Kharon8 Samba Member
Joined: March 05, 2011 Posts: 375 Location: Espoo, Finland
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22422 Location: Kimball, Mi
Posted: Fri Aug 10, 2018 6:38 am Post subject: Re: Official Type 34 thread |
Papers off so you can see whole chassis and door with first paint (2 layers). We'll do buffing when the paint is totally dry, after few months as we've no hurry with this car.
http://kharon.suomiforum.com/www/ghia3/P8071262.JPG
http://kharon.suomiforum.com/www/ghia3/P8071263.JPG
Seats need rebuilding and seat frames needs to painted so there's still work to do before starting assembly.
Engine is also still in pieces, we haven't yet even checked how bad the old parts are.
Odometer says about 77 thousand kilometers and if that's the first round engine should be in relatively good shape, just replace the wearing parts and that's that.
Rebuild anyway, doesn't make sense to skip that. Possibly slightly larger engine too, something like 1584cc (aka '1600'). _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
FVWA.fi support group. |
Posted: Sun Aug 12, 2018 3:07 am Post subject: Re: Official Type 34 thread |
Bobnotch wrote: |
Looks good, I like the color combo. Great job. |
Thanks.
More or less just work so far, but the interesting part will be getting it all together. We've a big pile of pictures about how it was but there's always something which isn't clear.
I've whole wiring loom on the floor currently, the idea is to measure/verify all the wires, clean the connectors with citrid acid and replace anything that looks it won't last another 20 years.
AFAIK there's no such thing as a new wiring set for T34 so repaired/refreshed old one has to do. Fortunately original wires are high quality and some previous owner has already replaced many connectors. But yellow jacket insulated crimped connectors, ouch ... those must go and original style (uninsulated) will be used instead. _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
tanhis Samba Member
Joined: July 23, 2005 Posts: 655 Location: Rauma Finland
Posted: Thu Aug 16, 2018 4:51 am Post subject: Re: Official Type 34 thread |
T34 upholstery material blue cerulean
Is this material still available as reproduction. I found out that this was reproduced around 10 years ago but no news after that.
_________________ -58 Typ2 ambulance
-62 Typ 34
-65 Typ 34
-73 411 variant all metal custom
-69 typ 2, 9 seater
-89 vanagon camper conversion matkaaja
-08 3.0tdi phaeton |
pedro sainz Samba Member
Posted: Thu Aug 16, 2018 7:25 pm Post subject: Re: Official Type 34 thread |
tanhis wrote: |
SMS don’t have any names
To order email them a picture
This is the closest Available
Is a little more Green look
Than Blue
I seen it in person and describe it as it is
Yes still in Stock _________________ 68 T34 1600 Automatic
62 T34 Cabriolet Prototype
N.O.N.A member #3
The Truth is Out There |
Posted: Thu Aug 16, 2018 7:43 pm Post subject: Re: Official Type 34 thread |
looks GREAT
just wondering your decision to Delete the rocker trim _________________ 68 T34 1600 Automatic
N.O.N.A member #3
tanhis Samba Member
Posted: Mon Aug 20, 2018 5:03 am Post subject: Re: Official Type 34 thread |
pedro sainz wrote: |
tanhis wrote: |
Than Blue
Yes still in Stock |
Thank you I will contact them.
This is a piece from under the rear seat that most like has not faded or changed color in the sun and it also looks more green than blue. So I think that the greenish tint is more accurate than the blue.
-62 Typ 34
-65 Typ 34
-69 typ 2, 9 seater
Posted: Mon Aug 27, 2018 2:15 pm Post subject: Re: Official Type 34 thread |
looks GREAT
just wondering your decision to Delete the rocker trim |
Thanks and I didn't!
I've the trim and the clips and everything, what happened is that we forgot to drill the holes to rocker panel before painting them. Ouch.
Fortunately we do have large pieces of original panel left so we get the position right.
Also an update: We lifted the body on the frame and it sits like it was made for it. Already bolted down and the car looks almost like drivable. No steering though as steering column and related parts are missing.
(Pics will follow later.)
Wiring set is still on my floor, engine is in pieces and most of the interior needs more or less cleaning/repairing/rebuilding.
Well, winter is just coming, no hurry.
But one thing we did, a modification: The pipe the wiring set was going through was basically rusted away so we had to create a new one from scratch anyway, so we made it 10mm larger than the original, now (if I recall correctly) 40mm.
Much easier to install wiring set back and it's not really visible anywhere. No idea why the original was so small, there's plenty of room. _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
Erik G Samba Member
Joined: October 16, 2002 Posts: 13278 Location: Tejas!
Posted: Thu Aug 30, 2018 7:48 am Post subject: Re: Official Type 34 thread |
Erik G wrote: |
I'd be tempted to use some kind of adhesive instead of drilling holes, but at least use spray wax if you haven't already |
Paint into holes and rust proofing to every box we can find. Currently we've Tectyl 558 on plans but that may change. Basically anything similar we can find will do as this car is not driven in wintertime.
We may have to drill some new holes for rustproofing so some re-painting will most probably be needed anyway. It would have been easier when the car was in pieces but we forgot that too.
"TECTYL 558 AMC is an amber colored, solvent cutback, slightly thixotropic wax base corrosion preventive compound
TECTYL 558 AMC is primarily intended for spray application to enclosed boxes, seams, joints and other creviced locations of vehicles, susceptible to corrosion." _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
ratlookvw Samba Member
Joined: June 21, 2004 Posts: 1809 Location: midnight train to GA
Posted: Tue Nov 06, 2018 2:56 pm Post subject: Re: Official Type 34 thread |
guys and gals, who was the fella that was reproducing the replacement arm for the rear trunk lock/catch I have seen the ad a 1000 times but now that I need a few cant find the ad. thanks in advance! _________________ If the RV Hut is a rockin, don't come a knockn'
57 Panel, 66 highroof panel, 65 Notch, 59 Vert, 61 Vert, 1969 Fridolin, 'Reggie ' 66 RV, 65 Pipe Truck, 65 RHD T-34, 70 dbl slider panel, 1969 Deep sea green sunroof automatic square, the greypoop-on, and a shit load of wheels! |
EasternNotch Samba Member
Joined: January 19, 2006 Posts: 634 Location: Boston Metro West
Posted: Wed Nov 07, 2018 7:59 am Post subject: Re: Official Type 34 thread |
🙏 so much!!!! Lucas
EasternNotch wrote: |
ratlookvw wrote: |
guys and gals, who was the fella that was reproducing the replacement arm for the rear trunk lock/catch I have seen the ad a 1000 times but now that I need a few cant find the ad. thanks in advance! |
Looks like the ad is inactive now, maybe reach out beertype3 and see if he still has any
https://www.thesamba.com/vw/classifieds/detail.php...4DSsm6dmR0
-Lucas |
Posted: Wed Nov 07, 2018 2:10 pm Post subject: Re: Official Type 34 thread |
ratlookvw wrote: |
🙏 so much!!!! Lucas
ratlookvw wrote: |
-Lucas |
Those pieces look like the ones Peaceful Warrior (Brian) had made up about 6 or 7 years ago. Don't know if he has any left. He's also not here in the t-3 forums any more, but he still has a bus or 2, so you might find him in there. Last time I talked to him on the phone, he hadn't moved yet, and was still working on 1 of his buses. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Dec 10, 2018 12:57 pm Post subject: Re: Official Type 34 thread |
We didn't do basically anything in summer, other projects and driving around while the season lasts. Engine to pieces, block to machine shop and wiring under work etc. small things.
But some new details:
http://kharon.suomiforum.com/www/ghia3/P9191310.JPG
http://kharon.suomiforum.com/www/ghia3/P9191307.JPG
http://kharon.suomiforum.com/www/ghia3/P9191306.JPG
Engine just came back from machine shop, needs just new bearings and some assembly: All parts are already painted.
Wiring set pulled to pipe and installation of electrical stuff can begin.
Rims sandblasted and painted, new tyres needs to be sourced as old ones are very old. Shouldn't be a problem.
What we need is new carpets (didn't have them in the first place) and interior roof. The latter fortunately is standard VW light beige vinyl and we can use old roof as template.
Ordered charcoal carpet set for my small Karmann (typ14) from Newton Commercial and once those arrive we decide if we order similar set for this one. I've heard they make high quality stuff and price *cough cough* is reflecting that, £612 (incl. VAT) for typ14.
Seat frames need sandblasting and paint but canvas should be OK just by washing.
That leaves some chrome parts to be re-chromed and many rubber parts we have only in very poor condition and no replacements for now.
Those will be headache at some point. _________________ Kharon -- '62 typ1, '63 typ14, '61 typ21, '65 typ34, '74 412, '75 typ26
