good water tight fitting for that.
Here is a link for the controller I picked up,
https://www.yoosmart.com/epsolar-mppt-tracer1215rn...-mt-5.html |
Syncromikey Samba Member
Joined: September 19, 2012 Posts: 463 Location: Calgary, Alberta, Canada
shadetreetim Samba Member
Joined: January 10, 2011 Posts: 1994 Location: Riverside, California
Posted: Sat Mar 30, 2013 10:15 am Post subject: |
Looks like those panels just fit the space. Looks good. _________________ Tim Potts
Doing my best every time I drive it to dispel the myth these Vanagons have to be slow!
'89 Vanagon Bluestar/Country Homes 1.8T & .77 4th
'74 Jeep CJ5 |
kernewek Samba Member
Joined: December 09, 2012 Posts: 44 Location: France/UK
Posted: Sat Mar 30, 2013 11:54 am Post subject: |
Nice install, fits the space real well. How about using something like this for the cable entry into the roof? They work well for vans on this side of the pond (and yes, in the UK we get LOTS of rain, so no weatherproof issues!)
http://www.campervanstuff.com/shop_stuff/index.php?mod=product&id_prd=1073
~ Craig _________________ 1998 T4 2.5 TDI with Timber Technicians high top
1985 T3 1.6TD hightop camper |
shepherdsond Samba Member
Joined: April 25, 2005 Posts: 439 Location: Bellingham, WA
Posted: Sat Mar 30, 2013 1:24 pm Post subject: wiring |
Ho Mike,
Think about running the wire down the outside of the top. just "around the corner" on one side or the other. Thenthe wiring can be brought up into the van through the caulking/adhesive in that rear corner. I you use white wire and secure it in place with some high quality white tape made for external applications then the entire install would not necessitate any through holes.
Anyway, just an idea, but it is the way I'll be doing it.
John _________________ NAHT hightop availability May 18 2023 -
Posted: Wed Apr 03, 2013 8:25 pm Post subject: |
Got to work on interior stuff so I can get wires hidden from solar panel...
I decided to use my hull liner on panels and screw them to the sides/top to give it more of a finished look, we shall see....
I used some 3/8'' plywood and furred out the interior to allow me to screw panels down
Gorilla tape holding everything up in place till braces went up
PVC pipes did the trick well
Cutting panels to fit the top, lots of angles....I used oak "door skins" these are a good width without wasting much material.
Cutting hull liner to fit
Made a roller to get things nice and smooth
All glued on, I used weldwood low VOC glue and a roller
One side done
More work tomorrow, glue has to cure 24 hours so I should be done gluing my furring by friday... |
Hodakaguy Samba Member
Joined: April 25, 2012 Posts: 661 Location: Eastern WA
