Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Mon Jul 02, 2012 1:25 pm Post subject: Port a wall on Smart car tire |
ok, I've run port a walls but never on a smart car tire
My car isn't that low to begin with, but 165r15 is too big. I'm considering 165/60/15, 145/65/15 and 155/60/15 for the front. Probably the 155. Has anyone tried the Kumho's yet? better or worse rim saver than the conti's?
I purchased some Atlas port a walls. I have seen some people allude to cutting the rim saver to make them lay right. Any pics? What did you do? what did you use. Thanks in advance _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Erik G Samba Member
smitty24 Samba Member
Joined: April 28, 2008 Posts: 2723 Location: Salem, Oregon
Posted: Fri Jul 06, 2012 12:41 pm Post subject: |
Erik, I have seen a couple guys cut those rim savers out. Personally, I believe it is there for a reason. Tires are too expensive to cut them up to fit a plastic insert in them. I would NOT use anything less than the 165/60 for an insert. I tried them in the past on a 145/65 as well as 155/60. Both had issues. The biggest problem when fitting inserts is width. If there is not enough meat to push, the inserts look terrible and will self destruct in no time. Tires do stretch to seat a rim, but stock 4" is not enough with inserts. 165/60 is just right and barely gives enough sidewall diameter to seat a 2" insert.
As for quality, I would assume they are similar. I go through a lot of tires and suspension setups. I use what works. I personally do not like Kumho tires. Used to use them a lot. There are better tires now. The Contis are hard to beat. I strongly doubt Kumho has improved; probably just jumped on the Smart car bandwagon in hopes of instant success= which is fine. Continental kind of has a monopoly in the United States. |
blackp5ca Samba Member
Joined: April 29, 2009 Posts: 118 Location: Barrie, Ontario. Canada
Posted: Mon Jul 09, 2012 12:41 pm Post subject: |
I used to run the porta-walls on a set of Conti smarts up front..you'll need to spend a little time with a dremel to grind the lip saver off...don't worry, there is lots of rubber "meat" there, just take your time.
If I were to do it again..i would run the porta-walls on some 135's. Little more sidewall, the inserts on the low profile of the 145/65's looks a little goofy to me..not enough black sidewall showing (but thats just my opinion)
Cheers.
Erik G Samba Member
