crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9939 Location: Orbiting San Diego
Posted: Wed Jun 27, 2012 5:14 am Post subject: |
In order to keep the twisting forces oriented the same, the used axle needs to stay on the same side of the vehicle. Swapping ends doesn't change this. If you move the axle over to the other side of the tranny it will reverse the twist. Swapping ends doesn't change this either.
Mark
ALIKA T3 wrote: |
So,once new,the shafts are installed a certain way,it doesn't matter right?
That's only because of stress that we shouldn't move them from side to side without reversing them,correct?..... |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
r.e.wing_fc3s Samba Member
Joined: April 16, 2010 Posts: 591 Location: Vanagon Capitol USA: Bellingham, WA
Posted: Sun Aug 12, 2012 10:15 pm Post subject: |
do these 944 cv's have increased travel over the stock axles or just increased angle? _________________ Reference Automotive: NW Washingtons Vanagon Specialist. (360)366-6965. referenceautomotive.com |
Jon_slider Samba Member
Posted: Mon Aug 13, 2012 9:23 am Post subject: |
IF your shocks allow increased down travel, your axles will be at a higher angle at full droop, in which case you might want a CV capable of operating at a higher angle.
I chose to use a CV with greater than the maximum 17 degree operating angle of stock CV's because at maximum droop, my axles are at 19 degrees. My fox shocks front and rear, allow an extra inch of droop.
The 944 CV is rated for a max angle of 22 degrees.
I now have 3000+ miles on the 944 axles and 944 CVs on the rear of my van. They are working great, no problems of any kind. I have been offroad and have locked my axles on the fly when going up hills, and I have even yanked other vans out of the sand.
I have stock front axles and CVs, they are also working great. My syncro weighs over 5000 lbs and the TDi motor has over 200ft lbs of torque. My front ride height currently is 20", my rear ride height is 21"
I use Swepco 210 in my transaxle, and in my front differential, which has a solid shaft, no Viscous Coupling. The van has a decoupler as well as front and rear lockers. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
insyncro Banned
Posted: Mon Aug 13, 2012 9:30 am Post subject: |
I'm running 944 CVs front and rear on a Syncro that is not lifted from stock.
Many, many miles without issue.
I have tested these same axles on my lifted Syncros and they work great, no issues to report. |
r39o Samba Polizei
Posted: Mon Aug 13, 2012 10:57 am Post subject: |
insyncro wrote: |
Are you using current new kits which seem to be GKN/Loebro or recycled originals?
Current cost plus is about $75 for the new kit each.
These days who knows how good they really are....
My buddy races 944s and slaughters lots of them for donor parts so I may be in luck for some freebie used ones of my choice (minimum pits.)
Just curious. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3343 Location: Talos IV, Piedmont Arizona
Posted: Mon Aug 13, 2012 1:32 pm Post subject: |
They work on a 181 too. _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
r39o Samba Polizei
Posted: Mon Aug 13, 2012 2:49 pm Post subject: |
Captain Pike wrote: |
They work on a 181 too. |
What's that thing? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
insyncro Banned
Posted: Mon Aug 13, 2012 7:57 pm Post subject: |
r39o wrote: |
insyncro wrote: |
Just curious. |
I am not using new, as in the most recently produced stock.
My stockpile of Porsche and Vanagon related parts were mostly purchased around when I bought my first Syncro...1995.
I paid $400 for each set of 8 that I would buy via my race parts Guy.
I stocked up on 930s, these from the 944 and various other Porsche parts that will work with our Vanagon systems. |
Posted: Thu Aug 16, 2012 7:23 pm Post subject: |
so ill ask again anyone know if the 944 axles have increased travel i.e. in/out distance. compared to stock/930/thing/type 4. i am aware of the angle differences. id like to not have to uses limiting straps. the axles i have achive the angle i need but they need more extension at full droop to not be the limiting factor. _________________ Reference Automotive: NW Washingtons Vanagon Specialist. (360)366-6965. referenceautomotive.com |
Posted: Thu Aug 16, 2012 7:41 pm Post subject: |
Go get a set and see if they tear out. Then post your results. Go Kirk on this one. Where no man has gone before...... _________________ LEARN TO SELF RESCUE
Posted: Thu Aug 16, 2012 9:23 pm Post subject: |
never heard of anyone talking about CV joint travel the way you are
but the 930CV body is thicker, so I would guess it has more plunge than the 944 which is narrow similar to the stock CV joint
I believe if your CV joints are the limiting factor, there is a problem with your shock travel being excessive, for which limiting straps would be the cure
what shocks and springs are you using, and did you modify the shock mount to increase extension, thereby creating your bind on the CV joint?
Let us know what caused your CVs to bind, and how you fix it _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
insyncro Banned
Posted: Thu Aug 23, 2012 8:48 am Post subject: |
There are beefier internal parts available for when 930s are being used.
Derek Drew broke that same part with a waterboxer powered Syncro. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Thu Aug 23, 2012 10:11 am Post subject: |
Jon_slider wrote: |
Moral of the story, if you dont want your axles and CV's to act as a protective fuse for your transaxle or differential, use a 930 Axle and CV to transfer the force to the differential. |
Was the part that failed new?
Was it abused prior with other axles?
Was it a manufacturing defect or abuse?
How was it broken?
I have been running 930s for a few years without breaking anything- should I be worried? |
Posted: Thu Aug 23, 2012 10:21 am Post subject: |
my comments are based on evidence of breakage. Since you have no breakage, yet, we dont know where your system's weak link is. But my guess is you will break your transmission before your 930 axles and CV's.. thats the point of sharing this info
fwiw
your 2.2 subie motor has had less power than the 2.5 subie that broke the differential output shaft, and your syncro runs smaller tires and has less ride heigh/body lift
now that you have increased your motor power to approach the power of the one that broke the diff output shaft you are in position to join the club.
All you need is bigger tires, more body lift, learn to drive like Frankensubie and DASMULE, and a trip to Mogfest.
You wont know where your weak link is until you break something, abuse required.
are you feeling lucky?
Im running 944 axles and 944 CV's, and have never broken one.. should I worry? _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
Posted: Thu Aug 23, 2012 10:25 am Post subject: |
So you are now saying that it is more than just the parts? I would like to know if this is a imminant failure or isolated.
I have been in the mogfest pit before and drove home 12 hrs under my own power.
Do you know the particulars on both failures? The Das Mule failure was abuse so no learning involved. |
insyncro Banned
Posted: Thu Aug 23, 2012 11:56 am Post subject: |
Driver error in harsh terrain breaks parts.
One slip of the clutch with a tired foot from prolonged creeping and ....whammo. |
Hodakaguy Samba Member
Joined: April 25, 2012 Posts: 661 Location: Eastern WA
